 High-End Nyheter
Page: of 45
cybwiz
800.000-klubben
Posted - 2008/04/21 :  15:36:29  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Se test av Chalice Audio The Grail
http://www.positive-feedback.com/Issue36/chalice_grail.htm
http://cybwiz.blogspot.com/
cybwiz
800.000-klubben
Posted - 2008/04/21 :  20:12:54  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Thesis Audio Amalthea fra Italia - ¤6680
Edited by - cybwiz on 2009/10/30 05:31:53
cybwiz
800.000-klubben
Posted - 2008/04/29 :  15:18:18  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
PIEGA CL120X
In the middle of 2008, PIEGA's new CL 120 X will make its market debut.
The CL 120 X feature two-piece assembly with a 22 cm MOM bass chassis to provide for the deep groove and the large C1 coaxial ribbon system (also used in legendary C 40).
It's sure to lift your listening experience to musical high-altitude musical flights.
The extra strenghtened cabin is a steady rock on both whispering levels and howling tornadoes.
The CL 120 X will be available in aluminum silver, black anodized aluminum and piano lacquer finishes.
Edited by - cybwiz on 2009/10/30 05:32:37
cybwiz
800.000-klubben
Posted - 2008/04/30 :  01:37:12  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Stereotimes har testet Behold Gentle
Den låt utrolig bra på High End 2008
http://www.stereotimes.com/amp042908.shtml
Edited by - cybwiz on 2008/05/03 18:49:43
pederb
Posted - 2008/05/06 :  23:02:52  Show Profile  Visit pederb's Homepage Send pederb a Private Message  Reply
Ny Preamp från Pathos Acoustics.
Synapse
Two stage preamplifier, zero feedback, entirely bi-monoaural with dual power supply, dual line stage, dual control signals, dual grounding, entirely optocoupled digital signal controls with separate grounding, hybrid differential line stages with dual transistor, triodes and mosfet, direct coupling class A
Synapse
Key specs and features
inputs:3 balanced XLR, 3 single ended RCA,
outputs:2 main balanced XLR, 1 tape out
frequency response : 1Hz .. 100KHz (200KHz @-3dB)
THD : 0,04% @ 4 Vrms
Volume control : 0,5 dB - 168 steps
http://www.pathosacoustics.com
Peder Bäckman
AVM Audio Video Manufaktur
Edited by - pederb on 2008/05/06 23:03:45
cybwiz
800.000-klubben
Posted - 2008/05/07 :  15:01:27  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Playback Designs MPS 5 - $15000
Having had a long term relationship with EMM Labs, we certainly know good digital playback when we hear it. Imagine our suprise when we heard the $24,500.00 EMM Labs DCC2eSE / CDSD-SE state of the art combination compared directly against the $15,000 Playback Designs MPS 5 and our jaws dropped. The difference was truly a revelation. There was no hint of the digital glare and hashiness that one comes to expect from digital playback. It just sounded natural. The musicality, dynamics and frequency extension were unlike anything we had ever experienced from CD's or SACD's.
We have had players and DACs in every configuration you could imagine, tube output stages, etc. and the Playback Designs gives you everything you would ever want with the highest level of clarity that other players cannot approach. We are not suggesting that you blindly order a unit from your dealer. We are suggesting that the Playback Designs MPS 5 needs to be heard before spending your money on lessor equipment.
Playback Designs and Blue Light Audio proudly offer the newest line of Playback Designs products designed specifically for the home "audiophile." Many of the recordings you will listen to where actually created using Playback Designs technology!
Edited by - cybwiz on 2008/06/06 15:13:34
cybwiz
800.000-klubben
Posted - 2008/05/10 :  16:59:18  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Bergmann Audio Sindre - 57000,- DK
http://bergmannaudio.com/
Edited by - cybwiz on 2008/05/10 16:59:55
cybwiz
800.000-klubben
Posted - 2008/05/12 :  17:57:34  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Odiaze ZQ31D - ¤12000
cybwiz
800.000-klubben
Posted - 2008/05/22 :  06:13:50  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Spectron Audio Musician III Signature Edition Mk2 - $7200
Features
· Digital pulse width modulation switching amplifier.
· Feedback loop 10 times faster than typical conventional amplifiers.
· Staggering headroom of 3500 volt-amps over 500 msec.
· No crossover distortion.
· Drives the most difficult speakers, stable to .1 Ohms.
· Foldback current limit. Automatic overload recovery.
· Professional quality balanced line input.
· Phase invert. Rear panel selectable.
· Accepts either XLR or RCA input: True balanced line.
· In-rush resistor bypass. More and tighter bass.
· Isolated low level power supplies. Eliminates noise from AC line in low level circuits.
· Speaker protection. Turns amp off for excessive DC or high frequency.
· High efficiency for minimal power consumption.
Technical Specifications
· Power Watts per channel, both channels driven
600 Watts at 8 Ohms
800 Watts at 4 Ohms
1400 Watts at 2 Ohms
· THD <.03% from 1W to 600W @ 8#937; ( in the listening range)
<.06% from 1W to 600W @ 8#937; ( > 22 kHz)
· Noise <180 µV (22 Hz to 22 kHz)
-83 dB below one Watt (A measure of hiss)
· SNR 115 dB
· Frequency response ±.1 dB 20 Hz to 20 kHz at 8 Ohms
· Bandwidth 100 kHz
Power Supply Voltage + 120 VDC
· Input impedance RCA: 50 kOhms, XLR: 50 kOhms
· Output impedance @ 1kHz .018 Ohms
· Output impedance @ 20kHz .095 Ohms
· Damping ratio 500:1
Gain 26db (20v/v)
· Efficiency >92% (Amp module)
· Line voltage 100, 120 or 240 VAC 50/60 Hz Switch selectable
· Power draw, no signal 40 Watts
· Weight 52 lbs, Shipping: 64 lbs or 28 kg
· Size 431 mm wide x 133 mm high x 368 mm deep
(17"W x 5¼"H x 14"D)
Edited by - cybwiz on 2009/10/30 05:36:27
cybwiz
800.000-klubben
Posted - 2008/06/02 :  08:48:00  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Thorens Jubilee - ¤35000
Universal, heavily dampened analogue turntable designed between subchassis and mass principles incorporating four independent 'levels of operation'
Two independent, exchangeable tonearm platforms whereby the range of usable tonearms is practically unlimited
Fine-adjustment of HTA ( ± 2 angular degrees, ca. 3 kg per platform without tonearm)
Tonearm TP 125 with 10 or 12 inches
Optional non-Thorens tonearms from 9 to 12 inches
Selectable output sockets: RCA or XLR
Split platter with internal belt drive
Outer platter (11.5 kg) has very low centre of gravity through layer construction and is 3-D-balanced in all three axes
Inner platter (1.9 kg) is filled with 200 grams of RDC and meticulously balanced (dynamically and statically)
Four individually adjustable unit feet with integrated new-generation RDC 6s compound
Drive system: Synchronous motor and precision flat belt
Speed control: electronically through external power supply
Speed: 33-1/3, 45 and 78 rpm
Dedicated turntable stand available as an option
Dimensions: Width: 600 mm / Depth: 500 mm / Height: appr. 150 mm without tonearms (depending on levelling) / with tonearms appr. 180 - 200 mm
Weight: 58 kg without tonearms
cybwiz
800.000-klubben
Posted - 2008/06/04 :  18:55:08  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Consensus Statement - ¤78000
Specifications
Speaker Statement
System 4-way Airflow Damping for closed cabinets
Cabinet CAFDCC Consensus Airflow Damping for Closed Cabinets
Resonance optimized plywood materials
Driver Arrangement
1 x 1.2" Ceramic Tweeter
Optional
1 x 1.2" Black Diamond Tweeter
1 x 7" Ceramic Midrange
2 x 7" Ceramic Woofer
3 x 9" Ceramic Woofer
Basket spiders & magnets airflow optimized
(Custom-made by Accuton for CONSENSUS)
Impedance 5 Ohm
Sensitivity 93 dB
Recommended Amp Power 15-500 Watt
Frequency Response 18 Hz#-35 kHz/-3 dB
Single-Wire Terminal WBT Germany Platinum
Crossover Parts CCCS Consensus Coherence Crossover System
Handmade by Consensus.
Crossoverparts exclusive built by
Mundorf Germany for Consensus
Internal Wire CMFC Consensus Magnetic Field Correction.
Spike-System CRT Consensus Resonance Technology
Dimensions (H x W x D) cm 178 x 36 x 62 cm
Weight (per piece) 120 kg (2pcs80/40kg)
Edited by - cybwiz on 2008/06/04 19:12:34
cybwiz
800.000-klubben
Posted - 2008/06/07 :  09:31:06  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Oblivion Technology
Nye norske super kabler designet av Raymond Celius
Oblivion Technology audio kabler lages av de beste utvalgte materialer av kobber, sølv og PTFE (TeflonTM). Det brukes en avansert mekanisk konstruksjon for å oppnå de minst mulige lydmessige påvirkninger.
Med kabler fra Oblivion Technology vil du oppleve en naturtrohet og dynamikk som sannsynligvis svært få andre kabler kan gjengi.
Alle priser i NOK
Digitalkabel/RCA
Pris: kr. 4250 for første meter,
deretter 3000 pr. meter
Digitalkabel/XLR
Pris: kr. 4000 for første meter,
Interconnect/RCA
Pris: kr. 8500 for første 1 meters par,
deretter kr. 6000 for hver ekstra meter
Interconnect/XLR
Pris: kr. 8000 for første 1 meters par,
Høyttalerkabel
deretter 6000 for hver ekstra meter
Strømkabel
Platespillerkabel(SME)
Pris: kr. 5000 for første 1 meter,
Jumper
Pris: kr. 2500 pr. par
Edited by - cybwiz on 2008/06/07 09:31:41
cybwiz
800.000-klubben
Posted - 2008/06/17 :  18:04:24  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Tidal Sunray T1
¤211.000 Piano black
¤230.000 Bubinga, Tyger Eucalyptus
¤236.000 African Pyramid Mahogany, Ebony Macasar
The TIDAL T1-LPX.
An active crossover without any compromises - based on our reference pre amplifier "Preos"
http://www.tidal-audio.de/english/t1.htm
Edited by - cybwiz on 2008/07/08 14:52:18
cybwiz
800.000-klubben
Posted - 2008/06/21 :  09:46:44  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Goldmund Metis 10
INPUTS
3 analog 2-channelinputs
2 digital inputs RCA (up to 96 kHz)
2 digital inputs optical toslink (up to 96 kHz)
1 digital input USB (up to 48 kHz pcm Stereo only)
The audio format supported are :
pcm 44.1kHz to 96kHz
Dolby Digital
DTS
DTS-CD
DIGITAL OUTPUTS
8 digital RCA SPDIF outputs specially made to connect
Metis / Metis Sub speakers.
Front panel and remote-control adjustable level control with
65dB range and 0.05dB accuracy in the 0-> -34dB range.
POWER SPPLY
1 separate transformers
6 separately regulated power supplies
Nominal AC line voltage : 117V or 240V
Input voltage range : +/ - 15%
Maximum power consumption : 8W
Fuse : 100mA / 250v (slow-blow)
SIZE AND WEIGHT
Size : 37cm L(14.57') × 30cm W(11.81') × 6cm H(2.36')
Weight : 7kg(15.43lb)
Edited by - cybwiz on 2009/03/26 16:57:01
U1
Posted - 2008/06/21 :  11:18:31  Show Profile Send U1 a Private Message  Reply
Oblivion Technology
Var det inte han med grendosan
cybwiz
800.000-klubben
Posted - 2008/06/28 :  18:02:23  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Evolution Acoustics
MMOne
Mini One
Mini Two
Mini Sub
cybwiz
800.000-klubben
Posted - 2008/07/07 :  19:30:22  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
KRELL SACD MKIII - $6000
MasterChief
Posted - 2008/07/08 :  20:13:53  Show Profile Send MasterChief a Private Message  Reply
MBL:s senaste referenshögtalare levereras till en av sina första kunder:
http://forums.avguide.com/viewtopic.php?t=4087
Edited by - MasterChief on 2008/07/08 20:14:50
cybwiz
800.000-klubben
Posted - 2008/07/08 :  20:28:09  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
TIDAL Impact Monobloc
Reference single monaural amplifier.
TIDAL Impact Monobloc is not just an internally simple bridged version of our Impact stereo power amplifier - it is much more.
Based on the technology we use inside of the Impact, the key to its unique performance for away of discussions between solid state and tube philosophies, it drives this concept here to its limit.
Instead of using here inside two channels we use one side for a controlled 1600 VA power supply with gigantic reserves to drive the Impact amplification board with the most stable and clean power even further.
This creates 60% more power, but this was not the point: it just plays even more relaxed, controlled and holographic then the stereo version.
single mono reference power amplifier
controlled power supply with 2 x 800VA non-noise toriod transformers, magnetical shielded and mechanical decoupled
240 000µF stabilisation capacity, ultra fast response with high-grade-long-life-capacitors
elimination of deleterious resonances by massive aluminum braces inside, excellent torsional and longitudinal rigidity
no protection circuit in signal path, no relay in exit path
intelligent protection system with: DC-offset-control, power supply control, temperature control, overload control
intelligent softstart system
extremly short signal paths on gold plated boards, DC-coupled input stage
EMI-linefilter
user-selectable input: 2 x balanced input XLR (gold plated), 2 x unbalanced (RCA-jack gold plated and teflon isolated)
stable under 1 ohms
rated power output at 8 ohms: 1 x 210 watts continuous rms power
rated power output at 4 ohms: 1 x 400 watts continuous rms power
rated power output at 2 ohms: 1 x 750 watts continuous rms power
rated power output at 1 ohms: 1 x 1.200 watts continuous rms power
Input impedance
unbalanced mode = 26kOhm
balanced mode = 2kOhm
voltage gain: 25 dB
bandwith: 1Hz - 250 kHz (-3 dB)
distorsion: < 0.007%
noise: 100 dB
slew rate: 50 V / µs
damping factor: >400 / 100 Hz and >400 / 10 kHz referenced to 8 ohms
dimensions: 17.3" x 8" x 17,3" / 44 cm x 20 cm x 40 cm
weight: 140 lbs. / 70 Kg incl. packaging
Edited by - cybwiz on 2008/10/17 19:15:26
pederb
Posted - 2008/07/10 :  18:43:28  Show Profile  Visit pederb's Homepage Send pederb a Private Message  Reply
Jonathan Valin är Stereophiles reviewer och inte en kund, han har dom bara som lån för att göra en review.
Peder Bäckman
Edited by - pederb on 2008/07/10 18:51:01
cybwiz
800.000-klubben
Posted - 2008/07/10 :  19:47:04  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Kuzma
Nye tonearmer
4Point - £3790
Stogi Reference 313VTA 12" - £1990
Edited by - cybwiz on 2008/07/10 19:47:20
cybwiz
800.000-klubben
Posted - 2008/07/10 :  19:55:50  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Rogue Audio Apollo - $10000 pr
Kommer også som Reference til $18000 pr
- Output power: 250 WPC
- THD: less than 0.1% typical, 1% at peak
- frequency response:
- 20Hz -25KHz at full output, 10Hz -100KHz at 10 watts
- Input sensitivity: 1.0V RMS
- Dimensions: 9.5" W x 24" D x 12" H
- Weight: 100 lbs each
Edited by - cybwiz on 2008/07/10 19:56:55
cybwiz
800.000-klubben
Posted - 2008/07/10 :  21:26:24  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
TIDAL Contriva Diacera SE - ¤50000
SE har innebygd delefilteret fra toppmodellen T1.
ca 10kg delefilter
Intern kabling - Argento Serenity-Master-Reference
Edited by - cybwiz on 2008/07/10 21:34:06
cybwiz
800.000-klubben
Posted - 2008/07/10 :  22:55:17  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
STEALTH Dream Petite
Suggested retail price is $5,500 for a 2 meter pair, and $2,200 for each consecutive meter.
(1.5m and shorter pair of Dream Petite speaker cables is $4,800)
cybwiz
800.000-klubben
Posted - 2008/07/19 :  22:21:25  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
audio research DAC7 - $3500
Front panel functions include Power, Mute, Invert, and Input Select.
LED to indicate when the selected input has a digital lock.
Remote control of Power, Mute, Invert, Input Selection plus Play/Pause, Stop, Track Up and Track Down as part of the USB protocol.
Fully balanced solid state design, utilizing a new direct coupled FET output stage and massive regulated power supplies with seven stages of regulation.
Separate audio and digital power transformers are mounted to boards made of the same material as ARC Reference products.
The Burr-Brown DAC is 24/192 capable and utilizes passive I/V conversion for best sonics.
Same chassis as the SP17.
Page: of 45 Previous Topic Topic Next Topic
