 Gryphon presenterar Poseidon Reference loudspeaker
Posted - 2004/09/08 :  07:25:18  Show Profile  Visit Pac's Homepage Send Pac a Private Message
Gryphon Audio Design
drar på ordentligt...
Gryphon Audio Designs Introduces
The Poseidon Reference Standard Loudspeaker System
Ry, Denmark, September 5, 2004 - Gryphon Audio Designs of Denmark announced today the release of possibly the most elaborate and uncompromising loudspeaker in the history of home audio, the Gryphon Poseidon. Constant Phase and True Time Alignment ensure sound quality worthy of Gryphon’s sumptuous furniture design.
Named after the Greek god of all things nautical and seismological, the four-piece, 34-driver Poseidon system consists of matching mid/high frequency towers and bass towers for each channel and stands an imposing 199 cm (6 ft. 6 1/2”) tall.
A bold expression of faith and confidence in the future of High End audio, the Gryphon Poseidon reaffirms the company’s 20-year commitment to two-channel audio on the cutting edge of technological innovation and aesthetic design.
Gryphon founder and CEO Flemming E. Rasmussen explains, “When we created the stand-mounted Gryphon Cantata loudspeaker for big-speaker performance in a normal-sized living space, listeners immediately became curious as to what we would do if size and cost were no object. Luckily, we had been working on that very thing for nearly 15 years with a constantly evolving loudspeaker project that we used as a reference in our amplifier and CD player design work.”
With 16 – 40,000 Hz frequency response +3 dB (depending on Q setting and room size), the 4-way sealed-enclosure system is based on a constant-phase crossover with all drivers in phase at all times at all frequencies, quite possibly for the first time in any loudspeaker.
Each bass column incorporates eight 8” drivers and a custom designed 1,000 Watt (4 Ohms) Gryphon amplifier. The bass columns employ Gryphon’s active Q Control room integration technology for smooth, extended bass response in virtually any environment. Q and bass level can be adjusted from the listening position with the Poseidon remote control. The separate active crossover networks weigh in at 35 kg (77 lbs) per channel.
Weight of complete Poseidon system: 800 Kgs.
The mid/high system utilizes four 5" midbass drivers and four 5” midrange units and the Scan Speak ring radiator tweeter in a 1 kg aluminum housing specially designed by Gryphon.
The four exquisitely finished cabinets feature a distinctive arched baffle precisely calculated to ensure true time alignment at the listening position. According to Rasmussen, available finish options are limited only by “the imagination of the buyer and the goodwill of his bank manager.”
Recommended list price is: 130.000 USD
About Gryphon Audio Designs
Since its inception in 1985, Gryphon Audio Designs of Denmark has earned a worldwide reputation for state of the art performance, intuitive ergonomics and stunning aesthetic design.
email@gryphon-audio.dk
www.gryphon-audio.com
F.C.
Posted - 2004/09/08 :  22:15:50  Show Profile Send F.C. a Private Message
Hej
Hvor har du fundet det henne?
Med venlig hilsen
Frederik Carøe
Synkront? Hvorfor ikke?
Duelund Coherent Audio
jonte0
Posted - 2004/09/08 :  22:51:23  Show Profile Send jonte0 a Private Message
här kanske
http://www.positive-feedback.com/industrynews.htm
Qui habet aures audiendi audiat
bambadoo
Posted - 2004/09/08 :  23:58:59  Show Profile Send bambadoo a Private Message
http://www.hifi4all.dk der står det også endel.
christopher
Posted - 2004/09/09 :  08:39:30  Show Profile Send christopher a Private Message
Har dom inte redan presenteras på CES i Las Vegas?
Rydberg
Posted - 2004/09/09 :  08:50:59  Show Profile Send Rydberg a Private Message
Lite bilder ska vi väl ha också!!!
I'm not a complete idiot, some parts are missing
F.C.
Posted - 2004/09/09 :  09:38:42  Show Profile Send F.C. a Private Message
Ikke dårligt...
Med venlig hilsen
Frederik Carøe
Posted - 2004/09/09 :  10:03:25  Show Profile  Visit Pac's Homepage Send Pac a Private Message
Det kommer från deras press-release.
sker
Posted - 2004/09/09 :  11:54:10  Show Profile Send sker a Private Message
Riktigt coola Ser ut som en blandning av Revels och Krells högtalare
Mitt system: http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=27987
F.C.
Posted - 2004/09/10 :  12:02:21  Show Profile Send F.C. a Private Message
Synes nu mere designet giver aninger til flotte Sonus Faber kabinetter.
Det sagt, er de klart et gryphon-produkt af udseende.
Med venlig hilsen
Frederik Carøe
edison
N.A.udiophile
Posted - 2004/09/13 :  20:51:26  Show Profile Send edison a Private Message
Nog borde priset även tillåtit en snygg design...(???)
Ganska märkligt att riktigt exklusiva högtalare påfallande ofta är så uselt formgivna (= läses "fula")
Men helt klart har dessa en poäng i sin bågform, Gryphon har så att säga tagit steget full ut där tex JMLab/Focal "bara" gjort fronten vinklad för tidskompenseringen av elementen som flankerar diskanten...
F.C.
Posted - 2004/09/13 :  22:29:22  Show Profile Send F.C. a Private Message
Det er nødvendigt, hvis faseforholdene skal passe. I øvrigt har du gjort et excellent valg af diskant.
Med venlig hilsen
Frederik Carøe
Rydberg
Posted - 2004/09/14 :  09:40:44  Show Profile Send Rydberg a Private Message
Posted - 2004/09/14 :  09:49:25  Show Profile Send EngelholmAudio a Private Message
Blåa strålkastare på prylarna till och med. Ingår dom, Rydis?
Rydberg
Posted - 2004/09/14 :  09:53:59  Show Profile Send Rydberg a Private Message
Tror de normalt är tillval faktiskt men de ingår dock om man väljer komfortpaketet
Posted - 2004/09/14 :  18:54:09  Show Profile Send Duelund Coherent Audio a Private Message
Blå lysdioder er jo populære...
Med venlig hilsen
Frederik Carøe
