 Edwards Audio TT1
Audiovector
Posted - 2014/04/16 :  22:40:29  Show Profile  Visit Audiovector's Homepage Send Audiovector a Private Message  Reply
Var tror ni om denna spelare?
Edwards Audio TT1
Prisad brittisk manuell skivspelare.
Edwards Audio har tweakat till denna spelare så bra att den vunnit What HiFi Awards!
HiFi Choice sa följande: "I can say this with confidence#8230;having compared [TT1] to its competitors, this deck offers quite remarkable performance for its price. It is very involving#8230;with great weight and scale and retains an astonishingly uncolored mid-band, with open high frequencies. It is very quiet even with old and frequently played albums. It further surprises by producing a stable, solid soundstage with [good] front-to-back depth#8230; In short, the TT1 communicates music's fundamentals and more with great conviction and ease#8230; It has a wonderful overall balance of attributes that make it exceptionally easy to enjoy and appreciate. [These exclusive] Edwards Audio modifications help it climb a rung or two further up the performance ladder."
Här hittar man bl a en 12 mm tjock akryltallrik (bilderna visar fel veresion), keramiskt lagring, MDF-plint, Little belter (blå referens rem).
Den finns med och utan pickuper i flera varianter. T ex C200 som kostar löst 1500:-.
Man kan även få den med valfri Sumiko eller Ortofon pickup - 5 % på pickup-priset.
EA202 tonarm (bl a bättre tonarmskablar)
Lock
MDF-Plint
Keramiskt lagring
12 mm akryltallrik
Little Belter
33 & 45 varv (flytta rem på trissa)
http://www.hifi-punkten.se/info.asp?ID=7101
Posted - 2014/04/17 :  07:17:55  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
VeteranHiFi har en exakt sådan för 2.500 om du är nyfiken. Slå Mirre en pling!
Vh micke
Posted - 2014/04/17 :  10:12:01  Show Profile Send Bubbel a Private Message  Reply
En Rega är alltid en Rega oavsett vad som görs med den!
Anders
Audiovector
Posted - 2014/04/19 :  11:04:05  Show Profile  Visit Audiovector's Homepage Send Audiovector a Private Message  Reply
Ingen som lyssnat på den?
RobertH
Posted - 2014/04/23 :  20:08:44  Show Profile Send RobertH a Private Message  Reply
Verkar ju vara en "pimpad" rega rp2, så den lär precis som bubbel skrivit; låta som en rega. Är ju inte så att det är några enorma skillnader.
Gillar du regaljudet så är det bara handla.
Wilson Benesch ACT Two | Pass B1-Buffer | Pass Labs X250 | Opera Reference 2.2 MkIII CD | Clearaudio Evolution Magnum | Lyra Kleos/Sumiko Palo Santos Presentation | Tom Evans Microgroove Plus X RIAA
Audiovector
Posted - 2014/04/30 :  09:38:06  Show Profile  Visit Audiovector's Homepage Send Audiovector a Private Message  Reply
Tack! Blev dock en Pro-Ject Debut Carbon Esprit DC!
