 Dom vet vad de håller på med, Italienarna...
Michael Dupé
Posted - 2003/01/05 :  19:56:27  Show Profile Send Michael Dupé a Private Message
Eller vad sägs om denna underbara, 7-vägs skapelse från Chario,
Academy Millennium Grand:
Technical Data
Acoustic Load : one bottom-firing vented push-pull & four open-end TLines
Vent shape: high order exponential type with both end flared
Transmission Line shape: non-linear tapering with rounded winding pipe and full resistive stuffing
Configuration: 7 way floor-standing non-conventional (proprietary)
Drivers:
1 ribbon tweeter 10 x 55 mm (0.4 x 2 in)
1 dome mid-tweeter 29mm (1.1 in)
1 cone midrange 130mm (5 in) carbon-cellulose
1 upper woofer 130mm (5 in) carbon-cellulose
1 centre woofer 130mm (5 in) carbon-cellulose
1 lower woofer 130mm (5 in) carbon-cellulose
1 push-pull subwoofer 320mm (12 in) treated cellulose
Sensitivity: 92.5 dB SPL normalised to 1 m (3 ft) with 2.83 Vrms de-correlated Left & Right pink noise whitin IEC 268-13 Listening Room
Low frequency cut off : 23 Hz @ -3dB referred to C, diatonic tone
Crossover Frequencies: unconventional alignment
Rated Impedance: 4#911; (minimum 3.2)
Sizes: 1800 x400 x 690 mm H x W x D
Weight: 152 kg
Speakers orientation: the speakers should be tilted inward facing the listener
Listening distance: optimum speaker-listener distance is about 3.5 - 4 m (10-12ft)
Side walls: should stay 1 m (3ft) far from the speaker front baffle at least
Back walls: should stay 1.6 m (4.7ft) far from the speaker front baffle at least
Suggested amplifiers
Normal amping
: 300W/4 #911; max,
Bi-amping
Sub woofers & Mid-High: 200 W/4 #911; max
Mid-High: 100 W/4#911; max
Sub & Woofers: 250 W/4#911; max
Tri-amping
Sub : 200 W/4#911; max
Woofers : 200 W/4#911; max
Mid-High : 100 W/4#911; max
De väcker ha-begär innom mig som jag inte visste fanns.
Funderar strongt på att göra mig av med mina Syntar och uppgradera mig lite...
ekman
Posted - 2003/01/05 :  19:58:10  Show Profile Send ekman a Private Message
ingen konkurrans för amati homage men jösses vad duktiga italienare är på träarbete
brumel
Posted - 2003/01/05 :  19:59:25  Show Profile Send brumel a Private Message
Är dom dyra eller mycket dyra?
Hifiarkeologen
Michael Dupé
Posted - 2003/01/05 :  20:10:05  Show Profile Send Michael Dupé a Private Message
Min gissning faller nog på: hur dyra som helst. 1000 spänn kilot kanske...
Knoppen
Posted - 2003/01/05 :  23:38:20  Show Profile Send Knoppen a Private Message
Jag har hittils kommit på två saker:
Banddsikanten är placerad liggande! För mig verkar dett mycket ologiskt eftersom den dp sprider dåligt off-axis, t ex om det är fler som lyssnar i soffan hör de en annan frekvensgång. Eller så är det nya modet i år?
Diskanterna verkar ganska lågt placerade. Eller så är högtalarna mycket höga? Oj nu ser jag, de är ju väldigt höga, hela 1,8 m!
/Johan
Niklas Nord
Posted - 2003/01/06 :  00:09:44  Show Profile Send Niklas Nord a Private Message
hmm... jag tycker det också ser mysik ut!
fast de måste ju såklart testat sin konstruktion.
den är i varje fall jättesnygg, dock stor....
men det är maffigt!
diskanten ser ut att ligga där den skall i sånna fall
den är så hög som den är.
kasra
Posted - 2003/01/06 :  00:39:04  Show Profile Send kasra a Private Message
/Johan
Banddiskanten spelar antagligen dem allra högsta tonerna, genom att lägga ner diskanten så minskas spridningen på bredden, medans den växer i y-ledet dvs lodrätt.. upponer...
Då kommer lyssningshöjden inte vara viktig, medans riktningskänsligheten kommer att öka om man vill höra dem högsta tonerna?!!
/kasra
"Pretty girls dont cry"
Neodynium
Posted - 2003/01/06 :  00:57:23  Show Profile Send Neodynium a Private Message
Klart spännande högtalare...=) Synd att vi inte har någon miljadär som kunde köpa allt vi hittade och anordna hifi träffar..
Michael Dupé
Posted - 2003/01/06 :  03:27:36  Show Profile Send Michael Dupé a Private Message
Jag instämmer! Dags att leta rätt på någon krösus som har lust å sponsra lite...
Jag måste bara få se dem i verkligheten!
They will be mine, oh yes, they will be mine..
Brosk
Posted - 2003/01/07 :  00:35:38  Show Profile Send Brosk a Private Message
Chockerande välbyggda. Men 152 kg på lilltån..
