acebowler
Posted - 2007/01/19 :  10:36:52  Show Profile Send acebowler a Private Message
Har ev kommit över ett par Tannoy Puma högtalare..
Enligt "nätet" skall det sitta 3805 element i dessa.
Skulle detta vara något att ha?
Det finns ju ett par Tannoyfantaster här så jag provar...
GM 70SE Nu kör vi!!
Posted - 2007/01/19 :  11:13:28  Show Profile Send Micke Y a Private Message
Här har du info
http://www.hilberink.nl/codehans/tannoy52.htm
THE WILDCATS : P - SERIES
In 1984 the Research and Development team at Tannoy wanted to prove that the Dual was an excellent
solution to very high quality live music performance venues. Clearly, with the sizes of magnet and
levels of efficiency available it could not compete with the outdoor rock concert systems from Altec,
Meyer and JBL but there was a niche in the cabaret and small club market where the sound quality
needed to be considerably higher than that to which people were accustomed. Specially adapted Duals
were designed that had more power handling and greater sensitivity than had ever been produced before
by Tannoy. These were fitted to a range of very robustly made cabinets with reinforced handles and
corners suitable for mobile cabaret or fixed contractor installation work. The line was christened the
'Wildcats' and was the start of a very successful venture into high quality voice and music provision
for sophisticated venues such as clubs, theatres and churches.
The Dual Concentric is a unique speaker system ideally placed for communication and intelligibility in
difficult acoustic surroundings. The dispersion character (directivity) is much more constant
throughout the audio band than with most other systems. Therefore more direct sound reaches the
listener than reflected sound and the intelligibility of the reproduced program material is greatly
enhanced. The directivity characteristic also prevents excitation of troublesome room resonance
associated with the reverberation time of room acoustics.
Intelligibility and communication ability in halls and theatres is measured in 'Alcons' or 'percentage
alcons'. The measurement is a quantitative analysis of the hit rate of a listener in the hall
interpreting different words that have similar vowel and consonant sounds. A perfect acoustical
environment would score 100%. The Dual Concentric system is notoriously good at providing the highest
percentage alcon figures in any environment when compared to the competition.
The Tannoy Wildcat range consisted of the following speaker systems:
Lynx using 3169G two 12" high sensitivity Dual Concentrics in a double cabinet.
Bobcat (B50) using 3169R 12" high sensitivity Dual Concentric in a single small cabinet.
Puma (P100) using 3805 15" high sensitivity, high power Dual Concentric.
Jaguar (J200) using 3809 Puma driver in a larger cabinet for deeper bass.
Panther (P200) using 3859 15" Dual Concentric in a front sectored horn cabinet.
Cougar using 3859 15" Dual Concentric in a floor wedge monitor.
Lion (L300) using 15" bass unit in a coupled cavity bass bin.
Cheetah (C150) using 15" bass unit in a small coupled cavity bass bin.
Leopard (L200) using 15" bass unit in a direct radiating bass bin.
The original Wildcat series was split into two ranges in 1987 to create a dedicated road proof MI
cabinet series and a specialist contractor's line for permanent installation. In 1985 Tannoy started
test marketing the high-output Dual Concentrics of the Wildcats into the more domestic end of the
market. The Impulse Series was created using similar Duals to the Wildcats in more acceptably finished
cabinets for home use. The series was not considered a major success but out of the work in
engineering, a new high power studio monitor was developed - the FSM.
The FSM was designed to sit at the top of the studio monitor line that was being improved and
developed by Engineering for launch in autumn 1985.
Many improvements had been worked on in the period from 1980- to 1985 and the time had come to
incorporate all enhancements into the new range. The range change is signaled by the move from Super
Red Monitor to Super Gold Monitor. Edge would coils, higher power and thermal handling, improved
levels of sound quality and a 'faster, tighter' sound quality contributed to the success of this line.
acebowler
Posted - 2007/01/19 :  11:19:11  Show Profile Send acebowler a Private Message
man tackar.
Har du hört byggen med dessa?
S
GM 70SE Nu kör vi!!
Guru
Posted - 2007/01/19 :  12:15:03  Show Profile Send Guru a Private Message
Lägg gärna upp ett foto på dina Tannoy, jag har nämligen ett par Tannoy liggandes men har inte lyckats klura ut vilken modell det är...
acebowler
Posted - 2007/01/19 :  12:47:23  Show Profile Send acebowler a Private Message
guru:
Absolut... skall bara hitta en kamerajävel.... har ingen nuförtiden,,,
och ingen blåtand i datorn heller...
GM 70SE Nu kör vi!!
Guru
Posted - 2007/01/19 :  16:46:36  Show Profile Send Guru a Private Message
Här finns lite mer Tannoy info:
http://tech.groups.yahoo.com/group/tannoy/
acebowler
Posted - 2007/01/19 :  22:30:34  Show Profile Send acebowler a Private Message
Guru!!
Du har PM
GM 70SE Nu kör vi!!
