| Author |
Topic  |
abbot
684 Posts |
Posted - 2006/06/20 : 10:21:24
Jag rotar vidare bland rören. Googlade på 12HG7 och fick bl.a. följande resultat: "The driver
The main peculiarity of the amp circuit, I guess, is the single-tube pentode driver. I experimented quite a bit with the 12HG7 and 12GN7A tubes, both of which are high Gm pentodes designed as video output amplifiers for color TV's. They are amazing devices, capable of providing very low distortion, high gain, and low output impedance all at the same time... much better than you can get with any single triode I've seen.
Here is some performance measurements I took of the driver stage, by itself:
Conditions:
B+ = 400V
Vg2 = 150V (regulated)
Plate load = 4000 ohms
Cathode resistor = 50 ohms, unbypassed
GE 12GN7A RCA 12HG7 5% THD @ 89V RMS (1kHz), 2nd + 3rd + ... harmonics 5% THD @ 100V RMS (1kHz), 2nd + 3rd + ... harmonics 1.8% THD @ 50V RMS (1kHz), 2nd + 3rd 1.2% THD @ 50V RMS (1kHz), 2nd + 3rd 0.3% THD @ 10V RMS (1kHz), all 2nd harmonic 0.26% THD @ 10V RMS (1kHz), all 2nd harmonic 0.12% THD @ 5V RMS (1kHz), all 2nd harmonic 0.12% THD @ 5V RMS (1kHz), all 2nd harmonic Ip = 34.2mA Ip = 34.4mA Ig2 = 5.8mA Ig2 = 5.6mA Vp = 250V Vp = 250V Wp = 8.5W Wp = 8.6W Wg2 = 0.87W Wg2 = 0.84W A = 38 A = 40 -0.23dB @ 20kHz, -2dB @ 100kHz into 100k -0.18dB @ 20kHz, -2dB @ 100kHz into 100k -0.68dB @ 20kHz, -6dB @ 100kHz into 100k + 470pF -0.68dB @ 20kHz, -6dB @ 200kHz into 100k + 470pF
The driver has a very nice harmonic profile, with the 3rd harmonic always below the 2nd. At lower levels, the 2nd is about the only harmonic that's measurable. For some reason pentodes seem to have the reputation for creating more high-order harmonics, but it's simply not true in a single-ended design. This driver tests, and sounds, better than any of the possible two-triode drivers I tried, like 6SN7 direct-coupled, or 6SL7 SRPP. It also does much better than a 6C45pi-E.
I also tried these tubes triode connected with a CCS, and they did well that way - about the same as a 6C45pi did, I guess. But I preferred the pentode connection. Try it, you'll like it!"
www.pmillett.com/813_se_triode_amps.htm - 28k -
Har du/ni någon erfarenhet av detta rör? Har du/ni använt det som utgångsrör och i så fall med vilket resultat? Övriga synpunkter?
8580 Posts |
Posted - 2006/06/20 : 11:49:41
| Jag har haft planer för röret i fråga, men det verkar svårt att hitta några i Sverige |
abbot
684 Posts |
Posted - 2006/06/20 : 13:32:15
| Vilken sorts planer, om man får vara så nyfiken? |
8580 Posts |
Posted - 2006/06/20 : 17:32:44
| Dels som ingångssteg men jag kikade även på att använda dem till nån sorts Spud. |
abbot
684 Posts |
Posted - 2006/06/23 : 12:36:17
| Nu har jag funderat och funderat men gått bet. Jag tror att du gör skäl för ditt namn. Vad är en Spud och till vad använder man en slik? Om jag nu råkat glömma fråga något relevant får du gärna svara på det också... |
8580 Posts |
Posted - 2006/06/23 : 16:46:48
Spud = rörförstärkare med ett enda förstärkande steg. Kräver ett rör med hög branthet och förstärkning, vanligtvis trioder i stil med 6C45 men jag har sett exemplar med högbranta pentoder också. Effektmässigt ligger man ofta under enwattsstrecket... |
7879 Posts |
abbot
684 Posts |
Posted - 2006/06/24 : 00:16:33
| Tack Snygging och Spirella för era svar. 12B4A är det fler som har tipsat om så det är troligen ett bra rör. Anledningen till frågan om 12HG7 är att det är vad jag råkar ha och den här Pete Millet verkar lite entusiastisk i länken jag lagt in. Dina länkar var mycket intressanta soundbrigade.Jag förmodar att du trivs i Lilla Paris (OT). |
8580 Posts |
Posted - 2006/06/24 : 14:13:16
| 12B4 är också ett sånt där fascinerande litet rör som man bara måste älska! |
Topic  |
