Author |
Topic  |
Creative Audio
2547 Posts |
Posted - 2005/07/07 : 20:09:13
Creative Audio presents music hall
a25.2 integrated amplifier / cd25.2 CD-player Creative Audio presents the release of the a25.2 integrated amp and cd25.2 CD-player. These components were specifically designed for the music lover. We set out to prove that with attention to detail, good design, and dedication, fine audio equipment can be made at a sonable price. To this end, we chose a select group of technologically avanced and synergistically matched parts to make the a25.2 and cd25.2. The perfect complement to one another this combination will provide years of musical enjoyment.
a25.2 Features: •Power: 2 x 60 Watts / 8 Ohm, 2 x 75 Watts / 4 Ohm Sinus •Min. Impedance: 2 Ohm •S/N: Mer än 101dB •Frequency Range: 10Hz -50kHz ±0.5dB •Distortion (THD+N): <0.002(1kHz) •Specially designed low-noise pre-amp section •Pre-amp out / Subwoofer connection •4 analog inputs, 1 tape loop •Headphone Input on front •Solid cabinet, thick brushed aluminum fascia •Gorgeous slim-line system remote control •Easily readable and dimmable florescent display •Detachable power cord Pris: 7.695:-
cd25.2 Features: •Burr-Brown PCM 1738 24-bit/192kHz DAC •Philips VAM1202/19 transport •Thick brushed-aluminum front plate and solid chassis •Two digital outputs; 1 x coaxial and 1 x optical •Standard analog output •Gorgeous slim-line system remote control •Easily readable and dimmable florescent display •Detachable power cord Pris: 6.595:- Settpris; - 10% |
++ äger och driver Creative Audio++ ++Stockfisch-records++Turtle-records++SCR-Records++C.E.C++MusicHall++Ayon++Lumen White++Agile Multimedia o. ström++Pentagon++Krell++DP++Phonar Högtalare++Fadel ART kablar++ViaBlue++Aqvox++Dynavox++T.A.C++Dual++
http://www.creative-audio.se |
Edited by - Creative Audio on 2005/09/05 23:07:03 |
Jörgen_G
8011 Posts |
Posted - 2005/07/07 : 21:48:20
De vanliga frågorna i detta skede av presentationer av nya produkter dyker upp: - Finns det några lyssningsintryck ännu? - Prisindikation?
mvh/ Jörgen G
edit: Tackar!
Mina grejor kan man läsa om i min tråd i Medlemmarnas system. Hen är ett förvånansvärt praktiskt och användbart pronomen. |
Edited by - Jörgen_G on 2005/07/07 22:02:50 |
Creative Audio
2547 Posts |
Posted - 2005/07/07 : 22:35:24
Jörgen vi fick apparaterna CE godkända förra veckan. Vi gör bara en slutkontroll till i sändningen från USA (dom kommer ifrån Ray Hall). Apparaterna kan levereras från och med nästa vecka. En av de första CD-Spelarna kommer att levereras till en forummedlem. Han kanske kan skriva en test. Vill inte göra detta själv (Jävig).
Wolfgang |
Jörgen_G
8011 Posts |
Posted - 2005/07/07 : 22:57:20
Wolfgang:quote: levereras till en forummedlem. Han kanske kan skriva en test. Vill inte göra detta själv (Jävig).
Tänkte inte på det
mvh/ Jörgen G |
Edited by - Jörgen_G on 2005/07/07 23:09:58 |
mayro
Lämnat på egen begäran
10984 Posts |
Posted - 2005/07/14 : 18:12:26
quote: En av de första CD-Spelarna kommer att levereras till en forummedlem. Han kanske kan skriva en test. Vill inte göra detta själv
JAG vill vara den forummedlemmen ..... Om du vågar sända till euLJUED eftersom vi sågar allt här.....   |
Driver Mayros hifidagis
2543 Posts |
Posted - 2005/07/14 : 18:33:39
PCM1738 är samma dac som sitter i den älskade/hatade Pioneer 668. Detta är en mycket bra dac förövrigt och jag tror garanterat att den här spelaren är ett par divisioner bättre än Pioneeren!
Dessutom var den ju riktigt snygg och stärkaren var t o m urläcker...
PS Stämmer förresten effektangivelserna på stärkaren? Verkar lite klen i 4 ohm!?
Mvh Jonas
edit: stvning |
You'll Never Walk Alone... |
Edited by - jonasz on 2005/07/14 18:34:34 |
18938 Posts |
Posted - 2005/07/14 : 18:42:25
Den spelar hos nån just NU!
"Vänner är de där ovanliga människorna som frågar dig hur det är och sen väntar på svaret. / Okänd" |
Bubben
1032 Posts |
Posted - 2005/07/14 : 19:06:36
Eh...vad säger dacen om hur spelaren låter? PCM 1738 (från Burr-Brown) sitter även i Krell SACD Standard...blev den lika bra som den då? 1738-dacen är i princip tre kombinerade 1704 (som sitter i Primare D30.2 och Advantage S1), anpassad för multikanal. 1738 har kommit att mer eller mindre bli en standard-dac för multikanalspelare.
Edit: Sifferflimmer |
"-Kvantitet är oväsentligt utan kvalitet." |
Edited by - Bubben on 2005/07/14 19:08:20 |
2543 Posts |
Posted - 2005/07/14 : 19:30:54
Vad betyder pickupen eller riia'n för vinyllyssning? 1738 finns i några apparater men den är absolut inte lika vanlig som alla dessa integrerade alster som sitter i 95% av alla CD/DVD-spelare nuförtiden. Det blir dyrare och förmodligen bättre att bygga med 1738 än t ex Crystaldacar.
Jonas |
2543 Posts |
Posted - 2005/07/14 : 19:38:40
PCM 1702 och 1704 är förövrigt utmärkta dacar också.  |
akktustakki
MJW Musik hemma
1098 Posts |
Posted - 2005/07/14 : 21:01:20
Nå, för bövelen, Hur låter det då?  |
Jörgen_G
8011 Posts |
Posted - 2005/07/14 : 21:09:35
Bra tydligen - han kan inte slita sig...
/Jörgen G |
18938 Posts |
Posted - 2005/07/14 : 22:00:55
Låter rät ok, men vill inte säga så mycket mer, efter bara 11 timmars spelande. |
akktustakki
MJW Musik hemma
1098 Posts |
Posted - 2005/07/14 : 22:18:20
Rätt OK? Mesigt Zalve, mesigt. |
18938 Posts |
Posted - 2005/07/14 : 23:08:30
Efter 11 timmar vill jag inte säga nåt, då vissa saker kan ändra på sig. Dock är den bättre än min tidigare källa. |
Creative Audio
2547 Posts |
Posted - 2005/07/16 : 11:32:19
Första sändningen Stärkare och CD- spelare slutsålda, nya kommer om en vecka !!
Wolfgang |
Snoop
Medlem, HiFi Norr
4184 Posts |
Posted - 2005/07/18 : 15:28:34
Fin fina grejjer!! |
[Squeezebox 3][Onkyo TX-SR876][Phonar Veritas P5][Kef KHT 2005.2] Moderator på Minhembio
Creative Audio
2547 Posts |
matte76
6570 Posts |
Posted - 2005/07/27 : 22:55:28
Mycket mycket snyggt system!   |
- Blått ett lag - Malmö FF! - Min anläggning: DH Labs Silversonic Power Plus (nätkablar) - Marantz SA-11S2 (CD/SACD) -> Xindak FA-1 XLR -> Marantz PM-11S1 -> Audioquest CV-8 (DBS, biwire) -> Canton Ergo 609 DC (Med Soundcare Superspikes) - Alla MÅSTE se "En obekväm sanning" (An inconvenient truth)! - Löjligt korta bilresor i Malmö - http://www.ingalojligabilresor.nu/
7380 Posts |
Posted - 2005/07/28 : 01:19:24
Mycket snygga högtalare |
Lever på samhällets botten. Knappt aktiv forummedlem längre, men jag tittar in ibland. |
Snoop
Medlem, HiFi Norr
4184 Posts |
Posted - 2005/07/28 : 07:28:04
Blir ju nästan avis på detta ju Sovrums stereo till mig i julklapp eller vad säger du wolfie  |
Edited by - Snoop on 2005/07/28 07:30:40 |
hjort
754 Posts |
Posted - 2005/07/31 : 13:19:25
Wolfgang kan man få Cd spelaren med digital ingång? |
Gaffa
fd. Mabuse
1455 Posts |
Topic  |
