 Varför Raven så dyra?
Page: of 3
Niklas Nord
Posted - 2002/11/14 :  12:52:45  Show Profile Send Niklas Nord a Private Message
3.1 kostar 16000:- styck, varför?
A close view of the 30mg membrane that reaches from 500 Hz to 35KHz!
ska raven ha en transformator? är det bara för att
det är ETT band, av alu? eller är det mylar..
dom är stora också..
en R2:a ;
en R1:a ;
svaret kanske kommer här;
The Raven pure ribbon tweeters have been acclaimed by many as the very best high frequency transducers available and for good reasons, extremely strong motors, almost negligeable moving mass, smooth and extended response and very low distortion figures.
Three models are available and they share the same sonic signature: very detailed, airy and light, extremely dynamic with both small and large signals and above all very musical.
I invite you to review the manufacturer's spec sheets by clicking your model of choice. (Please note that the spec sheets reflect the previous version of Raven's)
Raven R1.0 95db/2.83v, 2.5Khz - 30khz. $217ea
Raven R2.0 98db/2.83v, 2Khz - 30Khz. $307ea
Raven R3.1 100db/2.83v, 500hz - 30khz. $1,650ea
http://www.orcadesign.com/companys%20products/ravendrivers/raven3.html
den är farlig, här sprängs den;
har också en del mått;
t.o.m. en kurva, fast det är ingen kvinna, en högtalare??
(SNIPPLETS) very nice page; http://www.snippets.org/ldsg
Raven is a specialty brand of monopole ribbon tweeters produced by Orca Design. Although not cheap, the Raven drivers offer arguably the sweetest top end you can build into a system. The one caveat is that, like all true ribbons, they tend to be delicate and easy to damage, mechanically and/or electrically, by mishandling or careless crossover design. If you do damage one, Orca (the worldwide rep) will either fix it for you or can send you the parts to easily fix it yourself. One other caveat - all of the Raven models have enormous unshielded magnets and should never be considered for use near a TV! All three current Raven models are recommended:
The R1 model has been on the market for a while and has earned an enviable reputation. The rated sensitivity of the R1 is 95 dB. The recommended lower crossover frequency 2 kHz with a 60 W power rating. Since true ribbons have inherently low impedance (less than or equal to 1 ohm in many cases), the R1 has an attached transformer. This transformer and its attachment have undergone several evolutionary changes during the R1's life. view factory graphs 3rd party FR
The R2 model has been on the market about as long as the smaller R1 and has earned an enviable reputation. The rated sensitivity of the larger R2 is 98 dB. The recommended lower crossover frequency 2 kHz with a 60 W power rating. Since true ribbons have inherently low impedance (less than or equal to 1 ohm in many cases), the R1 has an attached transformer. front view rear view factory graphs 3rd party FR (horizontal) 3rd party FR (vertical)
Raven's latest design is the R3.1 super mid/tweeter unit which covers the audio spectrum from 500 Hz to 40 kHz. The sensitivity is rated at 99 dB and the power handling is rated at 60 W in its passband. This is significant, since the R3.1 is usable down to 500 Hz. While 60 W is plenty for the R1 and R2, crossed over at 2 kHz, the area between 500 Hz and 2 kHz contains significantly more energy in most program sources. Like the R1 and R2, the R3.1 uses a transformer to match its very low impedance. My respondents tell me that these are truly awesome. Unfortunately, they're priced accordingly - the MSRP earns this driver the distinction of being the among highest priced units in the LDSG. view response
Raven is distributed in North America by MCM, Speaker City, Zalytron, and E-Speakers.
Raven is distributed in Australia by W.A.R. Audio.
ack
Edited by - Niklas Nord on 2002/11/14 13:02:08
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  12:55:04  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Kanske för att det är så väldigt mycket dyra magneter i den?
Driver forumet faktiskt.se
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  12:58:44  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Jag kom på två punkter till utvecklingskostnad och väldigt liten upplaga.
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  13:13:46  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Det är ett äkta ribbon, alltså Aluminium.
norman
Posted - 2002/11/14 :  13:25:40  Show Profile Send norman a Private Message
R1:an var ju inte så dyr ändå, går iaf att jämföra prismässigt med andra lite finare diskanter.
Niklas Nord
Posted - 2002/11/14 :  13:30:47  Show Profile Send Niklas Nord a Private Message
Vad för mördarmagneter innehåller den då?
Bara 60watt, fast det räcker väl om db är 100 :)
och man kan dela lite högre kanske..
ojoj, fast de är lätta att förstöra står det
n/a
deleted
Posted - 2002/11/14 :  15:04:55  Show Profile Send n/a a Private Message
Hej NN!
Om man ställer 2st R1:or för nära varandra så kan det säga...
Pang!!( och sedan Aj, aj,,!!( A vet( av egen erfarenhet, ed ;)))
Mvh A*.
Niklas Nord
Posted - 2002/11/14 :  15:08:42  Show Profile Send Niklas Nord a Private Message
jasså du har testat.. raven.,.,
det måste du skriva ihop nått litet
om tycker jag
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  15:15:21  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Originally posted by Audiomaniker
Hej NN!
Jag vet en som bygger Line-Array med R2'or han har inte nämnt något problem...
Eller menar du att dom av magnetstyrkan smackar ihop i varandra?
Mvh A*.
Niklas Nord
Posted - 2002/11/14 :  15:19:34  Show Profile Send Niklas Nord a Private Message
smackversionen såklart..
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  15:23:37  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Okej, jag skulle inte vilja bli smackad mellan 2st R3'or frågan är hur man komme loss och hur man sen bänder isär ellementen från varandra!
Kofot kanske
n/a
deleted
Posted - 2002/11/14 :  15:46:17  Show Profile Send n/a a Private Message
Jag är mest intresserad av var jag får tag i transformatorn, det övriga ser inte allt för avancerat ut.
Niklas Nord
Posted - 2002/11/14 :  15:49:34  Show Profile Send Niklas Nord a Private Message
dahlberg, skulle du kunna bygga mig två Raven R3.1:or?
Eller kanske 4, eller 6, eller 8st ??
kan du?
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  15:52:21  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Dahlberg, nu har du möjlighet att tjäna rejäla pengar
Om du kan bygga en banddiskant som har rak frekvensgång från 500-40'000Hz!
Då köper jag direkt
norman
Posted - 2002/11/14 :  15:53:05  Show Profile Send norman a Private Message
Linda en egen! mätte precis på min som jag provisoriskt lindade och den går rakt från 300-40000hz utan fasvridningar (nedre gränsen är förståss beroende av hur hög spänning man vill mata in)..det är en vanlig trafokärna jag använt.
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  15:55:09  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
norman, hur hög känslighet?
Minst 100dB/2.83V vill jag ha.
Niklas Nord
Posted - 2002/11/14 :  15:56:14  Show Profile Send Niklas Nord a Private Message
vad snackar ni om, NORMAN, är det verkligen så enkelt?
magneterna kostar juh multum säger Alexi, och de har
rätt stor kraft i sig.
kan man verkligen göra sådanna hära själv? OM det går så
skulle jag bygga själv istället för att köpa Newform
bandare för många 10 000:- tals tusenlappar..
Kan ni inte sätta ihop lite bilder, ritningar osv..
så kan jag lägga upp en sida på min server..
HUR MAN GÖR,, dahlberg och norman, vill ni det? visa
oss dödliga, lite plotts..
norman
Posted - 2002/11/14 :  15:59:18  Show Profile Send norman a Private Message
nu pratade jag bara om trafon när jag nämnde frekvensgången.. min diskant är inte så bra.. ännu.. vet inte vilken känslighet min har.. men det går ju alltid att fixa många db/v om man får ha låg impedans.. men jag antar att du vill ha runt 4-8ohm?..
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  16:01:22  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Ja hm 100dB/1w 8ohm då. Det ger R3.1 och ESg1 ger 102dB fast från 900Hz.
norman
Posted - 2002/11/14 :  16:08:11  Show Profile Send norman a Private Message
mitt lilla projekt ligger nog på kanske 85db/w 8ohm om jag får gissa, den är iaf lägre än gammadiskanterna jag har. Men jag har inte alls optimerat magneterna och gapet, slängde mest ihop en för att kolla lite om det är möjligt att bygga en själv..
norman
Posted - 2002/11/14 :  16:10:48  Show Profile Send norman a Private Message
Magneterna fixar man gratis från skrotade radaranläggningar..
Skall du bygga en lång en skall du nog fråga dahlberg, då kan man ju slippa trafo också.
Niklas Nord
Posted - 2002/11/14 :  16:12:12  Show Profile Send Niklas Nord a Private Message
vart hämtar jag en gammal radar?
norman
Posted - 2002/11/14 :  16:14:54  Show Profile Send norman a Private Message
Bara att välta en sån där som står och snurrar i skogen... Mina hittade jag på en skrot där dom precis hade skrotat en radar.. vet dock inte hur ofta det händer att man kan hitta sånt.
n/a
deleted
Posted - 2002/11/14 :  16:18:27  Show Profile Send n/a a Private Message
Det jag hade tänkt mig var en ca:170cm lång diskant som bygger på samma typ av magnetsystem. Som jag ser det så är det bara dom två ljusgråa delarna som är av magnetiskt material det mörkgråa är vanligt blötjärn. Skulle det gå att få lite mer utförlig information angående transformatorlindningen att linda egna skall väl också gå att göra. Om man tittar lite närmare på frekvensgången så är dom inte så där jättelinjära trots allt. Dom har samma karakteristiska frekvensgång som alla andra ribbons visar upp. Nämligen dom två plattåerna, det går att få dom i nivå med varandra med ett tyngre membran. Iofs på bekostnad av utsträckningen uppåt i frekvens, men här har man lite att ta av.
Niklas Nord
Posted - 2002/11/14 :  16:24:28  Show Profile Send Niklas Nord a Private Message
blötjärn? okej..
dahlberg, du måste nästan del amed dig av din
kunskap här
Alexi
Ute och cyklar...?
Posted - 2002/11/14 :  16:33:48  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Vad kostar 4st Neodymium Nd-Fe-B permanentmagnet block på 200x50x20mm?
Edited by - Alexi on 2002/11/14 16:45:43
