 Vem vill hjälpa mig å "fantasiklona"... ;)
Dazzin
Posted - 2003/11/05 :  00:33:01  Show Profile  Visit Dazzin's Homepage Send Dazzin a Private Message
Påminner om seas element, allt jag kan själv
Värden på spolarna?
Lådvolymen?
Skulle definitivt va kul å lyssna på!
Edit: Hittade lite speccar:
RMD-cabinet (Resonance Minimising Design) crafted in tounge and groove, all walls made from 1,5" HP-MDF
2 x 6,5" SEAS EXCEL woofers with a modified magnesium-diaphragm, chromium-plated copper-phaseplug
28 mm SCAN SPEAK "REVELATOR"-tweetersystem, special coated cover plate
mechanical and pressure isolated passive crossover network laid out with ultra low tolerance components
exclusive use of SUPREMECAP™ MKP-capacitors, metalfilm-resistances and air-core-inductors for longest term stability
extremly linear frequency response, excellent step response, optimised phase and group delay
100 Ampere binding posts, goldplated, finest coaxial cable inside (free option: 4 inputs for bi-amping)
serial accessories: flightcases, chromium plated spikes with chromium plated bottom plates, microfibre-cleaning cloth, owners manual book (finest handmade leather) with its personal measurement protocols
serial cabinet finish: high gloss polished midnight black (real 10-layered piano lacquer, handpolished)
optional extra: high gloss polished noble woods in bubinga, amber maple or pyramidic mahogani (real 10-layered transparent piano lacquer, handpolished)
optional: original metal efect acrylic lacquer in silvergrey, bordeaux, ocean blue or any other colour
drivers: 2 x 6,5" woofers, 1 x 1,1" tweeter
nominal power input: 100 / 250 VA
nominal impedance: 4-6 Ohm, easy to drive with tube amps
frequency response: +/- 1,7 dB from 31 Hz - 23.000 Hz, F3 = 31 Hz
recommended amp input: quality instead quantity, 50 watts or more at 8 ohms
efficiency: 86 dB (real measurement)
dimensions: 46" x 9,6" x 14,3" / 117 cm x 24 cm x 36 cm
weight: approx. 324 lbs. / 162 kg (pair / incl. packaging)
Källa: http://www.tidal-audio.de/english/piano1.htm
Edited by - Dazzin on 2003/11/05 00:34:52
Niklas Nord
Posted - 2003/11/05 :  00:35:00  Show Profile Send Niklas Nord a Private Message
är det verkligen bra med så mycket komponenter i ett delningsfilter.
hmmmm
Kemppi
Posted - 2003/11/05 :  00:49:02  Show Profile Send Kemppi a Private Message
NN: Ja det varkar ju vara massa skit i filtret som MIT-Mulitcap bla (för visst är det de som sitter där).
*ironisk*
Du säger svetsa. Jag säger stabilt! Bor inte i fjollträsk.
Edited by - Kemppi on 2003/11/05 00:50:43
Dazzin
Posted - 2003/11/05 :  00:51:36  Show Profile  Visit Dazzin's Homepage Send Dazzin a Private Message
hoho
Ja, det låter nog bra iaf det där, skulle jag tro.
Kemppi
Posted - 2003/11/05 :  00:52:23  Show Profile Send Kemppi a Private Message
ja lådkonstruktionen verkar då iaf inte vara något fel på. Fina element med. Kanske det enda som är synd är att de inte lyxat till det med foliespolar. Foliespolar är förövrigt ypperliga att göra högtalarkabel av synd att de blir lite ömtåliga bara
Edit:
"mechanical and pressure isolated passive crossover network laid out with ultra low tolerance components
exclusive use of SUPREMECAP™ MKP-capacitors,"
Visst är det samma om MIT-Multicap. Eller iaf liknande?
Edited by - Kemppi on 2003/11/05 00:56:35
MaxMartin
Posted - 2003/11/05 :  14:15:54  Show Profile Send MaxMartin a Private Message
Jag tycker det ser ut som Audyn-Cap som vi säljer. Spolarna ärt också från Intertechnik. Inte jättedyrt precis...
