 Rör till försteg.
emil
Posted - 2004/11/10 :  15:39:53  Show Profile  Visit emil's Homepage Send emil a Private Message
I mitt försteg sitter det 2 rör i nätdelen som heter 5687. Har ringt runt och kollat om man kan få tag i dessa rör men det är ingen som känns vid denna varianten.
Finns det någon här på forumet som vet var man kan få tag på 5687or?
Rydberg
Posted - 2004/11/10 :  17:08:45  Show Profile Send Rydberg a Private Message
Tror Roland har: http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=22763&whichpage=1
Ibland kan man använda E182CC istället, sådana har jag själv till salu.
7119 / E182CC
The 7119 (known in Europe as the E182CC) is another computer tube which was developed by Amperex in the 1960s. Electronically equivalent to the 5687, the 7119 has much larger plates and can provide an additional 4dB of gain over its smaller rival. Objectively, it's actually more neutral than the 5687, but suffers on bright (mainly popular) recordings and can compound the edginess of many commercial loudspeakers, especially those which are bright to begin with. In our preamp, it performs best with classical music recordings, especially RCAs, Deccas, and Mercurys from the Golden Age (1957-1964), as well as on well engineered pop albums. Virtually all were sold under the Amperex brand, either made in Holland at the Philips plant or in the USA at the company's original Hicksville, Long Island, factory.
Edited by - Rydberg on 2004/11/10 17:11:02
niro116
Posted - 2004/11/10 :  17:18:13  Show Profile  Visit niro116's Homepage Send niro116 a Private Message
Stämmer bra Ola. Jag har också 7119/E182CC.
Jag ska återgälda din generositet.
Roland!
Tu-be or not tu-be. H.L Eisenson.
niro116
Posted - 2004/11/10 :  17:18:15  Show Profile  Visit niro116's Homepage Send niro116 a Private Message
Roland!
emil
Posted - 2004/11/10 :  17:59:17  Show Profile  Visit emil's Homepage Send emil a Private Message
Låter bra, så med ekvivalenterna till 5687orna så är det bara att plugga dem rätt in i socklarna och köra utan några som helst modifieringar dvs det är samma rör med samma egenskaper? Behövar man tänka på något speciellt när det gäller rör till likriktningen i mitt försteg man kan väl knappast höra någon skillnad om det är olika fabrikat på nätdelssidan?
I själva linje delen sitter det 2st ECC82 och 1st ECC83 vad har ni för favoriter som jag kan prova här dvs vilka tycker ni låter bäst?
Jag lyssnar på väldigt blandad musik.
Rydberg
Posted - 2004/11/10 :  18:10:18  Show Profile Send Rydberg a Private Message
emil> Jag tycker nog du ska köpa orginal 5687 från Roland så vet du att det blir rätt även om det säkert funkar fint med E182CC.
Vad det gäller ECC82/ECC81 så är ju Telefunken naturligtvis ett starkt kort.
emil
Posted - 2004/11/10 :  18:23:33  Show Profile  Visit emil's Homepage Send emil a Private Message
Jag kan inte hitta några 5687or i Rolands lista, är det vanligt att man andvänder 5687or som likriktare?
Rydberg
Posted - 2004/11/10 :  18:29:11  Show Profile Send Rydberg a Private Message
Kolla igen på Rolands annons
Utdrag:
http://bildarkiv.hififorum.nu/niro/IMGP0371.JPG E180CC, E80CC, 5687,
RCA 5692 "red base" http://bildarkiv.hififorum.nu/niro/IMGP0249.JPG
5687 är inget likriktarrör utan en dubbeltriod.
emil
Posted - 2004/11/10 :  18:34:17  Show Profile  Visit emil's Homepage Send emil a Private Message
Konstigt det sitter två ECC82or samt ett ECC83 och två 5687or i mitt försteg ECC82orna samt 83an måste ha med linjesteget och riaan att göra men vad har då 5687orna för funktion?
niro116
Posted - 2004/11/10 :  18:58:47  Show Profile  Visit niro116's Homepage Send niro116 a Private Message
Hej Emil.
5687:orna sitter förmodligen i linjesteget. Vad är det för försteg? Har du något schema eller länk till ett schema så ska jag genast förklara för dig hur det hänger ihop? Som Ola säger, "5687 är en dubbeltriod", inget likriktarrör.
Roland!
emil
Posted - 2004/11/10 :  19:14:45  Show Profile  Visit emil's Homepage Send emil a Private Message
Jag har schemat på mitt jobb så jag kan maila det till dig imorgon bitti, skriv gärna din mail här så skickar jag schemat till dig.
Det är ett moddat Marantz LS7 försteg.
niro116
Posted - 2004/11/10 :  19:32:11  Show Profile  Visit niro116's Homepage Send niro116 a Private Message
Skicka till tango4@telia.com
Roland!
Posted - 2004/11/11 :  00:24:55  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Tycker E182CC skiljer sig alltför mycket från 5687 för att vara ekvivalent. Jag har testat med E182CC i mitt slutsteg (designat med 5687) och det lät inte bra alls. Andra komponentvärden måste ändras för att få det rätt med E182CC.
Billington har 5687 liksom Etols. http://www.halfin.com/etols/html/vacuum-tube.htm
http://www.bel-tubes.co.uk/ Ligger runt en hundring styck.
Är det fel på rören?
Edit: Såg att Roland har rören, det var ju bra.
Edited by - Bernt Jansson on 2004/11/11 00:35:02
emil
Posted - 2004/11/11 :  07:56:04  Show Profile  Visit emil's Homepage Send emil a Private Message
Nej det är inte fel på rören men när jag öppnade locket så¨kände jag inte igen beteckningen på rören och blev lite små svettig man kanske inte kunde få tag på rören längre och det hade varit mindre kul.
Posted - 2004/11/11 :  07:59:45  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Aha, nä det är inga svåra rör att få tag på.
