 Världen är räddad vinyl tvätten är här
dole
en Harley day!
Posted - 2002/11/18 :  16:18:54  Show Profile Send dole a Private Message
The Zenn Record Cleaning Machine
Practically most if not all record cleaners on the market suck, and I do not meant that in a derogatory sense (though some do deserve that label ). Most record cleaners that are effective to some degree, use vacuum suction to remove the waste liquid after scrubbing. Most other systems that do not use suction, just merely move the dirt around on the record and are a total waste of time, money and effort.
However the Zenn record cleaner takes a different approach in removing the waste liquid by furiously spinning the record after scrubbing or more formally exploiting the effect of centrifugal force. As can be seen in the picture below, it's chassis is all acrylic. This is not just for aesthetics but because acrylic unlike wood is totally inert to the effects of water and humidity.
--Den som jämför med något bättre hamnar ofta i en penning knipa-- Ge mig mera pengar nu
Bobbokrull
f.d. "Robin Fischer"
Posted - 2002/11/18 :  16:23:24  Show Profile Send Bobbokrull a Private Message
Najs=)
synd att man inte ha nån bra vinylspelare då:-(
Jadde
Posted - 2002/11/18 :  16:24:49  Show Profile Send Jadde a Private Message
Tredje gången jag ser den här nu... Varför ska man smutsa ner skivorna?
dole
en Harley day!
Posted - 2002/11/18 :  16:26:48  Show Profile Send dole a Private Message
Jaså har den varit med tidigare?!
Bobbokrull
Posted - 2002/11/18 :  16:27:51  Show Profile Send Bobbokrull a Private Message
inte vad jag har sett iaf..
Pipes
Posted - 2002/11/18 :  17:04:01  Show Profile  Visit Pipes's Homepage Send Pipes a Private Message
Ja, den har varit med förut. Dahlberg kommenterade och jag lade in bilden för bara ngn vecka sedan.
Moderator på http://www.vinylengine.com/
Hatoil
Posted - 2002/11/18 :  17:55:35  Show Profile  Visit Hatoil's Homepage Send Hatoil a Private Message
Hur snabbt snurrar den när den centrifugerar?
Säljer ny och begagnad vinyl i butik och på nätet: www.vinylium.se
Pipes
Posted - 2002/11/18 :  19:15:24  Show Profile  Visit Pipes's Homepage Send Pipes a Private Message
Här är länken till den: http://www.zenn.com.sg/zenn_record_cleaning_machine.htm
nin
Posted - 2002/11/19 :  02:36:46  Show Profile Send nin a Private Message
Intressant sak...hmmmm...lägger nog mina surt tjänade pengar på en VPI 16.5 istället...Det ser ju bättre ut i hyllan med samma märke
Pipes
Posted - 2002/11/19 :  03:15:05  Show Profile  Visit Pipes's Homepage Send Pipes a Private Message
VPI:n har en fördel av sin automatik jämfört med Zenn-maskinen ovan. Det kan ju vara skönt att slippa köpa den från singapore också.
Varför inte ta en HW-17 istället, det skiljer ju bara 7500 i pris
nin
Posted - 2002/11/19 :  04:48:50  Show Profile Send nin a Private Message
Ja, 7500kr är ju inget när man ser 100-tals skiver hela tiden man vill ha men inte har råd...
Måste säga att det lutar mer och mer mot VPI TNT HR-X spelaren. Snackat med några ägare och väntar nu på olika tester. Ska kolla om inte PL audio ska ta in någon så man kan lyssna innan. Dom sa att dom "kanske" skulle ta in en...Vi får se...
