 Gissa källan!
24U Posted - 2009/11/10 : 11:23:40
Detta står att läsa i en manual för ett känt märke. Undrar om dom känner sina kunder väl??? Och inte är det väl så att vi lite till mans känner igen oss??? Och... jag gör det i varje fall och så länge man har sjukdomsinsikt har inte vansinnet brutit fullt ut. Det sade åtminstone min psykolog. Den 27e i ordningen...
Further adjustments for the neurotic/paranoid enthusiast
There are many hypothesis and theories regarding the accurate setting of bias compensation,
cartridge alignment and V.T.A.
All these theories exist because these adjustments are only approximations or compromises.
There is no one hundred percent correct answer.
If the previous instructions are followed carefully then the arm and cartridge are likely to
perform at or near to the optimum.
Nevertheless other methods do exist (i.e. the use of test records for setting bias compensation
and complex multiple point alignment systems for cartridge setting). If properly
understood and implemented these systems cause no harm and may be used.
However care must be taken when using test records as these are generally designed for
professional use. They are only relevant as a comparison between different products and
can lead to hi-fi paranoia if used in isolation.
Likewise more complex cartridge setting systems may be valid but are difficult to understand
and if not used correctly may cause more harm than good.
So experiment if you wish but you are likely to gain more pleasure from listening to music.
4   L A T E S T    R E P L I E S    (Newest First)
AlfaGTV Posted - 2009/11/11 : 21:55:11
Det kan man lätt tro, jag såg att du hade nämnt tillverkarnamnet i din systemtråd! Men jag såg det EFTER att jag skrivit här!
Jag har originalkartongen och manualen till min egen RB300 i en garderob här bredvid
MVH /Micke
24U Posted - 2009/11/11 : 14:55:01
Juppz. And the winner is... men Du har väl fuskkollat på min hemmatråd... *blink, blink*
AlfaGTV Posted - 2009/11/10 : 12:04:28
Tycker jag känner igen det däringa! Kan det vara Rega? (För nån arm kanske)
MVH /Micke
MatsT Posted - 2009/11/10 : 11:28:31
They are only relevant as a comparison between different products and can lead to hi-fi paranoia if used in isolation.
Den varningstexten kunde nog vara bra att sätta på många testprodukter.
