 Primare CD 31
Twincam
Posted - 2004/11/30 :  09:46:48  Show Profile Send Twincam a Private Message
Primare Systems, Växjö, Sweden. 1st December 2004:
A devotion to the cause of musical integrity has compelled Primare’s engineers and designers to seek ever more innovative ways to capture the spirit of the original recording. Their all-consuming passion has succeeded in further refining the Primare D30.2 CD player to create the CD31. The new player makes a definitive statement of Primare’s elite electronic and aesthetic design ethos. Utilising fully balanced low-noise topology throughout, and the finest discrete circuit components, the beautifully conceived CD31 will transcend expectations to deliver musical exhilaration, pure and simple.
For the CD31, Primare has selected precise transport, a very high quality 24 bit DAC for the 96kHz sampling mode, a matching high performance 24/96 filter, and an ultra-noise, high-speed output stage to preserve every musical nuance. Multiple isolated low noise power supplies are used to keep the musical signal free of electrical interference to exploit the full potential of the CD31’s balanced design.
Primare’s no-compromise design regimen is applied throughout the player, right down to the gold-plated analogue, digital and balanced outputs, and its sleek, elegant heavy-steel exterior, which matches the other 30 Series designs. The result is pure music, unsullied by the usual limitations of the CD format, from a CD player that exemplifies in every way, Primare’s approach to sound engineering.
-No compromise audiophile design and construction
-4 x Burr-Brown 1704 K grade audio DACs in a fully balanced topology
-Burr-Brown DF1704 high performance 8 x oversampling digital filter
-Multiple high performance low noise power supplies
-High quality 1% Metal film Resistors
-FET output device.
-Main power filter
-R-type transformer power supply with separate windings for analogue, digital and mechanism.
Primare CD31
Approximate retail price:
Availability:
Established in 1987, Primare Systems is a leading Swedish designer and manufacturer of high performance stereo and audio/visual products, dedicated to absolute fidelity and cutting-edge aesthetic design. www.primare.net
Ledzepp
Posted - 2004/11/30 :  11:09:32  Show Profile Send Ledzepp a Private Message
Hittar inget på deras sida om den???
Twincam
Posted - 2004/11/30 :  11:12:41  Show Profile Send Twincam a Private Message
Skall komma så småningom... Kanske inte förrän tidigast imorrn, då pressmedelandet är daterat 1 dec!?
Bubben
Posted - 2004/11/30 :  11:14:13  Show Profile Send Bubben a Private Message
Det var ord och inga visor...
Kan denna verkligen hamna runt 20k?
Ledzepp
Posted - 2004/12/02 :  12:17:56  Show Profile Send Ledzepp a Private Message
Twincam, vad är det för pressmedelande?
Finns inte på hemsidan än, idag är det den 2/12!!
Twincam
Posted - 2004/12/02 :  17:55:40  Show Profile Send Twincam a Private Message
Fick det från Audioactive när jag mailade en förfrågan om CD31. Den finns ju redan ute i butik, iallafall hos Esoterisk.
Harman
Posted - 2004/12/02 :  21:05:55  Show Profile Send Harman a Private Message
Primare brukar alltid vara sena ut med deras info på hemsidan.
Esoterisk hade väl CD21 innan hemsidan presenterade den oxå...
Mvh Dan
*Iron Maiden*
Ledzepp
Posted - 2004/12/03 :  08:44:37  Show Profile Send Ledzepp a Private Message
Esoterisk har för vana att lägga ut produkter flera veckor
innan dom har den i butik!
matte76
Posted - 2004/12/03 :  10:18:08  Show Profile Send matte76 a Private Message
Den finns hos HiFi skåne i Malmö också, jag ska låna hem den imorgon och jämföra med Primare CD21 och Naim CD5i.
- Blått ett lag - Malmö FF!
Denna sida genererades på 0.79 sekunder. Snitz Forums 2000
