 i'm searching scan-speak tw measurement files.
mauro
Posted - 2005/04/05 :  09:31:04  Show Profile Send mauro a Private Message
hi,
i'm searching for the measurement file of two scan-speak tw.
- d9700
- d9900 revelator
does somebody measured them and has the measurement file??
thank you.
rgards.
Posted - 2005/04/05 :  09:56:33  Show Profile Send EngelholmAudio a Private Message
Hi Mauro,
On my home site, www.engelholmaudio.com, I have measurements for the Scan Speak S2905/9700 in the EALS-3 loud speaker. You'll find it under "Downloads".
Both your tweeters behave as they should: minimun phase shift and could also be considered high pass function.
