 Dynaudio 30W100
Fimax
Posted - 2004/10/15 :  22:03:22  Show Profile Send Fimax a Private Message
Hej,
någon som vet om baselementet Dynaudio 30W100XL?
/filip
ZAC
Posted - 2004/10/16 :  10:52:50  Show Profile Send ZAC a Private Message
Driver parameters:
Qts=0.400
Fs=22.00 Hz
Vas=8.76 cu. ft
SPL=92.0 dB 1W 1m
max power=450 W RMS
Diameter=0.305 m
Xmax=0.009 m
Larsen
Posted - 2004/10/16 :  16:15:18  Show Profile Send Larsen a Private Message
Jag kompletterar med mer uppgifter
____________4ohm_________8ohm
Qm__________2.3__________2.4
Qe__________0.5__________0.5
Ot__________0.4__________0.4
Fs__________22___________22_____hz
Zmax________21___________21_____ohm
Mms________48___________48_____g
BL__________7.1__________8.2____Tm
Vas_________248__________248____lit
Sd__________400__________400____sqrcm
Xmax p-p lin__9____________9______mm
Xmax p-p_____28__________28_____mm
Talspole
Dia_________100__________100____mm
Längd_______17___________17_____mm
Lager_______2____________2
Le__________0.45_________0.65___mH
Zvc_________4____________8______Ohm
Re__________3.75_________5.35___Ohm
Effekttålighet
Nominal long term IEC____130 W
Transient 10 ms_________1000 W
Vikt________2.3 kg
Dimensioner 300x105 mm (diameter x djup)
Edited by - Larsen on 2004/10/16 16:32:47
Fimax
Posted - 2004/10/16 :  17:14:21  Show Profile Send Fimax a Private Message
Tack, men det jag mest undrade om den låter BRA eller inte... Lämplig för subwwofer eller högtalare osv.
/filip
