 QUAD 303 - 80 W istället för 28 W ???
mace
London calling
Posted - 2006/10/10 :  17:59:39  Show Profile Send mace a Private Message
Läste detta inlägg på quadhifi.
Our 303 boards
We don't use the original transistors, they don't exist anymore. But
we use transistors with better or equivalent specifications. All the
passive components are of the best industrial Audio grade. The
layout is based on the original to make them mechanical and wire
compatible. THe circuit layout is also based on the original, but
there are some changes. You can select the input sensitivity with a
jumper, 0.5, 1.5 or 5 V. Not by a resistive network, but by changing
the gain. In this way the noise is further reduced. The Pcb
accommodate larger output resistors and a better inductor. Also you
can change the current limit. It will deliver 80 Watts in 4 Ohm
instead of the standard 28 Watts in 4 Ohm.
The tracks on the Pcb are
wider where its counts. There is also room on the Pcb for further
modifications, Constant Current diodes and a different output
transistor configuration, but we think they are out of scope
concerning the 303.
Please contact me or Stefaan if you have any questions.
Vahaba Kan man göööra så
Vad förlorar man isåfall?
M
mera quad ESL = mera välljud.
Mr 500!
megajocke
Posted - 2006/10/10 :  22:26:43  Show Profile Send megajocke a Private Message
Antagligen så var det utgångstransistorerna som satte gränsen för effekten i orginalet så om man använder andra transistorer så kan man ju få mer effekt. Ett par MJ15003 eller liknande borde ge 80W i 4 ohm utan problem...
