 ARC VSI55 och Baby Grand?
Bland
Posted - 2006/03/19 :  11:19:20  Show Profile Send Bland a Private Message
Har börjat tröttna på hifi. Ganska rejält faktiskt, men musik tycker jag om . Nu tar min anläggning mycket plats och vill få en något mindre skrymmande anläggning. Lever idag med Respons Grand (2001) och vill gärna behålla respons. Reidars Baby Grand lockar mycket. Även ARC VSi 55 lockar! Men, klarar ARC VSI 55 att driva dessa högtalare? Det där tekniska kan jag inte så mycket om. Tacksam för svar!
Baby Grand!
Frequency response: 40 Hz - 40 kHz
- High frequency: Full level above 40 kHz
- Echo free: 200 Hz - 20 kHz ± 1 db)
- Low frequency response: -3 db 40 Hz
Sensitivity: 2,83V 85dB/ m
Nominal impedance: 4 ohm
VSi55 Specifications:
POWER OUTPUT: 50 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1% at 50 watts, below .05% at 1 watt. Approximate actual power available at "clipping" 52 watts (1kHz). (Note that actual power output is dependent upon both line voltage and "condition" i. e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH: (-3dB points) 12Hz to 90kHz.
FREQUENCY RESPONSE: (-3dB points at 1 watt) 1.0 Hz to 100 kHz.
INPUT SENSITIVITY: 0.5V RMS Single-ended for rated output. (32 dB gain into 8 ohms.)
INPUT IMPEDANCE: 50K ohms Single-ended.
MAXIMUM INPUT: 3.5V RMS (any input). Optional 6dB pad for CD use.
OUTPUT POLARITY: Non-inverting (any input).
OUTPUT REGULATION: Approximately 1.5 dB 8 ohm load to open circuit (Damping factor approximately 5).
MONO SUBWOOFER OUTPUT: 1V RMS at rated power.
OVERALL NEGATIVE FEEDBACK: 10dB.
SLEW RATE: 10 volts/microsecond.
RISE TIME: 2 microseconds.
HUM & NOISE: Less than 0.14mV RMS - 103dB below rated output (IHF weighted, input shorted).
POWER SUPPLIES: Electronically regulated Low and High Voltage supplies for input stages. Automatic 30 second warm-up/brown-out mute.
POWER SUPPLY ENERGY STORAGE: Approximately 166 joules.
POWER REQUIREMENTS: 100-125VAC 60Hz (200-250VAC 50Hz) 320 watts at rated output, 500 watts maximum, 205 watts at "idle". 0.5 watts power off.
TUBES REQUIRED: (2 ) Matched pair 6550EH - Power Output; (3) 6N1P input and driver.
DIMENSIONS : 14"(35.6 cm) W x 8"(20.3 cm) H x 16"(40.6 cm) D. Rear connectors extend .88" beyond chassis.
WEIGHT: 34 lbs. (15.5 kg) Net; 40 lbs. (18.2 kg) Shipping.
Specifications subject to change without notice.
Tomas
Posted - 2006/03/19 :  18:36:09  Show Profile Send Tomas a Private Message
Skulle tro att du blev mycket nöjd med den kombon. Själv bygger jag ett par 10W single ended steg till mina, det blir lite spännande. Baby Granden mår bra av mycket strömkapacitet och kan sluka enorm effekt, men låter ruskigt bra även med lite mindre. Har lyssnat med ett 80W steg från Airtight och ett 50W slusteg från ARC på stora Grand, och det lät ruskigt bra utifrån förutsättningarna.
MVH
hjort
Posted - 2006/03/19 :  20:26:06  Show Profile Send hjort a Private Message
Det går nog bra, det handlar väl mest om hur högt du vill kunna spela och hur mycket bas du vill ha.
ARC och Respons är mycket trevligt tillsammans.
Bland
Posted - 2006/03/20 :  21:40:58  Show Profile Send Bland a Private Message
Tackar för svar! Vi får se vad som händer!
