 Benz Micro Ace "S"
Posted - 2009/07/19 :  12:24:35  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
Nån som hört någon av dessa? (Finns liksom den gamle i Low, Medium och High)
Skall tillämpa en hel del teknik från de dyrare Benz:arna samt en Fritz Gyger S-slipning av nålen.
Har beställt en men inte fått den ännu...
MVH /Micke
Adagio
Harry-vinnare 2004
Posted - 2009/07/19 :  16:07:06  Show Profile Send Adagio a Private Message  Reply
Jag tror att samtliga nålslipningar från ACE och uppåt numera är "S".
MVH Jocke
Posted - 2009/07/19 :  17:26:38  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
Njae, den finns fortfarande att köpa i standardutförandet...
Däremot är det möjligt att de dyrare har den slipningen även sedan tidigare.
The S Class models ACE SL, SM, SH all incorporate the Benz Dynascan with Gyger S stylus coupled to improved generators using new coil windings and refined pole pieces/damper designs. Albert Lukaschek began researching increased performance and uniformity of his crosscoil designs while developing the Benz Ebony H, L and TR models. Experimenting with the length of the solid Boron cantilever revealed how the elasticity of this very stiff material contributed to compliance and trackability. Development of a grooved rear pole piece for countersinking the o-ring damper, first introduced on the Benz Ruby square plate cartridges, was then adapted to the cross coil designs, given their lower contact area and damping characteristics. The lower mass coils and matched cantilevers of the new S Class retain their real world output levels and with their improved styli, offer higher performance. Music lovers are getting the best performance/value ratio in phono cartridges, regardless of output level.
http://www.musicalsurroundings.com/benz.html
"The ACE SL produced solid, well-defined, yet delicate images within a world-class-wide soundstage of reasonable depth. Its resolution of ambient cues and inner detail were astonishing for $700. Its tonal balance combined lower-midrange warmth, reasonably good bottom-end extension, good top-end extension and detail, and a slight reticence in the transition from the upper mids to the treble that produced a relaxed, very pleasing, yet detailed sonic picture. There were no standout colorations, hard edges, or grain." - Michael Fremer, Stereophile June 2009
http://www.elusivedisc.com/prodinfo.asp?number=BENZACEL
MVH /Micke
Edit: Syftningsfel
Edited by - AlfaGTV on 2009/07/19 17:27:12
Posted - 2009/07/21 :  21:22:44  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
Nu sitter den där!!!
Och den låter redan MYCKET bra!
MVH /Micke
24U
Posted - 2009/07/25 :  17:55:55  Show Profile Send 24U a Private Message  Reply
Ser mycket, mycket trevligt ut AlfaGTV! Passar bättre på den armen rent estetiskt än min ACE på min SME 3009R. Kan tänka det låter bra också med den spelaren! Grattis!
Gozzi
Posted - 2009/09/19 :  13:58:45  Show Profile Send Gozzi a Private Message  Reply
Stiliga bilder, grym spelare !
[i][purple]
Posted - 2009/09/20 :  20:39:37  Show Profile  Visit AlfaGTV's Homepage Send AlfaGTV a Private Message  Reply
Tackar Gozzi!
Bilderna är faktiskt tagna med mobbe! ;)
Jag är också supernöjd med ljudet ifrån denna kombination även om jag inser att det finns förbättringspotential.
Siktar på en Lingo och ett Cirkus-kit framöver, men pickupen kommer inte att bytas i första taget!
MVH /Micke
