 Nac202 har väll bara din?
Jazz
Posted - 2004/10/09 :  08:13:55  Show Profile Send Jazz a Private Message
Eller finns det även rca???
Följ
10
Posted - 2004/10/09 :  09:37:38  Show Profile Send 10 a Private Message
Om det är NAC 202 du menar (och det är det ), har den både och. http://www.naim-audio.com/products/nac202.html säger:
The six inputs on the Naim NAC 202 can be selected directly from either the front panel or the NARCOM system remote. In addition to the usual DIN plug inputs, preferred for their superior earthing and impedance matching, two of the inputs can be configured for use with the more common RCA phono connectors, allowing a wide range of non-Naim cables and components to be used.
(min kursivering).
Edited by - 10 on 2004/10/09 09:38:23
Jazz
Posted - 2004/10/09 :  09:48:26  Show Profile Send Jazz a Private Message
Tackar för ett snabbt svar!!!
Följ
Denna sida genererades på 0.26 sekunder. Snitz Forums 2000
