 Snygga upp JBL bas koner !?!
imtkjlu
Posted - 2006/03/13 :  11:18:34  Show Profile Send imtkjlu a Private Message
Va tror ni om det här, någon som provat ?
Och vad är pva ?
///Kjelle
But if u want to blacken the cones
wait for a warm day
pva(wood working) glue 40% hot water 60 % or 50%-50% will do
keep mixing through the process
take a cloth a dip it in your water glue mix and go around in circle`s 1 direction till the cone wet,then set it out to dry
the theory goes
that the cardboard takes on the pvc the water resets the cone and dryes off leaving the cone stiffer
i do it ot all my drivers and it makes them look like new
and never had a prob no matter how much i crank them
morbo!
Edited by - imtkjlu on 2006/03/13 14:57:15
imtkjlu
Posted - 2006/03/13 :  11:37:43  Show Profile Send imtkjlu a Private Message
Glömde nämna att det gäller ett par 25 år gamla
JBL 2205A 15 Tums basar.
///Kjelle
