 Audio Aero Capitole,USA favorit,okänd i Sverige?
ulf
Posted - 2003/02/19 :  00:33:14  Show Profile Send ulf a Private Message
Denna CDspelare, nu i version 2, höjs ständigt till skyarna på amerikanska chatten Audiogon.com. Det anses om och om igen som en av de mest välljudande CDspelare som finns (även om den tydligen har en del funktionsproblem) oavsett pris. Är det någon som har lyssnat på denna franska rörbestyckade CDspelare?
markku
Posted - 2003/02/19 :  06:50:33  Show Profile Send markku a Private Message
Ulf,
Inte så, att jag har lyssnat på denna, men tänkte att bifoga Enjoy The Musics onlinetest av Audio Aero Capitole 24/192 Mk. II, var så god:
http://www.enjoythemusic.com/magazine/equipment/0902/audioaerocapitolen.htm
Jag saxar smakprov:
As with the Reynaud Offrandes, which appear to have similar sonic goals, the numbers do not tell much of the story here, since the Capitole II does not seem to as much interested in absolute information retrieval as in getting more of the sense of a "live" performance, for which Enjoy the Music has not yet devised numerical parameters.
In reviewing my ratings for the Naim CDS2, I blush a little at the numbers, which now strike me as affected by moderate grade inflation. I gave the Naim a 100 for imaging, which is too high. The Capitole II is superior to the Naim in imaging and in matters of spatial extension in all directions. The spatial qualities of the Naim strike me as entirely satisfactory but far from sensational, which the Capitole II's can sometimes be. The Naim seems to me superior to the Capitole in matters of tonality and in overall resolution. None of this, of course, matters a whit, if you prefer the overall results of the Capitole II.
Markku
I have no special talents. I am only passionately curious. - Albert Einstein 1952
markku
Posted - 2003/02/19 :  08:58:54  Show Profile Send markku a Private Message
Ulf,
Beträffande Audio Aero, ta kontakt med Pondera i Malmö. Ponderas Showroom websida listar ju följande:
Acapella High Harlekin speakers
Audio Aero Capitole MkII CD-player
Theta Digital Dreadnaught power amplifier
Audio Research LS-16 preamplifier
PENAUDIO Rebel and Charisma speakers
Dunlavy Audio Labs SC-I/AV speakers
http://www.pondera.se/rframe.htm
Markku
Edited by - markku on 2003/02/19 09:09:55
Hatoil
Posted - 2003/02/19 :  09:43:18  Show Profile  Visit Hatoil's Homepage Send Hatoil a Private Message
Anders har en på Hifi-stället i Göteborg också.
Säljer ny och begagnad vinyl i butik och på nätet: www.vinylium.se
ulf
Posted - 2003/02/20 :  02:25:12  Show Profile Send ulf a Private Message
Hatoil har du lyssnat på Capitolen? Vet du vad Anders tar för den?
Gebex
Posted - 2003/02/20 :  08:01:37  Show Profile Send Gebex a Private Message
Pondera tar 72.200 för spelaren.
Neodynium
Posted - 2003/02/20 :  08:14:52  Show Profile Send Neodynium a Private Message
Anders sa 65.000:- till mig... bäst att ringa och kolla dock.
Är också lite nyfiken på denna maskin.. jag undrar hur den står sig mot en Wadia 861.
linkan
Mångalen...!?
Posted - 2003/02/20 :  09:00:25  Show Profile Send linkan a Private Message
Är det MK II som säljs för dessa pengar, tyckte mig läsa i länken ovan att MK II skulle ligga på $8700 och det torde ju vara en bit över
65000 SEK.
Linkan
Knoppen
Posted - 2003/02/20 :  10:08:34  Show Profile Send Knoppen a Private Message
OBS! Nedanstående data är hämtade från länken ovan, ej tillverkarens hemsida som jag inte hittar.
Total harmonisk distorsion är på 0,3%, vilket får anses som extremt högt för att vara CD-spelare. Det kommer garanterat att höras.
Sedan verkar det lite lustigt att högpasfiltret är olika för 44,1 kHz (-1 dB @ 7 Hz) och 96 kHz (-1 dB @ 3 Hz) samplingsfrekvenser på ingången. Det finns inga tekniska argument för att välja olika högpassfilter. PCM-systemet tillåter nämligen signaler ned till likspänning utan problem.
Sedan specar de även -1 dB @ 20 kHz (fs = 44,1 kHz) och -1 dB @ 48 kHz (fs = 96 kHz) vilket är konstigt på flera sätt. 1) Om det vore sant så är det extremt dålig frekvensgång med avrullning på 1 dB @ 20 kHz. 2) Oftast stämmer inte dessa värden med verkligheten, den kan mäta bättre än så. Finns det någon som kan länka till en test med uppmätt frekvensgång?
När de skriver "High quality IC analog attenuator" så är det en finess som finns på D/A-omvandlarchipet, även om det är en bra grej, så har de i alla fall inte utvecklat den själva, det är en slags "på-köpet-finess" som man får om man väljar den DAC:en.
Själva DAC:en är någon slags enbit som Analog Devices fantasifull döpt till "Multibit Sigma-Delta modulator". I lyssningstesterna jag gjort har det visat sig att äkta multibitsdacar i genomsnitt presterat långt bättre än enbitsdacar. Det var ett generellt uttalande och denna produkt behöver alltså inte vara dålig för det, på just den punkten.
Johan L.
markku
Posted - 2003/02/20 :  10:18:07  Show Profile Send markku a Private Message
Johan L.
Nej men Knoppen då! Du måste använda lite mera fantasi och initiativ. Adressen är ju rätt enkel, eller vad:
http://www.audioaero.com/
Markku
Anders47
Posted - 2003/02/20 :  11:08:05  Show Profile Send Anders47 a Private Message
Förstår inte riktigt karaktäristiken chat angående Audiogon som den som startar tråden gör.
Audiogon är en marknadsplats där man i och för sig kan göra fynd, men med viss risk. Skall inte överdrivas men det händer att folk blir blåsta. Å andra sidan kan man hitta saker som är mycket billigare än i butik.
Till saken! Produktbeskrivningarna på Audiogon är ofta något av det mest hypade jag har sett. Allting beskrivs som otroligt bra, unbelievable, extreme, stunning etc.
s.m.f
Posted - 2003/02/20 :  13:49:23  Show Profile Send s.m.f a Private Message
[i]
Instämmer till fullo, inte mycket att överhuvutaget höjja på ögonbrynen av om man läser det där...
Pro-ject RPM 5.1/Oppo bdp 105/Yamaha CX-A 5000/ Primare A30.7/XTZ 2x12.18Ice/Avanti A100DC
s.m.f forever
s.m.f
Posted - 2003/02/20 :  13:50:36  Show Profile Send s.m.f a Private Message
även om just denna spelare kanske är jätebra, det säger jag inget om.
s.m.f forever
pnd
Posted - 2003/02/20 :  16:35:59  Show Profile Send pnd a Private Message
Förklaring när det gäller Audio Aeros priser.
Priserna beror på SEK/EUR kursen. Audio Aeros rekommendation för Capitole MkII listpris i Europa är EUR 7 680.
Jarmo
___________________________________
Pondera
Råkritegatan 4
212 36 Malmö
E-mail: info@pondera.se
Hatoil
Posted - 2003/02/20 :  19:32:55  Show Profile  Visit Hatoil's Homepage Send Hatoil a Private Message
Anders47: Audigon har forum också, det är säkert där den är hypad, inte bara i annonserna.
ulf: Jag har inte hört den och vet faktiskt inte om det är en mkII heller. Men Anders där brukar ha det senaste.
