 Fett slutsteg?
Amazon
fd. arne
Posted - 2003/09/09 :  15:57:31  Show Profile Send Amazon a Private Message
''The Krell MRA, which weighs three times more than I do, is part of the same series as Krell's Master Reference Subwoofer. It is a whopping 25½" × 18½" × 35" — and is only a monoblock! The MRA features Krell's CAST™ (Current Audio Signal Transmission) which has been developed "...to send audio signals from component to component without introducing the negative effects of interconnect cables into the signal, i.e., loss of gain, reduced slew rate, and tonal coloration." The amp's gain stages operate in current mode, rather than voltage mode amplification. The output stage is comprised of 216 proprietary output devices manufactured for Krell by Motorola. The signal path within the MRA is balanced from input to output. Power output? More than you will ever need: exceeding 1,000watts into 8ohms, 2,000watts into 4ohms, 4,000watts into 2ohms, 8,000watts into 1 Ohm, and 16,000watts into .5ohm — better warn your local power company before hooking this one up.''
310kg, 1000Watt klass A, 120000$
Edited by - Amazon on 2003/09/09 15:58:58
J-son
Ej medlem längre
Posted - 2003/09/09 :  16:00:53  Show Profile Send J-son a Private Message
K-man
Posted - 2003/09/09 :  16:03:26  Show Profile Send K-man a Private Message
Skit oxå! 3 cm för högt för mitt slutstegsfack exkl kylning....annars så!
\\k-man
Edited by - K-man on 2003/09/09 16:03:58
MartinH
Audiotrade
Posted - 2003/09/09 :  16:12:27  Show Profile Send MartinH a Private Message
Visst är det stort, kraftigt, dyrt och maffigt.. Men sen kan man fråga sig om all den kraften verkligen behövs ?!?! Men coolt är det...
/M
Ayn
Posted - 2003/09/09 :  16:16:53  Show Profile Send Ayn a Private Message
Okej, har varit med så pass länge att jag inte längre borde utbrista sånt här, men - ca 1,2 mille för ett monoblock?!?
För 2,4 mille till ett system ska det jäklar i mig vara bra ljud, så jag hoppas att Krell-nissarna inte bara brer på med priset för att de kan...
jls
Posted - 2003/09/09 :  16:31:21  Show Profile Send jls a Private Message
Tyckte att det andra steget såg bra mycke bättre ut.. ska man lägga ut sånna pengar vill iaf jag att det ska finnas lite för ögonen också.. fast, det kanske tar uppmärksamheten från det som är mer vikigt..
ekman
Posted - 2003/09/09 :  16:42:31  Show Profile Send ekman a Private Message
går moonblocket i klass a då??
sen tror jag inte det är i närheten ljudmässigt heller men ändå
Amazon
fd. arne
Posted - 2003/09/09 :  17:17:21  Show Profile Send Amazon a Private Message
Tycker detta steget verkar ganska så intressant också... Hifi klubben ska ju ha det i sitt sortiment..
http://www.classeaudio.com/Omega%20Mono,%20SACD,%20preamp/OmegaMono.html
Edited by - Amazon on 2003/09/09 17:19:14
geten
Posted - 2003/09/09 :  17:54:48  Show Profile Send geten a Private Message
Hehe ja den där Krell Master Reference är inte dålig
Små??
// Johan
ekman
Posted - 2003/09/09 :  18:08:32  Show Profile Send ekman a Private Message
arne hifiklubben tar nog bara in omegablocken på beställning
fast dom är ju bra mkt mindre än krellstegen =)
Amazon
fd. arne
Posted - 2003/09/09 :  18:35:56  Show Profile Send Amazon a Private Message
Kopia av meddelande:
Ursprungligen postad av ekman - 2003/09/09 :  18:08:32
Jobbit.. Detta steget hade de iaf i butiken sist ja va där och kollade...
http://www.hifiklubben.se/show.php?folder=8&product=CA401
ekman
Posted - 2003/09/09 :  18:43:45  Show Profile Send ekman a Private Message
jo ca401 eller cam350 är det ju dom brukar dema med men omega är jag rätt säker på att dom inte tar in
däremot har jag sett omega försteget och omega cdn i sverige men det var innan hifiklubben tog över classe
Posted - 2003/09/09 :  18:56:26  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Den här blir minst lika varm!
fidelityn
Posted - 2003/09/09 :  20:44:39  Show Profile Send fidelityn a Private Message
120000$ för en brödrost
Bravo
Posted - 2003/09/09 :  20:45:56  Show Profile Send Bravo a Private Message
En tjusigare släkting kanske
Saxat från hemsidan:
Energiförbrukning : 840 W (±5%) tomgång
210 W (±5%) i standby
Power Output : 300 w / 8 ohm kontinuerlig effekt
2400 w/ 1 ohm kontinuerlig effekt
Ovanstående mätningar mätt från 20 Hz-20 kHz med max 0,3% THD.
Störningsförhållande: Bättre än –80dB (ref. 1 w)
Vikt: 435lbs. (198kg) styck.
Priset? ca: 300. 000 paret, budgetförstärkeri i dessa sammanhang.
Bravo
sopwith
Posted - 2003/09/09 :  22:53:32  Show Profile Send sopwith a Private Message
1,2 per st i ett 5.1 system, är väl inget att gråta över, räkningen för kärnkraftverket man fick bygga utanför kommer säkert däremot att ta knäcken på én.
Bravo
Posted - 2003/09/09 :  22:56:50  Show Profile Send Bravo a Private Message
Eller när du blir tvungen att bygga om alla elinstallationer hemma, vilka säkringar (försäkringar) krävs?
Bravo
Posted - 2003/09/09 :  23:41:20  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Dom här tycker jag är häftiga också:
Pass Labs X1000. 1000W (varav 160W klass A) 100 kg/styck
Amplification component of the year; Stereophile 1999
Fisksmisk ola
Posted - 2003/09/09 :  23:44:27  Show Profile  Visit Fisksmisk ola's Homepage Send Fisksmisk ola a Private Message
jag är inte säker på att bernts makapär går i klass a hela vägen!
Euroline - T-Amp - DIY
Posted - 2003/09/09 :  23:55:29  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Nä, det gör den inte, 160W klass A resten upp till 1000W är AB. Men ändå...
Den här går i ren klass A:
http://www.passlabs.com/images/product/xa200-b&w.jpg
ekman
Posted - 2003/09/10 :  00:54:00  Show Profile Send ekman a Private Message
två st 36amps säkringar har jag hört att man behöver till MRA =)
och #33? 300w? det är ju en klockradio =)
Bravo
Posted - 2003/09/10 :  01:14:01  Show Profile Send Bravo a Private Message
För oss ödmjuka.........
Bravo
everwake
Posted - 2003/09/10 :  08:34:21  Show Profile Send everwake a Private Message
Då är jakten på slutsteg över...nu gäller det bara att hitta en högtalare med dippar ner mot 0,5 ohm, som klarar 16KW
hittar säkert sin väg till någon shejks PA-rigg
löser iaf problemet med att slutstegen går över i A/B när man krämar på
Amazon
fd. arne
Posted - 2003/09/10 :  08:54:24  Show Profile Send Amazon a Private Message
Blir nog svårt.. Men dessa kanske skulle passa. ''Low Frequency Regenerators: 12,000 watts per channel..''
Kostar bara $600,000 och väger 2.3 ton totalt. Ganska höga iof. Får bygga större vardagsrum
http://www.wisdomaudio.com/infinitespecs.html
Edited by - Amazon on 2003/09/10 08:56:26
everwake
Posted - 2003/09/10 :  14:14:23  Show Profile Send everwake a Private Message
dra mig baklänges....det där var onekligen det värsta jag någonsin hört talas om....trodde inte att sånt fanns....men nu vet jag ju varför elektroniktillverkare envisas med att bygga monster-steg...för att matcha monsterhögtalare förståss
ekman
Posted - 2003/09/10 :  16:34:53  Show Profile Send ekman a Private Message
det där är väl dessutom inte ens wisdoms största system =)
Denna sida genererades på 0.89 sekunder. Snitz Forums 2000
