 Coda Ts slutsteg sänkt pris
Figge
Posted - 2016/02/07 :  13:48:46  Show Profile Send Figge a Private Message
Säljer mitt slutsteg ett Coda TS.
RATED POWER
Class A to 10 Watts
400 Watts x 2 into 8 Ohms
800 Watts x 2 into 4 Ohms
1 Ohm load stable
BANDWIDTH
DC or -3dB at 5 Hz through 100kHz depending on
input
DISTORTION
Les s than .03% from 10Hz to 20kHz at 350 Watt
both channels driven into 4 through 8 Ohms
GAIN
26dB
CURRENT CAPABILITY
150 Amperes peak
SLEW RATE
50 Volts/microsecond
INPUT IMPEDANCE
50k Ohms unbalanced/1k Ohms balanced
OUTPUT IMPEDANCE
04 Ohms from 20Hz to 20kHz
NOISE
More than -110 dBA referenced to rated output
POWER SUPPLY
3.0 kVA toroidal transformer with independant
recti_ers and 80,000 uF of capacitance
DIMENSIONS
Faceplate: 17 inches wide by 5.5 inches tall
Chas s is : 16.75 inches wide by 6 inches tall by 14
inches deep
WEIGHT
62 lbs
http://coda.cc/product/index.php
http://www.pmaudio.no/index.php?menu...t=1791#produkt
Köpt av mig brukt från Norge i september 2014.
Till förmån för ett par monoblock i Klass A.
image: http://www.hifisentralen.no/forumet/images/smilies/smiley.gif
För över 100000:- så bra är den.
Read more at http://www.hifisentralen.no/forumet/torget.php?do=viewitem&itemid=121990&predata=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&displaytype=gallery&PagePosition=1377#Vo9ZUgtEbwH3OfbQ.99
Nypris:60000:- nu 28000:-26000:-
Orginalkartong finns och garanti kvar. 10 års garanti.
Edited by - Figge on 2016/03/20 15:13:10
Posted - 2016/02/07 :  14:26:36  Show Profile  Visit Pac's Homepage Send Pac a Private Message
Pris?
Figge
Posted - 2016/02/27 :  18:21:24  Show Profile Send Figge a Private Message
Innan den skickas tillbaka till Norge?
