 Pinka i poolen?!? :-) Kopieringsskydd på DVD-A
Melker
Posted - 2003/01/30 :  00:28:54  Show Profile Send Melker a Private Message
Har ni läst vad John Atkinson skriver på Stereophiles (September 2000)?
" I read about how, with DVD-Audio in particular, the music signal will be "watermarked" so that someone can extract the copyright information from the sound. An analogy would be those translucent logos that TV channels put in the corner of the screen?so you can be reminded, for example, that it is A&E that is bringing you Poirot.
As I explained in this space several months ago, because the watermarking code needs to be retrievable after the music data have been converted to analog, and perhaps transmitted over an AM radio link, or even compressed with MP3, the code has to be robust; ie, high in level. And if it is robust, it might be audible. Now, as David Leibowitz of Verance, the developers of the watermarking scheme adopted by the recording industry for DVD-Audio, pointed out in the August Stereophile's "Manufacturer's Comments," the watermarking is not as obvious as mixing Morse code with the music. The low-bit-rate (20bps) code is disguised to resemble the analog noise already present; in addition, it is spectrally shaped to get the maximum benefit from psychoacoustic masking. (In very simplistic terms, the code is loudest when the music is loudest in both the amplitude and frequency domains.) In addition, the watermarking doesn't have to be present all the time, nor is it mandatory for content producers to use it on DVD-As. (SACD uses a different scheme that apparently doesn't affect the music data.) "
Stämmer detta så verkar det som om DVD-A formatet helt enkelt skjuts i sank av sitt eget kopieringsskydd. Hans kollega Jon Iversson sammanfattar med:
"And don't get me started about watermarking DVD-Audio releases to prevent piracy. I agree 100% with John Atkinson's stance in last month's "As We See It": Boycott any company that does it. It's as if the record labels and equipment manufacturers got together to build the world's most wonderful swimming pool. They filled it with ultra-pure mountain spring water and install a state-of-the-art filtration system, and then, every day, mark their beautiful new territory by peeing in it like dogs."
http://www.stereophile.com/showarchives.cgi?257
http://www.stereophile.com/printarchives.cgi?281
Melker
Halmstad
Edited by - Melker on 2003/01/30 00:32:03
Magnuz
Posted - 2003/01/30 :  08:52:21  Show Profile Send Magnuz a Private Message
Ligger mycket i det. Tur att det åtminstone inte är obligatoriskt. Men man kan ju fråga sig vad vitsen med nya och teoretiskt bättre format är om man redan från början sabbar signalen med flit. Skillnaden mellan en välinspelad CD och en dito DVD-A är nog inte större än att den faktiskt skulle kunna "ätas upp" av kopieringsskyddet.
linq
Posted - 2003/01/30 :  08:52:46  Show Profile Send linq a Private Message
Watermarking är inte något som krävs för en DVD-A-skiva, skulle tro att det är vanligare utan än med. Dessutom förekommer det även på "vanliga" CD. Kanske också på SACD?
Timbre
Posted - 2003/01/30 :  11:40:32  Show Profile Send Timbre a Private Message
Bara misstanken är ett skott under vattenlinjen...
När det gäller DSD ligger kopieringsskyddet i själva hårdvaran och man kommer inte åt signalen digitalt.
linq
Posted - 2003/01/30 :  12:12:56  Show Profile Send linq a Private Message
Jag menade att eftersom det finns vanliga CD-skivor med watermarking så är det väl tänkbart att vissa skivbolag kan tänkas släppa SACD-skivor med det också, inte att watermarking finns inbyggt i hårdvaran på SACD-spelare.....
Conan
Posted - 2003/01/30 :  14:47:59  Show Profile Send Conan a Private Message
Hela skivbranshen håller på att ta död på sig själv -- och det är kanske lika bra att hela sk**en får konka så kanske det kan komma fram nåt bättre och "sundare" ur askan av den gamla draken! Liknelsen med att pinka i poolen var verkligen träffande!! Kan man inte fatta att loppet är kört och det inte går att backa tillbaka till den "gamla goda tiden" då folk satt runt lägerelden med stenkakor och trattgramofoner så tänker i alla fall inte jag sörja vid den graven!!
Sen är det är ju helt fantastiskt att "straffa" oss stackare som slantar upp och faktiskt köper plattan med "anti-ROM", kopieringsspärrar, vattenmärken som ligger i musiksignalen(!!!) och att annat jävulstyg man kan komma på! Förbannad är ju det minsta man kan bli...
CD-rean förresten... vilket skämt! Bara ännu en spik i kistan!
Militant Ljudrättsaktivist
