 41hz.com AMP5 *den fungerar*
Borgaren
Posted - 2006/02/10 :  21:08:49  Show Profile Send Borgaren a Private Message  Reply
Jag skall beställa ett amp5 kit, blir det alltså för mkt med 24v om man skall ha bryggat och köra 4ohm? Det har inte framgått på hemsidan :(
Intresse motiverar lärande
Daniel Ekström
Posted - 2006/02/11 :  12:29:08  Show Profile Send Daniel Ekström a Private Message  Reply
Så här står det i instruktionen ang. transformator:
The TA2022 chip in AMP5 requires a dual rail power supply plus a stabilized +5V 100 mA supply. The rail voltages could be +/-20V to +/-35V. Higher voltage gives a higher possible maximum power output. The limitations are about +/-35V upper limit voltage and the chip has an internal current limiting set at about 7.5A. With 4 ohm speakers or 8 ohm bridged mono, +/- 31V is the maximum recommended by Tripath, to avoid tripping the over-current shutdown at high power. With 8 ohm loads, +/- 35V can be used without tripping the overcurrent limit. Toroid transformers are available with standard values. Nominal voltages of +/- 18VAC to +/-24VAC are common. When rectified, this will give about +/-24VDC to +/-33VDC. Note that transformer voltages are given for full rated power. At low power, the voltage will be slightly higher. For maximum power into 4 ohms, a 2x22VAC transformer would be about ideal, while for 8 ohms, 2X24V would be about the maximum.
The VA (power) rating depends on the voltage rating and the load impedance. At the upper end, with a +/-24VAC transformer (which is slightly high as seen above) and 4 ohms speaker load or a 8 ohm bridged load, a VA rating of 300 VA(#8776;300Watt), or even more, is reasonable, while a with +/-18VAC transformer and 8 ohm loads, as low as 80 VA may be sufficient.
Generally, the higher transformer VA rating, the better, as it is more stable, “stiffer”, and runs cooler. The only drawbacks are price, size and weight. But there may not be mush advantage going to very high VA values.
/Daniel Ekström
Bygger Klass T
Min anläggning http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=46354
Edited by - Daniel Ekström on 2006/02/11 12:29:35
Daniel Ekström
Posted - 2006/02/13 :  12:58:33  Show Profile Send Daniel Ekström a Private Message  Reply
Nu är förstärkaren provkörd tillsammans med en Carver förförstärkare. Först tyckte jag att ljudet var lite tråkigt. Men så bytte jag tillbaka till min gamla Denon. Då visade det sig att ljudet från Carver+AMP5 var helt överlägset. Trots full loudness och tonkontrollerna uppställda på Denon så var ljudet plattare och tråkigare.
Fick en känsla av att det var mycket mer detaljer med nya bygget
Det kändes också som att det fanns en hel del kraft i förstärkaren
Ett intressant test vore nu att testa den med betydligt bättre högtalare.
/Daniel Ekström
Bygger Klass T
Joakim F
Posted - 2006/02/13 :  18:02:39  Show Profile Send Joakim F a Private Message  Reply
Kul att höra Daniel!
Man blir allt mer sugen på att beställa sig en byggsats själv.
Ta gärna fler bilder på bygget!
Borgaren
Posted - 2006/02/15 :  16:44:38  Show Profile Send Borgaren a Private Message  Reply
Vad blir "output" om den får 22V och bryggas, lastas med en 4 ohms last?
Funderar på att bygga denna amp till att driva mina subbar, den är ju billagre än hypex och ganska lättbyggd även för en newbie!!
nusse
Posted - 2006/02/15 :  20:14:46  Show Profile Send nusse a Private Message  Reply
Bridged 8 ohms 140W at 0,1% THD+N, 200W at 1% THD+N. Som sagt 8 Ohm.
Här finns mer info: http://www.tripath.com/downloads/TA2022.pdf
nusse
Posted - 2006/02/15 :  20:49:00  Show Profile Send nusse a Private Message  Reply
Min bror fick sitt AMP5kit idag och förhoppningsvis kommer snart trafona från Hypex, så man får lyssna.
Saxat från:http://www.jantzen-audio.com/"
The small value of Cross Coils (0,01 up to 0,05 mH) are the very best solution for Digital Amplifiers.
Undrar om det blir någe bättre, jämfört med att linda själv?
Edited by - nusse on 2006/02/15 20:50:01
Daniel Ekström
Posted - 2006/02/16 :  09:47:47  Show Profile Send Daniel Ekström a Private Message  Reply
Nusse är dom där spolarna från Jantzen är det dom som sitter på utgångarna?
/Daniel Ekström
Bygger Klass T
Borgaren
Posted - 2006/02/16 :  09:53:49  Show Profile Send Borgaren a Private Message  Reply
När jag läser om amp5:an så står det alltid "bridge 8ohm or 4ohm" som
extra krävande, vad innebär det om man tänkt sig att plåga med 4ohms last och amp5 bryggad?
nusse
Posted - 2006/02/16 :  13:19:16  Show Profile Send nusse a Private Message  Reply
Daniel: Jag har bara läst vad det står på 41Hz: http://www.41hz.com/Forums/topic.asp?TOPIC_ID=377 samt kommenteren på på Jantzens hemsida. Mailade Jantzen igår kväll angående tillgänglighet på dessa små spolar och pris. Inget svar än.
Det här kanske är ett problem?
it should be somewhat distanced since it's not as shielded as the toroidal kind.
(saxat från ovannämnda länk).
Lindade de två små toroiderna till min brors AMP5 idag och det var iaf inget större problem. Dock har vi inte mätt upp dem.
nusse
Posted - 2006/02/16 :  20:16:30  Show Profile Send nusse a Private Message  Reply
Min brors bygge: http://pairair.se/album/
Papaman
Posted - 2006/02/16 :  21:33:39  Show Profile Send Papaman a Private Message  Reply
Kul att det är fler som bygger!
Daniel Ekström
Posted - 2006/02/19 :  08:15:12  Show Profile Send Daniel Ekström a Private Message  Reply
Jag försökte mäta induktansen, men hittade inget instrument på jobbbet som kunde mäta så små induktanser
/Daniel Ekström
Bygger Klass T
nusse
Posted - 2006/02/19 :  08:50:33  Show Profile Send nusse a Private Message  Reply
Om det inte var fel på instrumentet min bror testade med så har antagligen de flesta helt fel värde (drygt 15uH).37 varv borde teoretiskt hamna strax under 11uH och 38 en bit över. Toleransen i byggbeskrivningen är 11 +/-1uH. Får väl återkomma med nya mätningar.
Edit: Det verkar som om mätintrumentet mätte fel...
Allt är nog som det ska. Sorry.
Edited by - nusse on 2006/02/20 15:53:53
nusse
Posted - 2006/02/19 :  09:56:53  Show Profile Send nusse a Private Message  Reply
Tror att jag hittat den ev. felorsaken. Kollat på Tripaths egna "Reference/Evaluation Board". De använder mindre ferrittoroider än vad 41Hz gör (T68 vs T80). 44 varv på båda. Hmmm.
DEt skiljer väldigt lite, typ 5% på dessa två typer. Sorry, igen
Edited by - nusse on 2006/02/20 15:56:20
OlaH
Posted - 2006/02/19 :  18:24:42  Show Profile Send OlaH a Private Message  Reply
hej
Har också börjat bygga amp2 och amp5.
trafo till amp5 2x20v 300va köpt hos trimlog,bra pris tror jag.
ola
Daniel Ekström
Posted - 2006/02/19 :  21:14:48  Show Profile Send Daniel Ekström a Private Message  Reply
Wow va kul att det är fler som bygger :D
/Daniel Ekström
Bygger Klass T
Papaman
Posted - 2006/03/01 :  22:45:34  Show Profile Send Papaman a Private Message  Reply
Nu funkar min med, har dock inte fixat nån låda än! kan helt klart rekomendera denna byggsats, första gången jag bygger nått annat än högtalare å det var inga större problem å få ihop!
Mvh.Patrik
nusse
Posted - 2006/03/01 :  23:41:30  Show Profile Send nusse a Private Message  Reply
Kul! Vill också bygga. Borde få mitt "nya" AMP2 kort imorgon.
På tal om låda så har min bror svetsat ihop en i alu http://pairair.se/AMP5/images/CRW_2170.jpg
Han har också antagligen bränt kretsen , men den fun kade en stund iaf. Med lite tur kommer kretsen imorgon...
Papaman
Posted - 2006/03/02 :  12:20:53  Show Profile Send Papaman a Private Message  Reply
Synd att inte AMP2 finns med bara hålmonterade komponenter, hade vart kul med lite mer power men jag tror inte jag fixar ytmonterat!
Denna sida genererades på 0.18 sekunder. Snitz Forums 2000
