 Velodyne HGS 10 säljes eller bytes mot slutsteg
Carlos
Posted - 2004/06/07 :  16:19:39  Show Profile Send Carlos a Private Message
Veldyne HGS 10 säljes eller bytes mot slutsteg eller förstärkare)
Föregångaren till Velodynes nya DD sub
Jag är även intresserad av att byta mot ett slusteg.
Saker jag kan slänga in i bytet, Audiovector Avantgarde av3c center i körsbär(2mån gammal, knappt spelad), Pioneer vsa-e07 THX ultra surroundförstärkare och pengar.
Allt är i jättfint skick
oliva88oliva@hotmail.com
Pris 9900 eller bud
Nypris 25 000kr
tel 0704-600754
Så länge annonsen finns kvar gäller den
Min är i svart pianolack
• 10" subwoofer with tandem 3" voice coils & 310 oz. motor
• Built-in 1000/1250 watt (RMS) Peak 3000 watt high efficiency class D amplifier
• Accelerometer based servo control system for extreme accuracy
• Adjustable (40 to 120Hz) low-pass crossover (defeatable)
• Multiple staggered low-pass crossovers; 12dB/octave initial,
48dB/octave ultimate
• Line-level (RCA) inputs & outputs
• 80 Hz high-pass crossover output
• Signal sensing auto turn on/off (defeatable)
• Variable volume control
• Selectable phase control (0#730; or 180#730;)
• Selectable subsonic filter (20Hz or 35Hz)
• Frequency response of 20Hz - 120Hz +/- 3dB
• Detachable power cord
• Anti-clipping circuit prevents over excursion & amp clipping
"If you know subwoofers, you know about Velodyne."
-Corey Greenberg
Home Theater Technology/February 1995
Face Off: Comparison of five subwoofers
"...the HGS-10 can be used in settings where a larger, more conventional
subwoofer would be unacceptable. In addition, its performance
enough that it's worth considering even if space is not an issue.
prepared to watch your friends' jaws drop when you tell them
they're hearing is coming from that little box."
-Robert Deutsch
Stereophile Guide to Home Theater/September 1998
Maila med förslag
Edited by - Carlos on 2004/07/03 09:40:51
