IC FIDELITY
30 Posts |
Posted - 2010/02/11 : 09:02:06
Here#8217;s a thrilling full-range loudspeaker of reference quality that supplies plenty of goosebumps, but also has #8217;stat-like coherence, superb time and phase accuracy, and breathtaking soundstaging.
It is an accurate, yet musical speaker with fast transients, precise layered imaging, and articulate, extended bass.
You may have noted that I frequently used the phrase, #8220;just like in a live performance,#8221; when describing the sonic prowess of this Vienna Acoustics flagship loudspeaker. And that#8217;s just it. The Music compares surprisingly well to a live performance, and that#8217;s very high praise.
http://www.avguide.com/review/tas-195-vienna-acoustics-the-music-loudspeaker?page=3
Arrangerar Nordens största mässa för Ljud & Bild http://www.goteborghifishow.se |
