 Ny orginal Leonardo?
delight
Posted - 2005/02/12 :  22:59:23  Show Profile Send delight a Private Message
Hittade lite bider på orginals Leonardo, med utseénde jag inte sett förut. Klart brutalsnygg!
Översatt texten med babbelfisk
Uses PHILIPS VAM12 series laser collecting; . Uses the electric circuit board integration design, soon the PHILIPS servo electric circuit, the power circuit, the digital processing electric circuit, the DA switching circuit, the analog output electric circuit integrates designs together on the bigger electric circuit board; . Uses PHILIPS the CD7- II servosystem, specially is software which "Leonardo" designs; . In sets at the HDCD decoding and the digital filter, uses Micro Soft digital filter chip PMD200, DAC is PCM1704 divides into the independent two sound tracks to output; . By two Shan Yunfang OPA627, OPA604 adds double to transport puts 5532 to take the filter and the analog output part, and has designed the entire balanced output for it; . "Leonardo" has had the super function which the overwhelming majority CD broadcast machine cannot compare. It has realized to several audio frequency specifications different processing way: Namely retained the 20Bit/96KHz HDCD processing way; Entire synthesizes 24Bit/176.4KHz again the 16Bit/44.1Khz data the number symbol stream, this specification is equal with 24Bit/196KHz; Entire synthesizes 24Bit/352.8KHz again the 16Bit/44.1KHz data the number symbol stream; "Leonardo" has produced these three specifications, also is three kind of sounds. In other words is: If is the HDCD small dish piece on by the original specification 20Bit/96KHz broadcast, other CD small dish piece may choose two kind of patterns outputs, one kind is the 24Bit/176.4KHz output; Another kind is the 24Bit/352.8KHz output. Machine three kind of sounds, indeed are extremely rare, it has fully manifested #21407;#21019; company's in CD broadcast machine manufacture technology outstanding strength. . In sets at two groups high quality to move in a circle the transformer and the enclosed transformer #38548;#31163;#20179;, effectively isolates the electronmagetic interference; . "Leonardo the" outward appearance design is unique, has used the firm circular aluminum alloy tray in the main body structure, on uncovers Ge Shi to design, lets the PHILIPS machine core stably aerosol on the aluminum alloy tray, coordinates the outer space warehouse -like roof panel as well as the red assistance light which passes from the plate warehouse, #19968;#30524;#26395;#21435; then instantly leads you in the beautiful logical sequence beautiful imaginary boundary. Entire machine by four circulars aluminum alloys foot column strut, moreover may wilfully correct the strut altitude; . The disposition simulates RCA, the balanced output, Digital coaxial, the optical cable outputs each group. Technical specification: Signal to noise ratio: 110dB, 1KHzJF, -122dB power output: RCA: 1.5Vpps balance: 1.5Vpps tendency: 120dB (24Bit) frequency response: 5Hz ~ 20KHz
Leonardo was basically summarizes the recent years to possess about CD work Player audio frequency characteristic integration. Leonardo take the traditional 16Bit/44.1KHz specification (the traditional CD Player audio frequency specification) as a foundation, and in this foundation General 16Bit/44.1KHz specification through technical method promotion for quite Yu Zuixin SACD audio frequency specification, also was transforms the early 16Bit/44.1KHz audio frequency specification number symbol stream after technical processing 24Bit/176.4KHz and the 24Bit/352.8KHz digital form, 24Bit/176.4KHz is equal to the present SACD audio frequency specification, but 24Bit/352.8KHz was has promoted 8 time of sampling frequencies in the original 16Bit/44.1KHz this audio f
hobbes
Posted - 2005/02/12 :  23:19:41  Show Profile Send hobbes a Private Message
Jag blev väldigt sugen på den första gången jag såg.. (På grund av utseendet ) Men tyvärr var den lite för dyr ( Eller rättare sagt mycket för dyr för mig..)
Bravo
Posted - 2005/02/13 :  02:54:44  Show Profile Send Bravo a Private Message
Brutal var ordet, vad kostar den då?
Bravo
hobbes
Posted - 2005/02/13 :  05:56:57  Show Profile Send hobbes a Private Message
US$2500 plus frakt/moms/tull...
Bravo
Posted - 2005/02/13 :  06:03:11  Show Profile Send Bravo a Private Message
Det blir en del ja, men trots allt inte så svindyr som jag trodde först. Fast visst räcker det till.
Bravo
Aton
Posted - 2005/02/15 :  23:35:12  Show Profile Send Aton a Private Message
Elegant! Men vilken dammsamlare den halvöppna CD-skålen blir.
