 R2904/700000 measurements file......
mauro
Posted - 2005/08/01 :  18:49:13  Show Profile Send mauro a Private Message
hi,
does somebody measured the R2904/700000 scan-speak tw ??
i need the measurements file in frd or txt format.........also other formats are good.
please help me!
regards.
Posted - 2005/08/01 :  19:49:11  Show Profile Send EngelholmAudio a Private Message
Is this what you're looking for (but in .txt format?
Mail me or if any one else whants it I could put it as downloadable file from my homepage.
nl
Posted - 2005/08/01 :  21:12:05  Show Profile Send nl a Private Message
Jag skulle väldigt gärna vilja ha filen. Har du en på Vifa P17WJ-00-08 också? Är intresserad av att simulera med dom två elementen. Jag vill få fram ett första utkast på filter till mina byggen. Visst funkar txt-formatet i LSPCad?
mauro
Posted - 2005/08/02 :  15:10:10  Show Profile Send mauro a Private Message
i've sended you an e-mail,do you recieved it??
please answer.
regards
Posted - 2005/08/02 :  15:20:48  Show Profile Send EngelholmAudio a Private Message
Frequency file:
http://www.engelholmaudio.com/tmp/ScanSpeakRingRadiatro.txt
Impedance file:
http://www.engelholmaudio.com/tmp/ScanSpeakRingRadiatroIMP.txt
..since there was more than one interested.
Ps. I did not receive any mail, Mauro.
nl
Posted - 2005/08/03 :  11:00:23  Show Profile Send nl a Private Message
Tack så mycket
Posted - 2005/08/04 :  10:49:45  Show Profile Send EngelholmAudio a Private Message
You're welcome, nl!
mauro
Posted - 2005/08/07 :  18:40:19  Show Profile Send mauro a Private Message
hi EngelholmAudio,
thank you very much for the meas. files.
what measure system do you use?
if no message arrived to you probably my server crasches.....that's life.
regards
muro
Edited by - mauro on 2005/08/07 18:42:32
Posted - 2005/08/07 :  18:41:59  Show Profile Send EngelholmAudio a Private Message
I used Clio Standard with the Clio microphone and a Rotel 931 mk II integretad amp.
Take no interest in the SPL since I didn't calibrate it to 1 meter anv 2.83 volt.
mauro
Posted - 2005/08/07 :  18:44:55  Show Profile Send mauro a Private Message
ok,
thank you.
regards
mauro
