 Scheu skivspelare på den svenska marknaden
robban
Audio Concept
Posted - 2003/06/22 :  11:43:20  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej,
vi valde Scheu som producent av tallrik och lager till vår referensspelare Nordic Concept pga. deras hantverksskicklighet. Vi har även valt att erbjuda den svenska marknaden deras egen Cello, som är en enklare spelare, med mycket fina prestanda. Spelaren kan levereras med eller utan tonarm.
mvh, robban
Frän producentens hemsida,
“We proudly present our new approach to a ready to run turntable at an affordable price. The Scheu Cello is the result of our research in high mass turntables. The main focus was to bring all benefits of a high mass concept to a lower mass turntable. We could have made it completely different but after a short excourse with other bearings and platters we found out that it makes no sense saving money on the bearing and platter, which means that the bearing of the Cello is identical to the bearing of the Premier. The reduced platter thickness of 30 mm is a part of this new concept to keep masses balanced and this platter is manufactured exactly the same way as our thicker models. We offer black and transparent plinths.”
  Ansvarar för distribution och försäljning av HIFI produkter via,
guran99
Posted - 2003/06/22 :  19:49:21  Show Profile Send guran99 a Private Message
Hej !
Lite väl häftigt påslag på priset, 719 EUR enl. SCHEU hemsida blir 13500 SEK.
Guran
robban
Audio Concept
Posted - 2003/06/22 :  22:36:21  Show Profile  Visit robban's Homepage Send robban a Private Message
Hej Guran,
gör en "reload" av vår sida så ser du priserna,
11 000.- utan arm.
13 000.- med arm.
mvh, robban
