 Mcintosh super High-End
cybwiz
800.000-klubben
Posted - 2005/08/13 :  16:40:08  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Mcintosh viste for første gang samlet sitt super high-end anlegg på messa i Hong Kong.
Anlegget besto av C1000 kontroll forsterker, Mc2Kw Effekt, MCD1000/MDA1000 Cd Transport/Dac og Xrt2K høytalere.
Kabling var fra XLO.
C1000
Fra Audiokarma forum
You order the C1000 controller ($7000) with the tube or solid state pre amp section ($8000 ea.). This makes a two box, dual mono preamp for $15K. The preamp section has two phono inputs and one is set for MM and the other moving coil.
They can both have loading and capacitance set from the remote control on the fly.
If you want BOTH tube and solid state you can buy a second pre amp section and have three boxes where the controller/power supply section will let you assign control to any of your inputs and where you want them to be, the tube or solid state section.
No this has not been done before.
The preamps are both fully balanced which is a first for a McIntosh tube pre and the signal to noise ratio is more than 5 Db better than the C200 or C2200.
The distortion is very low and the channel separation is the limit of the test gear, 140 Db.
Øverst på bildet den tredelte C1000 og under Cd Transporten og Dac.
Dac
Mc2Kw 6 chassis Effekt forsterkere til $60000.
Hele anlegget og Xrt2k høytalerene til $80000 paret.
Xrt2k har visst 114 elementer pr høytaler!
Baksiden har nok av innganger.
Det blir omtrent en hel "vegg" med Mc2kw forsterkere skal man koble til alt her.
http://cybwiz.blogspot.com/
Edited by - cybwiz on 2005/08/15 12:17:38
Posted - 2005/08/13 :  16:50:48  Show Profile Send johan.björklund a Private Message  Reply
Jösses !
Beat
Posted - 2005/08/13 :  17:12:47  Show Profile  Visit Beat's Homepage Send Beat a Private Message  Reply
Undrar hur det blitt på mina 20 kvm...
Du når oss på Lazy Boy hær:
sales@lazyboyaudio.no
http://www.lazyboyaudio.no/
thli
Posted - 2005/08/13 :  17:55:52  Show Profile Send thli a Private Message  Reply
Denna mässa var TUNG!!! . Om man kollar igenom mässrapporten så är det en hel del sanslösa system, måste finnas mycket pengar i Asien. Synd att man inte var där
//Thomas
matsj
Posted - 2005/08/13 :  18:02:28  Show Profile Send matsj a Private Message  Reply
Fy F_n vad grymt ,De stegen hade passat mig på alla sätt utom priset . mycket trevliga bilder.
mats
1W=115db.
Wizard
Posted - 2005/08/13 :  18:04:38  Show Profile Send Wizard a Private Message  Reply
Grymt! Men varför kan de inte lära sig att ha vettiga byglingar mellan högtalardelarna, istället för sytråd
Wizard
ohmega
Posted - 2005/08/13 :  20:28:37  Show Profile Send ohmega a Private Message  Reply
Ojj...det var mååånga högtalarelement i dom högtalarna
Posted - 2005/08/13 :  20:35:31  Show Profile Send Circlomanen a Private Message  Reply
McIntosh tillhör samma tunga skara som HD, Klipsch, JBL mfl goa märken.
Vilken dröm att få sätta tänderna i ett par sådana slutsteg!!!!
ILLY
HiFitraktör
Posted - 2005/08/14 :  23:57:48  Show Profile Send ILLY a Private Message  Reply
Jag har läst om den där uppställningen någonstans förut, egentligen är den helt galen. Inte för att mitt sifferminne är det bästa, men jag vill minnas att högtalarna hade en känslighet på en sisådär 114dB/w/m och slutstegen lämnade flera kW totalt. Snacka om dynamisk headroom vid lyssning på normal ljudnivå... Utan tvekan snygga prylar iaf.
Om någon skulle vilja donera anläggningen på bilden till mej så skulle jag bli jätteglad, skicka PM isåfall.
Militant cyklist.
Cyber
Posted - 2005/08/15 :  00:57:38  Show Profile Send Cyber a Private Message  Reply
En "grym" uppställning av HiFi-godis
/Cyber
Jax
Posted - 2005/08/15 :  12:29:13  Show Profile  Visit Jax's Homepage Send Jax a Private Message  Reply
Intressant... servern bilderna ligger på är klassad som porrsajt enligt jobbets brandvägg.
Får kolla hemma sen.
/Janne
Posted - 2005/08/15 :  13:08:45  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message  Reply
Jax: Lite porrigt är det ju också.
cybwiz
800.000-klubben
Posted - 2005/09/19 :  02:10:33  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message  Reply
Systemet ble vist på Cedia 2005
http://www.mcintoshlabs.com/data/Trade%20Shows/CEDIA.Web.Report.pdf
Info om komponentene
http://www.mcintoshlabs.com/data/brochures/C1000.pdf
http://www.mcintoshlabs.com/data/brochures/MC2KW.pdf
http://www.mcintoshlabs.com/data/brochures/XRT2K.pdf
christopher
Posted - 2005/09/19 :  09:38:42  Show Profile Send christopher a Private Message  Reply
känslighet på en sisådär 114dB/w/m låter väll högt för en sådan konstruktion, så höga värden på kanslighet brukar man bara få för några enstaka hörn konstruktioner och det är sällan dom kommer över 110dB/w/m, skulle dock tro at dessa högtalare ligger runt 85 till 90 db/w/m.
Posted - 2005/09/19 :  09:55:13  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message  Reply
Med så många element är det inte alls otroligt med känslighet en bra bit över 100 dB.
ILLY
HiFitraktör
Posted - 2005/09/19 :  10:09:44  Show Profile Send ILLY a Private Message  Reply
Hm, jag måste erkänna att 114db var en siffra tagen ur luften. Efter att ha letat reda på texten där jag läst om dem så insåg jag att det inte stod någon sifferangivelse på känsligheten. Vad det däremot står är följande:
"En kul demonstration blev det däremot med normal lyssningsnivå vid en tiondels watt och nästan outhärdligt högt när man inte utnyttjat mer än omkring en hundra-del av förstärkarnas resurser"
(Hifi & Musik, maj 2005, sid 35)
Militant cyklist.
Edited by - ILLY on 2005/09/19 10:10:55
Posted - 2005/09/19 :  10:32:13  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message  Reply
Nej, du hade rätt christopher. 89dB enligt bladet: http://www.mcintoshlabs.com/data/brochures/XRT2K.pdf
