 Audio Research Reference CD7
cybwiz
800.000-klubben
Posted - 2005/11/17 :  08:39:16  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message
Price
$8,995
Description
Compact disc player.
"The CD7 is a Reference Level model to complement the CD3MKII with an even higher performance. Incorporating the strongest aspects of the CD3MKII - its rugged construction, the Philips Pro2 laser mechanism, the Crystal 24 bit DAC, its user friendly menu of useful features and functions - the Reference CD7 breaks new ground with a gain stage taken directly from the REF3, incorporating the latest proprietary capacitor technology found only in Audio Research Reference components.
Using four 6H30 triodes, the audio stage features high voltage regulation using an additional three 6H30s, coupled to a massive power supply. The extensively ventilated top-load chassis is just slightly deeper front to back than the CD3MKII. Height is unchanged, while a thicker front panel helps identify the CD7 as a Reference product. Inputs, outputs and the accompanying remote are identical to the CD3MKII. The standby function on the CD3MKII is now a power on/off function on the CD7, with an LED indicator on the front panel, since this is a vacuum-tube product.
Is the CD7 really much better than the CD3MKII? Yes, it is in every aspect. The sonic background is quieter and blacker, thanks to noise and distortion figures that are significantly lower than those of the CD3MKII. Musical dynamics and sheer openness of the soundstage are also much improved, in part due to the massive power supply and carefully chosen parts. You will also hear dynamic nuances that render small ensemble recordings much more believable and vivid. Notes and sounds have more individual shape, body and location as they appear and recede. The soundstage expands and breathes as the recording calls for it. Bass response is massive and tuneful. The CD7 simply has a natural speed and ease without coloration and it is truly like the REF3 in this regard. There is a weight and harmonic completeness one expects from a reference level vacuum-tube product.
http://cybwiz.blogspot.com/
Edited by - cybwiz on 2005/11/21 21:28:29
Posted - 2005/11/17 :  09:47:07  Show Profile  Visit Zalve's Homepage Send Zalve a Private Message
Posted - 2005/11/17 :  09:53:36  Show Profile Send EngelholmAudio a Private Message
Detta är verkligt imponerande och intresserande (!) då detta var en av de paradgrener jag upplevde när jag hade CD3'an hemma.
6H30-trioderna har blivit väldigt populära!
Posted - 2005/11/17 :  10:43:01  Show Profile  Visit Pac's Homepage Send Pac a Private Message
Jo, 6H30 har blivit kommersiellt tillgänglig först under senare år. Det fanns begränsningar på vem som fick köpa dessa rör fram till för bara några år sedan. BAT var den första tillverkaren som fick använda röret kommersiellt utanför militärindustrin...
freann
Posted - 2005/11/17 :  11:44:09  Show Profile Send freann a Private Message
Ser ut att vara en väldigt trevlig maskin. Många rör - är det tre rören likriktarrör?
Den mest "fabriks-tweakade" spelaren hittils?! Från AR dessutom.
MartinH
Audiotrade
Posted - 2005/11/17 :  13:23:23  Show Profile Send MartinH a Private Message
Roligt med de små fyrkantiga duttarna på varje onding och på närkomponenterna...
Och rör ringar direkt på alla rör, snyggt !!
Men smakar det, så kostar det... Undrar vad den kommer landa på här i Sverige ?!?
/M
Posted - 2005/11/17 :  13:28:06  Show Profile  Visit Pac's Homepage Send Pac a Private Message
Det är svårt att avgöra vad de olika rören har för funktion. Enligt ARCDB är alla rören 6H30 och de tre som sitter till höger i bild skulle enligt dem vara spänningsreglering.
Men, det finns mer roligt att kommentera på bilden. Som vanligt har de varit nogranna med valet av komponenter. De fyra kondensatorerna till höger i bild verkar vara någon typ av oljekondensatorer och de skulle då kunna vara utgångskondensatorer. Hela linjesteget verkar vara uppbyggt med kolresistorer. Jag tycker mig se både kolfilm och kolmassa. Trafon är en R-core, mer om deras för/nackdelar kan man läsa här: http://www.custommag.com/products/r-core.shtml
Klockning, drivestyrning och DAC'ar ser jag inte alls... De funktionerna sitter nog under driven.
ARCDB har tydligen lyssnat till denna pjäs också, mer om det här: http://www.arcdb.ws/REFCD7/REFCD7.html
Klart intressant spelare.
Posted - 2005/11/17 :  14:56:49  Show Profile Send EngelholmAudio a Private Message
Lite OT kanske: Vad kostar 6H30-rören? Finns det olika märken? Olika signaturer på ljudet?
Vem säljer dessa? (PM välkomna)
Mattias
Posted - 2005/12/13 :  21:29:48  Show Profile Send Mattias a Private Message
Nu finns CD7 på ARC-s hemsida under nya produkter.
http://www.audioresearch.com/
/Mattias
Edited by - Mattias on 2005/12/14 08:42:22
