 Nordost Quattro-Fil XLR 1m SÄNKT PRIS
gromit
Posted - 2003/09/30 :  19:01:11  Show Profile Send gromit a Private Message
Nordost Quattro-Fil XLR 1 m.
Nyskick, finns i Linköping.
Detta är en mycket bra kabel, detaljerad, neutral och snabb. Den har inte alls den spretighet som Nordosts billigare kablar kan ha.
Nypris: Mer än 15000 i XLR-version.
Mitt pris: 8000 kr
"Nordost Quattro Fil may very well be the best audio cables on the
planet. Looks like they had better add a few employees,
because Quattro Fil is a winner.
(Secrets of Home Theater and High Fidelity, jan 1999)
"Nordost Quattro Fil interconnects. There is no better interconnect. Compared with the competition (and there’s a world of it out there), the Quattro Fils are virtually invisible sonically. There is no signature that I can, at this point in my explorations, detect. This has been true, as it is with all Nordost products, in every system in which I’ve used them. Built to Nordost’s exacting standards, and technical marvel in construction, this continues Nordost’s string of excellences in design, with hardly a misstep - the Red Dawn cables excepted - in the bunch. Most impressive to me is the way the Quattros let the music come through - one example of that lies in the fact that you can hear a hard and a soft transient that are literally simultaneous, both being reproduced without any interaction. could be this is one of the few five - star components. Time and further evaluations will tell."
(The Absolute Sound, Issue 116)
Mark Levinson No 39 -> Krell FPB-200c -> Ino Audio pi60s
Edited by - gromit on 2003/12/30 11:09:26
