 Vilka parametrar är viktiga för en högtalare?
esl
Posted - 2009/01/24 :  21:54:08  Show Profile Send esl a Private Message
Några verkliga experter på området ljudåtergivning och Psykoakustik:
Dr. Sean Olive Ordförande i AES Western Canada/US Chef på utveckling av Harman (JBL, Infinity, Harman, Mark Levinsson, Epicure, mm)
Steve Temme Listen Inc.
Dr. Earl Geddes GedLee http://www.gedlee.com/Audio_trans.htm
Laurie Fincham THX
Mike Klasco Menlo Scientific
Dr. Floyd Toole
Vad dessa betytt för HiFin kanske är överfllödigt att prata om. Och när dom kommer ihop och diskuterar så viktiga saker som högtalaråtergivning, då spetsar i alla fall jag öronen. Denna bloggen skall jag följa!
http://seanolive.blogspot.com/
Innovare necesse est.
marens
Posted - 2009/01/25 :  14:57:35  Show Profile Send marens a Private Message
1. The perception of loudspeaker sound quality is dominated by linear distortions, which can be accurately quantified and predicted using a set of comprehensive anechoic frequency response measurements (see my previous posting here)
2. Both trained and untrained listeners tend to prefer the most accurate loudspeakers when measured under controlled double-blind listening conditions (see this article here).
3. The relationship between perception and measurement of nonlinear distortions is less well understood and needs further research. Popular specifications like Total Harmonic Distortion (THD) and Intermodulation Distortion (IM) do not accurately reflect the distortion#8217;s audibility and effect on the perceived sound quality of the loudspeaker.
4. Current industry loudspeaker specifications are woefully inadequate in characterizing the sound quality of the loudspeaker. The commonly quoted #8220;20 Hz - 20 kHz , +- 3 dB#8221; single-curve specification is a good example. Floyd Toole made the observation that there is more useful performance information on the side of a tire (see tire below) compared to what#8217;s currently found on most loudspeaker spec sheets (see Floyd's new book "Sound Reproduction").
Mina understrykningar. Kan bara fullständigt hålla med dessa herrar. Den enkilda mest förbisedda "parametern" eller egenskapen är frekvensgång i olika riktningar från högtalaren. När man börjar prata om frekvensgång i ett "rymdperspektiv" så inser man mer och mer hur mycket mer komplext det är, och vilka effekter det har på det upplevda ljudet, jämfört med vanlig frekvensgång i en förstärkare tex.
