 Har du testat detta?
abbot Posted - 2012/09/18 : 16:32:23
GOOD USED TUBE PREAMPLIFIERS
If you already have a line stage, and are now looking for just a phono stage, and also want excellent quality without paying "big bucks", there is an easy solution that you will never read anywhere else;
Just find a top notch used tube preamplifier from the 1980#8217;s or 1990#8217;s at a bargain price!
Confused?...
All you have to do is take the audio signal from the preamplifier's "tape outputs", which automatically bypasses the preamplifier#8217;s entire line stage and all of its controls, except the selector switch.
More good news...
There are plenty of excellent choices;
Audio Research Corp. SP-8, SP-6 (later models), SP-10 & SP-11;
Conrad Johnson (not quite as desirable as ARC) PV-5, PV-7, PV-2, PV-1, Premier Two and Premier Three (check the circuit boards carefully for deterioration);
Counterpoint SA-3 and SA-5 series (very desirable);
Convergent Audio Technology SL-1 (all versions);
MFA-Magus and Audible Illusions Modulus II or III series.
The various Melos, Music Reference and the older Paragon and Precision Fidelity models (C-4, C-7, C-8, C-9) are also excellent choices.
If you are on a real tight budget, a Dynaco PAS-2, 3 or 3(X) will work very well.
All of these units can and should be modified (with superior coupling capacitors etc). There are undoubtedly a number of other models that are also worthy of consideration, which I have either overlooked or forgotten, for now.
FURTHER- I have CRITICAL information for those of you who are using the phono stage section of a tube preamplifier (through its Tape Output), while also bypassing its line stage. Since I've advised using this procedure for years now, here's the latest advice I learned (from Tom Tutay) about optimizing the performance of these components. It's quite simple...
While the Selector Switch is obviously on the Phono input, you should also make certain that the Tape Monitor switch, if there is one, is always set to "Tape" or "On". When you do this, the output signal of the dedicated phono stage goes directly to the Tape Output ONLY, while none of the signal goes to its internal Line Stage, which would further load it down, thus weakening it. Keep in mind: ANY weakening of this already delicate phono signal will be detrimental to it, so this procedure is mandatory if you want to optimize the inherent capabilities of the phono stage. This procedure may also help transistor phono stages.
Also, do NOT remove the tubes in the now unused line stage. Put "junkers" in the tube sockets if you have to. Why? Because the heater voltages may otherwise become too high for the remaining tubes still in the phono stage, which may both compromise their performance and even reduce their operating life.
Hämtat här:http://www.high-endaudio.com/RC-PhonoStages.html
RIAA-steget i Edison One är bättre än vad många är medvetna om. Bara ett exempel, Helge...
