 Byte av kondensatorer i Sonic Frontiers!?
eliot
Posted - 2004/04/18 :  21:15:58  Show Profile Send eliot a Private Message
Hej,
jag läste nedanstående på http://ecoustics.audioreview.com/:
Review Date:
January 21, 2002
Product Model Year:
1998
Summary:
I own this unit for over 2 years and it doesn't even come into my mind to swap it for sth. else. The stock unit sounds really good (especially with comparison to transistor Wadias, Levinsons) but there is still a room for huge improovement. First of all - the unit MUST (!!!!) have capacitors changed. After replacement of only 6 WIMA caps for Auricaps (1.0uF 200V) the sound became much more detailed, transparent, full bodied, with much better localization, wider and even deeper sounstage. Amazing, especially considering small cost of the caps change. Second recommended upgrade concerns tubes - (I changed for Edicrons - more delicate and clear than stock Sovtecks).
The third improovent that should be made is the use of a good powercord. It may improove SFCD1 dramatically. With these upgrades the sound is simply REAL and most analoglike possible from the digital source (even SACD players I heard don't come even close).
If you own SFCD1 and want to change it for separate combos, do yourself a favour before waisting your money and make upgrades I mentioned above. First of all CHANGE THE CAPS !!!
Strengths:
musicality, harmonic richness, imaging, depth of the stage (analog-like)
Weaknesses:
none (after some upgrades)
Similar Products Used:
Sonic frontiers SFD2 mkI DAC, EAD 7000mkII DAC, Audio Logic DAC model 34, Wadia 860 CD player
- Jag har bytt rör och har en bra nätkabel
Min är från maj 1996 och har 12st ERO 1uF/250V (6st per kanal) som ser ut precis som WIMA brukar se ut, så det är säkert de han menar. Skall man köpa Auricap som finns på Partsconnexion http://www.partsconnexion.com/ för $8.50 eller Mundorf MCap Zn som finns på GoldenAge Music för 92kr eller någon annan - vad rekommenderas ?
Skulle vara tacksam på tipps! Har moddat mycket men då inte köpt speciellt dyra komponenter utan det har mer varit tekniskt knowhow som gjort utslaget....
Sven
Winston Churchill
Edited by - eliot on 2004/04/18 21:54:40
eliot
Posted - 2004/04/18 :  21:52:41  Show Profile Send eliot a Private Message
Här finns en recension av Auricap: http://www.tnt-audio.com/accessories/auricap_e.html
Här finns en bra DIY-länk för köp av kondensatorer och klocka: http://www.audiotuning.de/
Winston Churchill
Mattias S
Posted - 2004/04/18 :  22:43:23  Show Profile Send Mattias S a Private Message
SCR kondinga från elfa är inte så dåliga. Riktigt bra faktiskt.
Mvh // Mattias S
Anläggning: imac 27" - Audirvana Plus - Supra usb cable - Resonessence Labs Concero HP DSD hörlursförstärkare / dac - B&W P7 Wireless
rejvgudrun
Posted - 2004/04/19 :  09:14:14  Show Profile Send rejvgudrun a Private Message
Tony Gee har lite åsikter:
http://home.hetnet.nl/~geenius/CAP.html
________________________
PRAGA MATER URBIUM
bambadoo
Posted - 2004/04/19 :  11:09:00  Show Profile Send bambadoo a Private Message
Da har du vel leste denne billedreportasjen fra et fremragende hififorum medlem :-)
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=24235
MCap supreme silver/oil kan anbefales.
Denna sida genererades på 1.2 sekunder. Snitz Forums 2000
