 Leonardo CD-A9.3
jos
Posted - 2006/01/11 :  08:35:45  Show Profile Send jos a Private Message
Halloj!
Jag har blivit lite intresserad av denna spelare och undrar om det är någon som hört något om den?
Det ska tydligen vara en uppgradering av Original Leonardo 5 Aniversary CD Player, - och alltså inte samma spelare.
Modified PHILIPS VAM12 top loading laser pick up and Philips CD7-II digital servo system for accurate laser pick up and fact track access.
.Two Burr-Brown’s PCM-1792(24Bit/192KHz) as D/A converter.
.True balanced design. Two separate left/right channel D/A converter, filtering and output circuits.
.Two kinds of linear digital filters which can be selected by using of remote control to get two different sound effects.
.Two sets of special designed heavy duty toriod power transformers with sealed metal enclosures supply the power to digital and analog circuit separately.
.Six separate power supplier and voltage regulator circuits supply very stable and clean power through out different circuit blocks.
.Independent power supplier for clock circuit makes clock circuit very stable and improves linear distortion caused by error of source clock.
.Well designed D/A circuit for ultra low noise level.
Original unique GOS digital processing technology.
.Blue LEDs on top and display panel.
.Heavy duty Aluminum alloy top loading plate, body, adjustable feet and remote control.
.One set of balanced XLR output
.One set of single ended RCA output
.One digital coax output
.One optical S/PDIF output
.One power socket
.Output level: <1.9V
.Frequency response: 5Hz~20kHz
.Distortion and noise: 0.0015%(-60dB)
.S/N ratio: >105dB
.Dynamic range: 120dB
.Digital output characteristics: S/PDIF standard
.Power supplier: 220/120VAC±5%, 50/60Hz
.Dimensions (W,H,D):
430 X 130 X 320(MM), 16.9X5.1X12.6(IN)
.Weight: 13.5kg, 29.8lb
http://www.original-cd.com/index-products-a93.htm
Edited by - jos on 2006/04/03 12:27:24
jos
Posted - 2006/01/17 :  12:52:37  Show Profile Send jos a Private Message
Någon som kan säga något om Anniversary-modellen då?
Gustaf
Posted - 2006/01/17 :  12:56:01  Show Profile Send Gustaf a Private Message
http://www.6moons.com/audioreviews/original/original.html
jos
Posted - 2006/01/17 :  21:22:15  Show Profile Send jos a Private Message
Ah! Äntligen!
Tackar!
jos
Posted - 2006/01/17 :  21:56:52  Show Profile Send jos a Private Message
Eller förresten... Den var ju inte klar!
Den som väntar på något gott...
Edited by - jos on 2006/01/17 22:05:47
calle_jr
Reportage-Harry 2006
Posted - 2006/01/18 :  22:31:51  Show Profile  Visit calle_jr's Homepage Send calle_jr a Private Message
Jag hade förmånen att låna Leonardo Anniversary ett par veckor. Det är en mycket fin spelare. Den har en ganska neutral karaktär med en mycket naturtrogen och detaljerad ljudbild. Med rätt matchning (som alltid) skulle jag gärna behålla den. Jag fick ihop det bäst med signalkablar i koppar med min dåvarande elektronik.
Skrev lite om det här: http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=41603
och här: http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=41659&SearchTerms=leonardo
Med sin modesta storlek och den coola designen gör den heller inte bort sig. Den är ännu snyggare i verkligheten.
edit: lade till en länk till
Edited by - calle_jr on 2006/01/18 22:36:08
jos
Posted - 2006/01/20 :  09:27:29  Show Profile Send jos a Private Message
Tackar, men de har jag redan läst...
Jag är grymt sugen på Leonardon. Låter den ok så är den värd pengarna bara för utseendet...
jos
Posted - 2006/01/20 :  09:30:00  Show Profile Send jos a Private Message
Anledningen till att det inte blev någon recension ännu... :
"..The Leonardo is equally gorgeous - for 1/10th the Zanden's coin where other makers give you bent sheet metal instead. In fact, this player looks so good in the flesh -- I'm afraid the photos don't fully convey it -- that I barely care how it'll sound. Obviously, that attitude won't at all do for a review. Give me some time then. I need to recover from the present infatuation with the cosmetic wow factor before I get down to sonic brass tacks. Otherwise I'll be completely besotted and pre-biased by appearance alone. Hot damn. Original!"
jos
Posted - 2006/02/09 :  10:57:56  Show Profile Send jos a Private Message
Ska väl inte säga för mycket men jag tror nog att det blir en Leonardo
Ledzepp
Posted - 2006/02/09 :  11:58:57  Show Profile Send Ledzepp a Private Message
Original har även en intressant integrerad rörstärkare på G...
jos
Posted - 2006/02/09 :  12:41:36  Show Profile Send jos a Private Message
Jo, den passar ju rätt bra för den som har en Original 2008 CD.
Jag vet inte om jag tycker att den är vrålsnygg precis men häftig design helt klar.
jos
Posted - 2006/02/22 :  00:12:09  Show Profile Send jos a Private Message
Då har man världens snyggaste (smaken är ju iofs som baken..) cd
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=48351
Edited by - jos on 2006/02/22 08:17:34
Akkelis Audio
Posted - 2006/03/10 :  20:30:40  Show Profile  Visit Akkelis Audio's Homepage Send Akkelis Audio a Private Message
Några lyssningsintryck, jämförelser med annat?
www.akkelisaudio.com
ArtSound
Posted - 2006/03/10 :  21:07:33  Show Profile  Visit ArtSound's Homepage Send ArtSound a Private Message
Ja Stefan : http://www.6moons.com/audioreviews/original/original.html Her er jo nærmest en sammenligning med "den du ved nok"
Spøg til side: Jeg har ikke lyttet til Original, og skal ikke udtale mig om den
www.artsound.dk
jos
Posted - 2006/03/30 :  12:49:17  Show Profile Send jos a Private Message
Srajan verkade tycka sådär men smaken är väl som baken. Själv är jag ruskigt nöjd, tycker den spelar fantastiskt. Har den stående på SD-kuddar vilket jag inbillade mig förbättrade ljudet något.
Det roligaste för mig själv är att jag för första gången någonsin verkligen hör en rejäl förbättring bara på grund av CD. Har aldrig hört så stor skillnad tidigare. Detta beror iofs delvis på att jag inte lyssnat till så fantastiskt många lite finare spelare. Jag kör den med Xindak FP-Gold strömkabel och FA-1 RCA tillsammans med en Myryad MI120.
Här är en annan recension:
http://www6.head-fi.org/forums/showpost.php?p=1840787&postcount=1
Och här är en ägares synpunkter angående Srajans recension:
"Hi Ping,
Just wanted to relay a little story. After reading Srajan's review, I actually began to wonder if my hearing wasn't failing me. My system is as follows: Atma-Sphere MP1 MKII pre; Atma-Sphere MA2.2 amp; Soundlab A-1 Speaker; Purist Audio Anniversary ICs; Magnan Signature speaker cables; expensive power cords; Original CD player.
After I read the review, I decided to see if I was going crazy or not. I went to a local dealer and asked if I could borrow what he considered to be his best CD player. I ended up with an Audio Research CD3MKII. Hesuggested this over the Consonance Droplet he had in stock as he thought the Audio Research blew it away.
Long story short, I compared the AR with the Original, same cables, power cords, volume settings etc... It took all of about three seconds to determine the winner. The Original absolutely destroyed the AR. In terms of extension on both extremes, midrange purity, soundstaging, imaging, presence, dynamics, transparency etc.. any parameter you could think of, the Original was the better player. I have compared and preferred the Original to the Esoteric DV50, Cary 303/300, Audio Research CD3MKII, Resolution Audio Opus 21 and an Electrocompaniet EMC1. I will admit that it took some tweaking to get the best out of the Original. The first thing I did was set the player on some Titanium cones and pucks. I built a platform using Aurios with a sand filled base on top and a sandwich of sorbothane and a Polycrystal shelf. It is dead, dead quiet and helped the player tremendously. I put an Electraglide Epiphany power cord on the unit and the Purist Audio Dominus IC. I also use a Marigo 3D stabilizer matt, black side up. I can hear some of the brightness that Srajan is referring to but I attribute that to the digital medium. It was much less the the Audio Research in my system. Bottem line is that I think with a few mods, this player could compete with anything I've heard. I haven't had the Zanden or Reimyo or the Emm that everyone is raving about but in the sub 10k price range, I think it's a winner. Sorry to be so long but I did want to share my experience with you. Good luck in the future with this player.
Sincerely,
Rusty Mosher
Edited by - jos on 2006/03/30 12:55:15
Denna sida genererades på 0.51 sekunder. Snitz Forums 2000
