 Vad tror ni om denna högtalaranslutningen?
matson
formerly known as...
Posted - 2002/07/15 :  00:16:00  Show Profile Send matson a Private Message
Patenterad av Cardas!
"The CPBP saves installation time without sacrificing sound quality. A single Allen bolt locks the glass filled nylon, binding post base to the chassis or cabinet. Raised bosses on the back of the base fit standard mounting holes and keep it from rotating. After the base is installed, the internal conductors are pulled through the post holes and soldered to the contact posts while they are outside and easy to reach."
"The posts are then inserted into the base. This is a very simple and time saving process. And, because of its elegant design, the Cardas Patented Binding Post affords sound quality equal to, or better than anything in the industry."
150 spänn styck(man behöver 2st för 2st högtalare(stereo alltså))!
Mvh/Mats
'Bad habits pay off in the long run'
n/a
deleted
Posted - 2002/07/15 :  00:42:41  Show Profile Send n/a a Private Message
Hej M!
Jo de verkar väldigt bra( det är lite fula dock, är de inte??).
Dessa är billigare och snyggare:
, med dessa:
Mvh A
matson
Posted - 2002/07/15 :  01:03:37  Show Profile Send matson a Private Message
Hej A!
Jo, kanske lite fula....
....men Speakon är ju så drygt om man skall prova med andra kablar(med vanliga kontakter alltså).
Mvh/Mats
n/a
deleted
Posted - 2002/07/15 :  01:12:12  Show Profile Send n/a a Private Message
Hej M!
Jo, det blir nog mest om man bygger något eget med Speakon från början då.
Mvh A
