 Vinylkopiering freeware?
miaber
Posted - 2008/08/26 :  19:35:01  Show Profile  Visit miaber's Homepage Send miaber a Private Message
I ett tidigare liv (innan XP eller Vista) hade jag winonCD för att kopiera vinylerna till CD. Nu fungerar ju inte detta längre i dom nya operativsystemen, och en uppgradering kostar.
Vet någon om det finns någon användbar freeware för detta ändamål? Eller vilka program använder ni (som inte får kosta skjortan)?
DahlbergAudio
Mästar-Harry 2005
Posted - 2008/08/26 :  20:28:23  Show Profile  Visit DahlbergAudio's Homepage Send DahlbergAudio a Private Message
Audiograbber verkar funka (gratis)
Line in sampling.
This function is found under the file menu.
The "line in" sampling function is used to record from audio sources through the soundcard either internally, ie. from the cd rom, or even a music file on the hard disc, or from an outside audio source such as a phonograph or radio, through the "line in" jack on the soundcard. You can plug whichever audio source you desire into your soundcard and let Audiograbber record from it. For best results, always try to send as good a signal to the soundcard as possible. To record from vinyl it is best to connect the turntable to the stereo and then the stereo to the sound card. Do not connect the turntable directly to the soundcard, as the signal from the turntable is too weak.
The "line in" function has three different recording modes: "manual", "track splitting", and "time scheduled". These different modes are described in more detail later on in text.
http://www.audiograbber.com-us.net/
Edited by - DahlbergAudio on 2008/08/26 20:29:08
Posted - 2008/08/27 :  20:09:31  Show Profile Send Bubbel a Private Message
Bästa kopierings program jag har hittat är Groove mechanic http://www.coyotes.bc.ca/
Hur gör du:
http://www.pcabusers.com/vinyllp/vinyllp.htm
Anders
miaber
Posted - 2008/08/27 :  22:21:35  Show Profile  Visit miaber's Homepage Send miaber a Private Message
Jag har nu testat Audiograbber. Funkar klockrent. Tack för tipset/n.
Enkelt gränssnitt, bla.
DahlbergAudio
Mästar-Harry 2005
Posted - 2008/08/27 :  22:59:21  Show Profile  Visit DahlbergAudio's Homepage Send DahlbergAudio a Private Message
Varsågod
mikaels
Posted - 2008/09/14 :  13:07:25  Show Profile Send mikaels a Private Message
Audacity, http://audacity.sourceforge.net/
Bundlas ju med den där USB-anslutna vinylspelaren som säljs här och var.
- "Do you indulge in any form of worship?"
- "Life. I love life, very much indeed.
David Bowie interviewed by Russell Harty, 1973
