 Skivor med "dubbla spår"
AlfaGTV Posted - 2012/02/09 : 10:56:18
Är det någon som känner till flera skivor med dubbla spår på?
Jag har en 12" 45rpm med "M" som innehåller den gamla hitten Pop Muzik:
The UK 12-inch single version was notable for the A-side having a double groove such that the two tracks ("Pop Muzik" and "M Factor") both started at the outer edge of the record and finished in the middle (with a long silence at the end of "M Factor" since the track was the shorter of the two). This resulted in a random selection of the two tracks, depending on which groove the needle landed in the lead-in.
Quoten kommer från Wikipedia, de förklarade bättre än vad jag kunde.
MVH /Micke
