 Von Schweikert VR8
Björn N
Fd. Speakerpro
Posted - 2002/11/16 :  17:47:10  Show Profile Send Björn N a Private Message
Jag kan satta en peng pa att basen som sitter i VSR Vr 8 ar ett Beyma 12B100R...
Den hogtlaren ar ju kand for sin basformaga, elementet kostar knappt 200 Euro dessutom!
Optimist. punkt slut.
celef
sirap i datorn
Posted - 2002/11/16 :  18:15:13  Show Profile Send celef a Private Message
VR8 använde en 10" och en 13", jag tror båda var tillverkade av Audax (PR240M0 + PR330M0 ??).
sound pollution
n/a
deleted
Posted - 2002/11/16 :  19:36:51  Show Profile Send n/a a Private Message
Mellanregistret var Audax HM-130co.
Björn N
Fd. Speakerpro
Posted - 2002/11/16 :  20:05:14  Show Profile Send Björn N a Private Message
Mellanregistret var fran Audax vet jag, mojligt att basarna oxa var det men Beyma elementet ser EXAKT ut som det som finns i VR8, lika stor magnet o allt=)
celef
sirap i datorn
Posted - 2002/11/16 :  21:07:08  Show Profile Send celef a Private Message
Det fanns två basar i VR8, en 10:a och en 13 tummare, hur får du det till en 12:a? ;-)
sound pollution
Niklas Nord
Posted - 2002/11/16 :  21:13:07  Show Profile Send Niklas Nord a Private Message
vad ni tjaffsar., det är juh full metal jacket
på tvåan snart..
Crossover frequencies: Virtual "one-way" design, using full range drivers as "main" system, augmented at sub-bass and treble frequencies. The frequencies chosen, 100Hz and 3.5Khz, are well outside the ear’s most sensitive range, allowing full midrange coherency without driver overlap.
Bass system: 13" sub-bass and 10" midbass high efficiency, cast frame drivers using extremely stiff and lightweight paper cones, large 4" voice coils, and huge 6000 gram magnets. Separate periodically vented enclosures are tuned to a sixth order Chebychev alignment which features transient response speed enhancement due to magnetic overdamping and 100% stuffing fill.
Midrange system: Twin 5.5" cast frame drivers, featuring woven carbon fiber diaphragms, edge wound ribbon voice coils, oversized vented magnets, and Norsorex surrounds. All 4 midrange drivers have tested and matched frequency response tolerances to within 1/4 dB.
Treble system: Titanium inverse dome with dioxide damping layer, phase control plate, transmission line loading, Ferrofluid cooling, and enormous 1200 gram magnetic structure.
Ambiance retrieval system: Rear firing midrange / treble driver ( same as front tweeter ) with Ambiance Derivation Circuit and Spatial Dimensional control for effects level.
Frequency response: 16 Hz ( with optional filter ) to 35Khz, +/- 3 DB. ( Midrange +/- 1 DB )
Inputs: Separate pairs of metal posts for woofer, midrange / treble inputs for bi-amping or bi-wiring.
Sensitivity: 96Db @ 1W 1M anechoic, 100 Db measured in room with boundary boost.
Impedance: Four ohms nominal rating. High current tube or solid state amplifiers recommended.
Power recommendations: Five watts minimum, 1000 watts maximum peak input.
Enclosure: Two piece stacking type, with wall thickness varying from 1" to 3" using constrained layer damping techniques and cross bracing. Adjustable midrange / treble module with time aligned drivers.
Weight: 500 lb. ea.
Dimensions 74" H X 18" W X 28" D.
celef
sirap i datorn
Posted - 2002/11/16 :  21:41:05  Show Profile Send celef a Private Message
Tjaffs? Nej, debatt!
FMJ? Den musikintresserade tittar på Fame Factory! ;-)
sound pollution
Alexi
Ute och cyklar...?
Posted - 2002/11/17 :  02:34:26  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Om man är intresserad av musik var man ute och lysnade! Inte hemma och tittade på TV!
"...sixth order Chebychev alignment which features transient response speed enhancement due to magnetic overdamping and 100% stuffing fill..."
Hohoho vilket skitsnack
Driver forumet faktiskt.se
celef
sirap i datorn
Posted - 2002/11/17 :  11:10:43  Show Profile Send celef a Private Message
Chebychev?? Å jag som trodde att de använde EBS!!
"As in the VR-6 enclosure described above, the tuning of the enclosures is staggered between 20Hz and 40Hz to eliminate the dreaded "one note bass" common to ported enclosures. The Theile/Small alignment is an Extended Bass Shelf (EBS) design with a highly damped Qts of approximately 0.5. (Commonly used Butterworth alignments with a Qts of "1" sound thick and slow, but are routinely used by other manufacturers.)"
sound pollution
n/a
deleted
Posted - 2002/11/17 :  12:23:09  Show Profile Send n/a a Private Message
Qts på 0.5 är Chebychev!( has det för sig?, ed )
Mvh A*.
Björn N
Fd. Speakerpro
Posted - 2002/11/17 :  15:22:02  Show Profile Send Björn N a Private Message
Hmm ar det bara jag som tycker att VSR hogtalare ar riktigt fula?
celef
sirap i datorn
Posted - 2002/11/17 :  16:22:29  Show Profile Send celef a Private Message
EBS, röd kurva:
Med Chebychev får jag en ganska peakig avrullning, jag skulle vilja säga nära Q=1 ??
Är det inte märkligt hur benämningen "Qts" används??
sound pollution
AndersP
Posted - 2002/11/18 :  20:34:46  Show Profile Send AndersP a Private Message
Celef: Märkligt är för snällt uttryckt. Åt h*****e fel passar bättre tycker jag. Qts är en småsignalparameter för högtalarelement. Q i det här sammanhanget måste ju vara ett uttryck för formen på avrullningen. I de slutna lådornas värld kallas det för Qb såvitt jag vet.
Äldre farbröder har av nån anledning satt sina efternamn på dom oxo. Chebychev minns jag inte i farten men det är i alla fall inte 0,5 som Audiomaniker skriver, men högre och säkert lite "peakigt". Q 0,5 heter Linkwitz-Riley och Q 0,7 heter Butterworth, men det finns flera, vad man nu ska med den kunskapen till.
Linkwitz Orion
Center: Ino Audio piM
Surround: 6 x Ino Audio a2
celef
sirap i datorn
Posted - 2002/11/18 :  22:51:05  Show Profile Send celef a Private Message
Jag håller helt med!
sound pollution
Magnuz
Posted - 2002/11/19 :  12:05:56  Show Profile Send Magnuz a Private Message
Nja, Linkwitz-Riley är väl 0,49 vill jag minnas och Butterworth är 0.707 om man ska vara petig, och det ska man ju. Chebychev är högre, minns dock ej hur mycket. Jag tror A är ute efter Bessel: Q = 0,577
AndersP
Posted - 2002/11/19 :  14:29:41  Show Profile Send AndersP a Private Message
Jo, men jag använde bara en värdesiffra. Rundar man av så blir det ju som jag skrev. Är du säker på att dina tal inte oxo är avrundade, hehe?
Neodynium
Posted - 2002/11/19 :  18:34:46  Show Profile Send Neodynium a Private Message
Jag hade också en massa dumma ide'er om VR-8'orna. Så för att reda ut vad som är vad så köpte jag ett par.
Joakim
n/a
deleted
Posted - 2002/11/19 :  18:38:30  Show Profile Send n/a a Private Message
Antagligen inte så "dumt" gjort
De verkar spännande ,jag har "bara" VR 4.
CD/Vinyl debatten på 80-talet gav inget!!
Neodynium
Posted - 2002/11/19 :  18:42:48  Show Profile Send Neodynium a Private Message
Inte så bara, vi testade dem igår (HSE GEN 3) med S1,Vincent 991 och Clou Silver Voice. Det lät ruskigt bra. Lite fixat rum oxå.
Joakim
celef
sirap i datorn
Posted - 2002/11/19 :  19:49:56  Show Profile Send celef a Private Message
Nå VR-ägare, fram med insexnycklarna å berätta för oss fabrikat på elementen! :-)
sound pollution
n/a
deleted
Posted - 2002/11/19 :  19:56:18  Show Profile Send n/a a Private Message
"neodynium"
Låter trevligt, jag matar dem med VINCENT 991 "åsså" och CD-S3 men detta är väl att svära i himlen för "fixfolket"
Men jag lyssnar inte på¨mina öron" utan på hjärnan
men det är väl skit samma.
Neodynium
Posted - 2002/11/19 :  23:22:41  Show Profile Send Neodynium a Private Message
"neodynium"
Joakim är inte jag... han brukar skriva här hos mig! Jag kör Mini Utopior och Krell Showcase.. *smiles*
CD-S3 är inte en dålig cd spelare... en sådan körde jag med innan.. dock hade mitt ex lite konstigheter för sig... så jag fick möjlighet att köpa annat dvs fick tillbaka pengarna... så jag bytte.
Joakim har öppnat sina lådor.. och det är de franska elementen som sitter i (basarna).
Niklas Nord
Posted - 2002/12/03 :  14:22:42  Show Profile Send Niklas Nord a Private Message
upp.
nu när det hörts vr8:or i nedre landet
svensson
många inlägg är det....
Posted - 2002/12/03 :  14:45:34  Show Profile Send svensson a Private Message
Jag har VR7:or hemma, grymt ljud. Drömmer vidare om VR8.
Det börja tidigt, så tidigt jag minns....
Niklas Nord
Posted - 2002/12/03 :  15:10:02  Show Profile Send Niklas Nord a Private Message
men kommer inte allt ljud uppifrån?
De ser rent ut sagt mkt dåligt konstruerade ut att vara..
man vill juh höra artisten framför sig, inte från ovan sky.
svensson
Posted - 2002/12/03 :  15:14:08  Show Profile Send svensson a Private Message
Inga kommentarer om mina VR7:or....
dom finns ju inte....
Men VR4 fram och VR3 bak är iaf nåt liknande.
Konstruktionen är det nog inget fel på, däremot
är det dåliga byggen. iaf VR3 och VR4.
Har bytt både terminaler och plasthistorian
som terminalerna var infällda i....
