 KingRex PREference försteg
Transient Design
Posted - 2011/03/27 :  10:40:53  Show Profile  Visit Transient Design's Homepage Send Transient Design a Private Message
KingRex PREference försteg med phonomodul och extern nätdel.
Demoex i originalförpackning. Perfekt i nyskick!
listpris 16000:- ... Vår(t) pris 9995:-
spec:
Inputs: RCA#65290;4
Outputs: RCA#65290;1
Gain: 7dB,14dB,20dB Selectable
Frequency Response Range:
20Hz-20Khz(+0~-0.1dB)
5Hz-80Khz(+0~-1.0dB)
Maxium Input Level:9Vrms(@0dB)
Maxium Output Level: 9Vrms
THD+Noise: <0.0005% @1KHz
Input Sensitivity:
1.1V For 2.5V Out@7dB Gain
510mV For 2.5V Out@14dB Gain
250mV For 2.5V Out@20dB Gain
Signal to Noise Ratio:126dB
Channel Separation:
112dB@1KHz,92dB@10KHz
Power Consumption:<10W
Phonodel
Signal to Noise Ratio: 112dB(MM-Low gain), 104dB (MC-Low gain)
THD+N Ratio = 0.0006%(MM-LOW Gain)#12288; 0.01%(MC-LOW Gain)
Crosstalk (at 1kHZ): -94dB (MM-Low gain), -79 dB(MC-Low gain)
Crosstalk (at 10kHz):-100dB (MM-Low gain), -86dB(MC-Low gain)
Gain (at 1kHz): 24dB(MM-Low gain), 43 dB(MC-Low gain), High gain=+20dB
Max Input Level: 19mV(MM), 6.6 mV(MC), (High-gain)
218mV(MM),72mV (MC),(Low-gain)
Output Impedance: <100 Ohms
Input Impedance : 100Ohms, 220 Ohms, 47kOhms, switchable
Input Capacitance: 0 P, 100P, switchable.
pma vid intresse
Lasse
Transient Design
www.transientdesign.se Distributör för AMR, iFi-Audio, Acoustic Revive, Leben, Line Magnetic, LAB12, Okki Nokki, Bryston, Kora, HANA och HiFimans hörlurar.
Edited by - Transient Design on 2011/03/29 08:21:07
