 Hjälp mig att tolka texten.
Gubben i Kalmar
200.000 klubben
Posted - 2008/03/16 :  22:46:53  Show Profile Send Gubben i Kalmar a Private Message  Reply
Hej igen!
Nu sitter jag med "skägget i brevlådan".
Jag är ingen elektonikingenjör och en franskman har skrivit den engelska texten.
Kan någon förklara nedan text hämtad på http://www.vinylengine.com/step-ups-and-mc-cartridges.shtml
Det beskriver hur man anpassar en MC-puppa till ingången på antingen en tranformator eller en akivt förstärkarsteg.
Han beskriver en "regel" som går ut på att ändra belastningen på MC-puppan i tre steg.
Syftar han på ett motstånd paralellt mellan MC:n och transformatorn?
Gäller denna "regel" både transformator och aktiv förstärkar stegsteg?
So please, don#8217;t contact me to insult me about my rule!
For this rule, we#8217;ll use a spec given by the manufacturer: the load impedance. We#8217;ll take this load impedance as meaning a load impedance recommended for active transformers (and not for passive devices). This data certainly includes things relavent to important characteristics of the cartridge we don#8217;t know, but that must be considered.
A manufacturer generally gives you a minimum load impedance for active devices (or a range, but it#8217;s less common).
If the load impedance (for active devices) is said to be > or equal to 20 ohms, the internal impedance is 3 ohms, you should try to load your cartridge at load impedances between:
the load impedance given by the manufacturer (20 ohms)
the load impedance given by the manufacturer + 10*internal impedance (50 ohms)
Now, for a 40 ohms internal impedance cartridge with load impedance for active devices of 100 ohms, you should try load impedances between 100 and 500 ohms. If your system is too bright (suppose you#8217;re having triangle loudspeakers#8230;), you will certainly be happy with something that will #8220;cool down#8221; your sound, so try something close to 100 ohms. On the contrary, you may be happier with something closer to 500 ohms.
Now, my opinion: I never hear satisfactory results when the load impedance on a passive device is equal to the load impedance indicated by the manufacturer (we understand as load impedance on an active device). You#8217;ll try and you#8217;ll tell me. We#8217;ll see later the way to test different load impedances but you don#8217;t need to test 100 values between 100 and 500 ohms : something like 3 or 4 value is enough and in our case, you could try 100 ohms (and you#8217;ll tell me), 200 ohms, 300 ohms and 470 ohms (with a 1:10 transformer).
If the manufacturer is proposing a range of load impedance (say between 20 and 200 ohms), follow that range by testing say, 50 ohms, 100 ohms and 150 ohms.
Do you think things are over? No, they aren#8217;t! The load impedance is an important thing BUT it#8217;s only the first important thing to consider. Remember that the natural impedance is directly linked to the gain of your step-up.
Vänligen
Gubben i Kalmar
Tommy Björklund
fam_bjorklund@msn.com
tkr
Posted - 2008/03/17 :  09:37:55  Show Profile Send tkr a Private Message  Reply
Hei,
Der er strengt tatt ikke puen som blir tilpasset, men derimot RIAAen.
På en RIAA med mm-inngang, vil denne være bygget slik at pu "ser" en impedanse på 47 kOhm.
En MC-pu vil helst "se" en impedanse fra 50-500 Ohm, da låter den best. Jeg har selv forsøkt å tweake lyden ac min MC-pu ved å stille på impedansen. Det er ,ærlig talt, små forskjeller å høre, men de er der.
Hvis du kopler inn en stepup, vil denne forandre den impedansen som puen ser. Såvidt jeg vet gjelder følgende:
En stepup vil forandre den impedansen er pu "ser" med kvadratet av forsterkningen.
M.a.o. vil en stepup som forsterker signalet 10x føre til at puen "ser" en impedans på 1/100 av den opprinnelige impedansen i RIAA . (R / 10*2)
Musica, dona vobis pacem
Edited by - tkr on 2008/03/17 09:41:20
Gubben i Kalmar
200.000 klubben
Posted - 2008/03/17 :  16:35:44  Show Profile Send Gubben i Kalmar a Private Message  Reply
Tack tkr!
Men jag är inte säker på att jag har förstått allt riktigt.
Titta på nedan text:
Menas detta att man kan öka den "recomended load impedance" på puen, genom att koppla en resistor (motstånd) i serie mellan MC puen och stepup?
Vänligen
Gubben i Kalmar
Tommy Björklund
Jamo
Posted - 2008/03/17 :  17:12:16  Show Profile Send Jamo a Private Message  Reply
I denna artikel: http://www.hagtech.com/loading.html
står i slutet under step-up transformers:
What resistor should you put in parallel with the 47k phonostage to change the loading to a desired value? Artikeln rekommenderar alltså att lägga motstånden parallellt över MM-ingången på förförstärkaren (eller utgången av step-upen). Vid en snabb eftertanke borde det väl även gå att lägga motstånden parallellt över step-upens ingångssida, men det är kanske god praxis att jobba på "högspänningssidan".
Hälsningar Jamo
Gubben i Kalmar
200.000 klubben
Posted - 2008/03/17 :  18:51:49  Show Profile Send Gubben i Kalmar a Private Message  Reply
Ahaaaaaaaa!
Nu tror jag "tjugofemöringen" trilla ner.
Det franskmannen Seb vill ha sagt är att man räknar fram en önskad belastnings impedans för Mc puppan.
Inte som jag trodde, ett spänningsjusterande resistor. Spänningsjusteringen görs i andra änden,mellan tranformatorn och MM-ingången.
Tack tkr och Jamo för Ert tålamod.
Tommy Björklund
tkr
Posted - 2008/03/17 :  21:37:57  Show Profile Send tkr a Private Message  Reply
Hei,
Den resistoren må iallfall parallellkoples, ikke seriekoples!
Det gjenstår å si en ting:
Den eneste måten å finne ut om praksis stemmer med teorien, er å lytte. Det er nok klokt å prøve ut med forskjellige verdier på den resistoren.
Edited by - tkr on 2008/03/17 21:39:07
Gubben i Kalmar
200.000 klubben
Posted - 2008/03/17 :  22:36:18  Show Profile Send Gubben i Kalmar a Private Message  Reply
Ja, jag ska ta Dina synpunkter till mig, tkr.
Tommy Björklund
