 KnowHow angående Visaton
Niklas Nord
Posted - 2002/09/30 :  17:36:48  Show Profile Send Niklas Nord a Private Message
Visaton har en del intressanta högtalare!
T.ex. denna som heter AL 170 som har en
alu kon.. passa sig seas !!
Dock kurvan ser lite lågmäld ut från 1000 hertz och ned..
fast kanske fin avrullning..
Technical Data:
Nominal power handling 70 Watt
Peak power handling 100 Watt
Nominal impedance 8 Ohm
Frequency response fc - 8000 Hz
Mean sound pressure (nominal) 88 dB (1 W/1 m)
Maximum cone displacement 22 mm
Resonance frequency 38 Hz
Magnetic induction 1,1 Tesla
Magnetic flux 520 µ Weber
Height of front pole-plate 6 mm
Voice coil diameter 2,5 cm
Height of winding 1,8 cm
Cutout diameter 15 cm
Net weight 1,2 kg
D.C. resistance Rdc 5,6 Ohm
Mechanical Q factor Qms 4,47
Electrical Q factor Qes 0,36
Total Q factor Qts 0,34
Equivalent volume Vas 33 l
Effective piston area Sd 133 cm2
Dynamically moved mass mmd 13 g
Force factor Bxl 6,93 T · m
Inductance of the voice coil 0,91 mH
Niklas Nord
Posted - 2002/09/30 :  17:38:45  Show Profile Send Niklas Nord a Private Message
Även AL 130 faktiskt
Technical Data:
Nominal power handling 60 Watt
Peak power handling 90 Watt
Mean sound pressure (nominal) 87 dB (1 W/1 m)
Maximum cone displacement 17 mm
Resonance frequency 40 Hz
Magnetic induction 0,95 Tesla
Magnetic flux 450 µ Weber
Cutout diameter 11,5 cm
Net weight 1 kg
Mechanical Q factor Qms 5,19
Electrical Q factor Qes 0,39
Total Q factor Qts 0,36
Equivalent volume Vas 15,6 l
Effective piston area Sd 79 cm2
Dynamically moved mass mmd 8,8 g
Force factor Bxl 5,64 T · m
Inductance of the voice coil 0,67 mH
Niklas Nord
Posted - 2002/09/30 :  17:40:50  Show Profile Send Niklas Nord a Private Message
Är denna bra tro.. Ser GRYM, och visaton,
har inte ett av de bästa labben i världen
för högtalarforskning???
Technical Data:
Nominal power handling 40 Watt
Peak power handling 60 Watt
Mean sound pressure (nominal) 86 dB
(1 W/1 m)
Maximum cone displacement 4,5 mm
Resonance frequency 62 Hz
Magnetic induction 1,2 Tesla
Magnetic flux 300 µ Weber
Height of front pole-plate 4 mm
Voice coil diameter 20 mm
Height of winding 8,5 mm
Cutout diameter 101 mm
Net weight 1,05 kg
D.C. resistance Rdc 6,0 Ohm
Mechanical Q factor Qms 7,05
Electrical Q factor Qes 0,40
Total Q factor Qts 0,38
Equivalent volume Vas 6,92 l
Effective piston area Sd 54 cm2
Dynamically moved mass mmd 4 g
Force factor Bxl 4,8 T m
Inductance of the voice coil 0,7 mH
celef
sirap i datorn
Posted - 2002/09/30 :  18:31:15  Show Profile Send celef a Private Message
Den senare har varit uppe för diskusion tidigare, IÖ berättade om bassvaget och att den lämpade sig bäst för tysk marschmusik!? Dock är elementet mkt populär bland tyska byggare (bäst test i Klang&Ton).
sound pollution
Niklas Nord
Posted - 2002/09/30 :  18:46:43  Show Profile Send Niklas Nord a Private Message
läste lite om det, att det finns ett specialfilter för den
drivern som får ala elakheter att försvinna!
men jag undrar jag, är lite skeptisk. samtidigt som
den verkar sjysst på nått sätt..
men jag gillar nog audax bättre..
Nagref
Posted - 2002/09/30 :  20:21:32  Show Profile Send Nagref a Private Message
Ska man vara snäll (!) mot det första elementet så har det en bandbredd (ofiltrerat) på runt 5.3-7kHz!!! (-3dB vill säga). Det andra är sämre... Det sista är rätt oroligt i hela frekvensområdet...
Skulle du inte använda Audax NN??
VD för Acoustic Landscape
Niklas Nord
Posted - 2002/09/30 :  20:35:49  Show Profile Send Niklas Nord a Private Message
ja men jag kollar juh upp alla tänkbara elementtyper..
hur kan du se det av kurvorna, deras bästa användningsområde?
Nagref
Posted - 2002/09/30 :  20:47:14  Show Profile Send Nagref a Private Message
Det kan jag inte se men ur ett strikt tekniskt perspektiv så utgår det användbara området från där man har den högsta punkten men det betyder inte betyda att det är där man måste utgå ifrån.
Om distorsionen från element två (så att den inte exiterar resonansen) i raden är låg så misstänker jag att det är lämpligast för dig att använda med ett aktivt brant filter.
Niklas Nord
Posted - 2002/09/30 :  20:58:26  Show Profile Send Niklas Nord a Private Message
Nagref
Posted - 2002/09/30 :  21:07:52  Show Profile Send Nagref a Private Message
????Vilket????
Björn N
Fd. Speakerpro
Posted - 2002/10/01 :  12:43:43  Show Profile Send Björn N a Private Message
Monacor SPH-102 Kep spelar rakt upp till 10 KHz !
Optimist. punkt slut.
