 Pioneer Vsa E07 Surroundförstärkare THX ultra
Carlos
Posted - 2004/07/02 :  20:52:04  Show Profile Send Carlos a Private Message
Jag är även intresserad av att byta mot ett slusteg.
Saker jag kan slänga in i bytet, velodyne Hgs 10, Audiovector Avangarde AV3C center i körsbär(2 mån gammal ,knappt spelad) och pengar.
Allt är i jättefint skick.
Nypris 17000
Pris 7000 eller bud
oliva88oliva@hotmail.com
Tel 0704-600754
Så länge annonsen finns kvar gäller den
5.1 kanaler, Dolby digital, DTS, 5x130 watt
THX 5.1 Ultra Certified
Dolby Digital/Dolby Pro Logic Surround/DTS/MPEG
5.1 channel input
130W DIN 6 Ohms
96 kHz/24-bit D/A Converter
5-channel Equal Power (Accurate Imaging System)
New High-Speed DSP Chip
6 DSP mode
4-mode Advanced Theatre: Musical, Drama, Action, 5-D Theatre
Digital Noise Reduction
Midnight listening mode
New back-lighted liquid crystal touch panel Remote control
Laserdisc RF input
Dolby Digital RF input
External decoder input
Direct energy MOS FET circuit
LCD touch screen remote
New Remote Controllers
This remote features a back-lighted liquid crystal touch panel. Most major AV products are already memorised as presets. And their prodigious memory is eager to expand - to learn new codes of non-preset products and special functions. The macro learning function even memorises operation of multiple product into one key (9 macros available). The new design enable more comfortable, centralised operation of your home entertainment system.
Midnight Listening Mode
If others are sleeping or studying, trying to enjoy a program quietly shouldn't compromise such sound qualities as surround effects or dialogue clarity. Midnight Listening Mode can adjusts subwoofer, rear and centre speaker levels, while enhancing delay and compressing dynamic range, for greater enjoyment of cinema-like sound at low volume.
Specifications
Power output (1 kHz): 130W (6#937;)
Surround: 130W + 130W (front) (6#937;), 130W (centre) (6#937;), 130W + 130W (rear) (6#937;)
Dimensions: (Width, Height, Depth) 420mm, 173mm, 470mm
Weight: 17.2Kg
Edited by - Carlos on 2004/07/03 09:18:29
