 Ny referens - CD spelare från Resolution Audio
robban
Audio Concept
Posted - 2003/08/06 :  16:14:53  Show Profile  Visit robban's Homepage Send robban a Private Message
Opus 21
Resolution Audio är ett mindre, men specialiserad amerikanskt företag som gör CD spelare I världsklass. Förutom en gedigen bakgrund har de över 10 års erfarenhet inom High End produktion, och Opus 21 är kulmen av en längre utveckling som baserar sig på deras tidigare kritikerrosade CD55.
Spelaren:
Specifikationer; (från tillverkarens hemsida)
The opus 21 cd player inherits the strengths of the cd55...
-(4) BurrBrown PCM 1704 24-bit converters, still the finest available
-16x digital filter upsamples to 705 kHz/24-bit data rate
-analog-domain volume control maintains full converter resolution at any volume
-balanced and single-ended outputs which drive any power amplifier directly.
...incorporates new techniques for stunning performance...
-improved analog section increases detail and soundstage
-CDROM mechanism improves disc playability and reliability
-96 kHz/24-bit digital input enhances two-channel home theater
-external power supply with central display eliminates noise
...and is delivered in an innovative European-inspired chassis design
-two-chassis design for flexible system installation
-aluminum chassis avoids magnetic interference of steel
-24 x 25 x 7.5 cm (9.5 x 9.8 x 3 in) WxDxH (Each component)
By moving the power supply and display to a second chassis, the critical audio circuitry is free to bring out more detail than ever before. Three-dimensional circuit construction, while more costly, dramatically reduces signal path for unparalleld precision.
A design this sophisticated requires an equally compelling chassis. By avoiding steel, the audio signals are free to develop without being constricted by magnetic interaction. The compact design is a refreshing departure from the common, overbuilt excesses crowding the marketplace. The result is a distinctive player of unmatched musicality at a surpisingly affordable price.
Tillverkarens hemsida; www.resolutionaudio.com
Investering: 39 500.-
Information och provlyssning: info@klubben.net
Tester:
http://www.audioasylum.com/audio/digital/messages/46666.html
http://forum.audiogon.com/cgi-bin/fr_srch.pl?ANY&&purlsrch&EXY&&&&resolution+audio
http://www.positive-feedback.com/Issue1/resolutionaudioopus21.htm
HiFi + (senaste numret)
  Ansvarar för distribution och försäljning av HIFI produkter via,
hsivp
Gissa vad min förkortning betyder!
Posted - 2003/08/06 :  19:39:08  Show Profile  Visit hsivp's Homepage Send hsivp a Private Message
Vad ska man säga.. äntligen i sverige =)
marbrink
Posted - 2003/08/06 :  19:41:54  Show Profile Send marbrink a Private Message
tror det var test på dom i nyaste hifi choice...
Posted - 2003/08/06 :  21:40:11  Show Profile Send 10 a Private Message
"Äntligen" är bara förnamnet! Då kanske det är dags att sätta ut en säljesannons och skaffa lite nya lådor? Fast man kanske ska lyssna först...
Tack Robban och Klubben.net för att ni gör Sverige till ett bättre land att leva i!
sampix
Posted - 2003/08/07 :  10:06:15  Show Profile Send sampix a Private Message
jag såg den där spelaren i någon tidning. förmodligen hifi-news (??).
Otroligt vacker skapelse!
några personliga lyssningsintryck?
kabelskitsnackare
robban
Audio Concept
Posted - 2003/08/07 :  10:38:19  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej,
Trevligt med all positiv respons...
Har kört den några timmar nu - direkt ansluten till mina monosteg - och dynamik, upplösning och engagemang i musiken är några omedelbara personliga intryck som det skulle gå att skriva en hel del mera om.
Men det är nog bättre att andra skriver om sina egna intryck. Provlyssning rekommenderas. Bor ni i Stockholmsområdet får ni mycket gärna testa den i er egen anläggning.
Mail till: info@klubben.net
Mvh, robban
jan
Hög Fidelitet
Posted - 2003/08/07 :  11:40:21  Show Profile  Visit jan's Homepage Send jan a Private Message
Jep - det likar jeg. Ingen pris här - men helt korrekt en INVESTERING! Om bara andre ochså hadde likadan instilling och inte hela tiden fokuserer på rabatter, billigt och tilbud.
Jan Nielsen
http://www.pladespilleren.dk
Posted - 2003/08/07 :  18:51:06  Show Profile Send 10 a Private Message
Fråga till Robban: Hur ser fjärren som följer med ut? Det är väl inte den där hemska plastbiten som visas i HiFi+-recensionen?
robban
Audio Concept
Posted - 2003/08/07 :  22:04:17  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej 10,
Nej, den modell som vi erbjuder är den helt nya - ny fjärrkontroll med direktaccess, nytt moderkort, tyst drive etc. HiFi + kommer att göra ännu ett test av denna, nya maskinen lite längre fram.
PS. Rekommenderar även att läsa testet i nya numret av HiFi Choice.
Mvh, robban
Posted - 2003/08/08 :  12:00:37  Show Profile Send 10 a Private Message
Hmm, trist med en plastfjärr när man lägger 40 kkr. Fast å andra sidan slipper man ju betala ett par tusen för en metallfjärr man kanske inte vill ha, så...
Alla kan inte vara lyckliga hela tiden!
hifidreamer
Posted - 2003/08/08 :  13:25:12  Show Profile Send hifidreamer a Private Message
Morsning!
Det verkar vara en trevlig sak de där. Gör de måhända DVD - spelare också?
Posted - 2003/08/08 :  14:02:50  Show Profile Send 10 a Private Message
Det kan jag svara på. Inga andra produkter än Opus 21 för tillfället. Dock har de en integrerad förstärkare på gång som är utvecklad tillsammans med DNM. Borde vara klar inom en snar framtid. Vet kanske Robban något om priset på den? Det kunde ju vara trevligt att ha ett helt minisystem med vettigt ljud i sovrummet eller så!
Också, fan vad sugen man börjar bli att höra skapelsen! Bilden med fjärren får det att vattnas i min mun!
MartinH
Audiotrade
Posted - 2003/08/09 :  19:50:10  Show Profile Send MartinH a Private Message
Trist med företag som inte ens kan göra ett eget skal till den "Philips" fjärr man köpt.. Sorgligt att man inte har ett genomgående kvalitets tänkande..
robban
Audio Concept
Posted - 2003/08/10 :  01:03:12  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej,
Visst – håller med - fjärren är lite plastig. Den gör hursomhelst det jobb den skall. Det är samma som tex. Tact använder till vissa av deras produkter. Tror inte den blir bättre bara för att man flyttar elektroniken till ett metallhölje – bara dyrare och tyngre.
Recensenter hade tidigare synpunkter på en del funktonalitet som fattades den (gamla) fjärren såsom direktaccess till skivspår. I den nya fjärren är detta fixat.
Den kommande integrerade förstärkaren verkar mycket intressant. DNM är inblandat, vilket är spännande. Tyvärr vet jag inget pris än.
MartinH – det är väl just en genomtänkt kvalitetsstrategi som präglar produkterna från Resolution, till skillnad från mycket annat i marknaden. Personligen ser jag det som ett stort kvalitetstecken att Resolution har fokuserat på de delar som har störst betydelse för ljudet.
Om du rannsakar de produkter du representerar vill du säkert hitta många exempel på producenter som köper produkter (OEM) av andra producenter och använder dem i de egna konstruktionerna. Vissa produkter ändras och vissa ändras inte inför ramen av den egna konstruktionen. CD spelare är bra exempel på just detta. Fjärrar, drivverk, nätdelar, etc. köps in och används på det sätt konstruktörerna har planerat. Det är alltså inte komponenterna som i störst grad skiljer produkterna åt, men konstruktörernas design, ideal, etc...
Mvh, robban
MartinH
Audiotrade
Posted - 2003/08/10 :  01:12:56  Show Profile Send MartinH a Private Message
Jo tack, jag vet mycket väl hur OEM tillverkning och försäljning fungerar.. Men jag tycker ändå att det inte känns speciellt kul att köpa en produkt för 40000:- och få med en fjärr som ser ut som om den följde med nått som man köppte på OnOff -89.. är dock helt säker på att den gör sitt jobb, men det känns lite väl billigt på en sån produkt.
Vet dock att många företag har det på detta sättet, men det gör det inte bättre för det, jag tycker att har man lagt ner så mycket på elektronik och t.o.m på kartongen som den kommer i, varför inte på fjärren ??? Jag skulle inte vilja ha den på vardagsrumbordet i alla fall..
/M
robban
Audio Concept
Posted - 2003/08/10 :  01:25:53  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej MartinH,
Det är enkelt – om du vill ha en CD spelare med en viss sorts fjärrkontroll – och tycker det är viktigt, så söker du upp en sådan spelare och köper den.
Om inte du hittar en kan du alltid köpa en ”One for All” fjärr, - om inte annat som dekoration i ditt vardagsrum...
Mvh, robban
MartinH
Audiotrade
Posted - 2003/08/10 :  01:35:16  Show Profile Send MartinH a Private Message
Självklart..men jag förstår bara inte riktigt tanken bakom det hela bara.. Och One For All är inte direkt snyggare så det blir nog inte en sån heller.
Lite vad jag menar är att det är synd att inte företagen har en mer genomgående design i alla delar idag, man snålar in på en del som faktisk ibland syns mer än själv elektroniken ?!?!
robban
Audio Concept
Posted - 2003/08/10 :  01:49:44  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej MartinH,
Det kan väl inte vara så svårt att förstå - att företagen gör val när det gäller de produkter de producerar. Om du tycker fjärrkontrollen är viktigast, eller att den skall vara i samma utförande som apparaten i övrigt, så styr kanske det i större grad ditt val än andra förtjänster som produkten erbjuder. Det är i så tillfälle ditt val.
Det finns säkert massor av matchande produkter där ute......
Mvh, robban
Bravo
Posted - 2003/08/10 :  01:52:14  Show Profile Send Bravo a Private Message
Verkar vara en intressant apparat, bara det att man separerat nät- driv- verk från varandra. Intressant att höra om den skulle kunna ta upp kampen med mina egna apparater.
Trevligt utseende dessutom. (frånsett fjärren då!)
Bravo
robban
Audio Concept
Posted - 2003/08/10 :  01:53:44  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej Bravo,
du är välkommen att provlyssna den och jämföra.
mvh, robban
sladd
Posted - 2003/08/10 :  08:28:52  Show Profile  Visit sladd's Homepage Send sladd a Private Message
Hej Robban, ser trevlig ut den där!
Robban skrev till Martin H:
Om du rannsakar de produkter du representerar...
Vilka produkter är det?
Den som jämför med något sämre kommer aldrig framåt
Butiksägare, Hificonsult
Cyber
Posted - 2003/08/10 :  10:05:41  Show Profile Send Cyber a Private Message
Robban, om du har vägarna förbi (min) forumsträff i sep (återkommer med datum) får du gärna ta med dig skapelsen
robban
Audio Concept
Posted - 2003/08/10 :  10:48:56  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej Cybervoice,
det gör jag gärna.
mvh, robban
robban
Audio Concept
Posted - 2003/08/10 :  10:56:48  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej Sladd,
Jo, den är mycket bra. Hoppas du kan lyssna på den vid tillfälle.
Sladd, - för att svara på din fråga vore det väl bäst om MartinH själv berättar om sitt samband med Stockholmsbutiken HiFi Art. Det är väl så att MartinH representerar butiken och därmed deras produkter, även om han påstår sig vara en oberoende privatperson.
För min del får han mer än gärna representera vem han vill, men det är väl mer rättvist att han, såväl som vi andra gör, i så tillfälle lägger till en signatur som klargör hans anknytning till branschen.
Gör han det, framstår han själv som mer trovärdig, och hans kritik av andras produkter kommer inte att klinga lika ihåligt som den för tillfället gör.
mvh, robban
MartinH
Audiotrade
Posted - 2003/08/10 :  12:45:09  Show Profile Send MartinH a Private Message
Så lite du vet Robban.. Men min ev sammhörighet med HifiArt är på samma basis som ganska många av de kunder som finns hos butiken, vänskap,välvilja att hjälpa till och ett gediget hifiintresse !! Och att jag skulle representera HifiArt var mer än vad jag visste, för då skulle jag nog gå och se till att jag får nån lön därifrån oxå...
Men jag har gått ut med att jag har en bekantskaps relation till HifiArt tidigare och detta vet en hel del redan här på forumet. Och jag tycker inte att jag ska behöva lägga in i min signatur vilka personer som jag räknar till min bekantskaps krets.
Och det är ju kul att du Robban inte kan ta kritik på de produkter du tar in, ens om den är befogad...
robban
Audio Concept
Posted - 2003/08/10 :  13:21:46  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej MartinH,
Tror det är rätt många som genomskådad din verksamhet på forumet.
Att tex. i ett inlägg snacka skit om Supras kablar för att i nästa mening skicka kunder till nämnda butik för att köpa Kimber är väl lite mer än en vänlig handling. Det är typisk en ”snik-säljares” uppgift. Sedan kan man jo ta ut lön på många olika vis. Tex. sänkte priser på produkter man köper etc.
Sådant sker överallt – och är egentligen ok, så länge alla vinner på det och vågar skylta öppet med det. Problemet uppstår om man inte kan erkänna det. Då är du långt från en objektiv tyckare på forumet och inte längre trovärdig.
Att du kritiserar en fjärrkontroll bryr jag mig egentligen inte ett dugg om. Det indikerar bara att för dig är fjärrkontroller viktiga.
Som du ser av tråden är det fler som nämnt fjärrkontrollen. Inget problem med det. Det irriterande i ditt inlägg var med vilken tråkig ton och dålig dold illvillighet du framkom med din synpunkt.
Mvh, robban
