 Record Stabilizing Ring
Big Pete Posted - 2007/05/01 : 12:04:19
Undrar om någon har prövat eller hört någon som har testat denna ring?
Det lovas, som vanligt mycket goda resultat och nöjda användare med tillhörande vittnesmål.
Frågan är om det ger mer än det kostar och motiverar hanterandet också?
Kolla själva på denna site.
www.soundfountain.com/amb/ttring.html
13   L A T E S T    R E P L I E S    (Newest First)
Big Pete Posted - 2007/05/06 : 13:06:30
Nu har jag fått svaret ang. ringen för alla intresserade, men där priset talar emot ett försök samt att min Shelter puppa ligger redan lite lågt med kort rör:
Thanks for visiting my pages and for your interest in The Universal
Record Stabilizing Ring.
In order to know whether the Universal RSR does fit your turntable and cartridge,
you will have some measuring to do.
The distance between spindle and outside of the arm base should be at least
170 mm and there should be a clearance of at least 7 mm between
top of the turntable mat/platter and any knob, switch, light or whatever
obstacle.
Furthermore the cartridge must have a cantilever which is long
enough not to touch the 0.6 upper segment of the ring when resting
on the record at the beginning of the groove. This especially is
important in case of a groove guard (thick edge of the record).
The distance between cartridge body and record groove should be
enough not to touch the upper 0.6 mm segment of the URSR.
Depending on the thickness of the groove guard there should be
at least one millimeter clearance.
The URSR can be used with most modern cartrdges, but not with
Deccas and Ortofon Moving Coil cartridges, as these have very
short cantilevers.
Roger S. Gordon of Positive Feedback Online wrote about his eperiences:
I have used the following cartridges with the URSR:
Miyabi 47, Koetsu Urushi, ZYX UNIverse, ZYX mono, Dynavector XV-1s, Denon 102, VdH Condor, VdH Colibri XGW, VdH Colibri XPW, and Benz LP Ebony.
I still need to try a Titan-i and an Allaerts. So little time, so many cartridges. All of these cartridges worked fine with the URSR.
The VdH are the easiest to use with the URSR because of the long, exposed cantilevers.
The ZYX mono, is the most difficult because of the short cantilever.
The Denon also has a short cantilever, but the bottom of the cartridge slopes up and away from the cantilever so the edges of the cartridge are high enough to pass over the URSR. On a couple of LPs I could not access the outermost grooves with the ZYX mono. I have also found a couple of LPs with a diameter larger than the URSR.
I loaned the URSR to a friend and he reported that one of his LPs was too small in diameter for the URSR. That works out to about 3-4 off size LPs for over 1,000 LPs tested. Not a bad percentage.Roger S. Gordon
Attached I have two documents for you to read/view.
At the moment I have the 33/45 clamp available. It is the one with the 45 RPM
adaptor. But leaving the adaptor out it works the same as the other clamp.
The price is GBP 38 plus shipment GBP 12 if it is ordered alone.
No shipping cost has to be paid if ordered with the Universal RSR.
The price of the Universal RSR is Euro 350 plus Euro 30 for shipment via Priority Air Mail.
Or $450 plus $45 for shipment via Priority Air Mail outside the EU.
For EU customers Euro 350 Euro 30.
Payment can be made by transferring the total amount into my Dutch bank account.
Paying via PayPal is also possible. In that case payment can be made on the day
prior to shipment.
The package consists of
*the Universal RSR
*Circular Centering Disc for placing the ring on the record
*the wooden crate
*the Manual
*the Philosophy.
It will take at least 10 days for a ring to be ready from the moment you order.
If you have further questions, do not hesitate to mail me.
Regards,
Rudolf A. Bruil
Rozenstraat 94B
1016 NX Amsterdam
(+31) (0)20 885 38 66
pick-me-up Posted - 2007/05/05 : 13:30:28
Precis. Har också läst en hel del om dem. Det är lite för extremt enligt mig.
Vad blir nästa steg sen? Att man binds i en stol med bundna ögon och tvångströja på sig när man ska lyssna på vinyl?
Någonstans får man väl dra gränsen ändå. Fast det finns säkert fanatiker som är beredda att göra vad som helst för att nå audionirvana. Se bara på dessa monsterspelare som väger flera hundra kilo!
Buggsson Posted - 2007/05/03 : 02:05:48
Om det är något att ha beror nog kanske på vem man frågar. Jag har sett även negativa aspekter på denna ring. Även t.ex. vakuumtallrikar som en hel del verkar tycka låter bra, finns det andra som tycker tvärt om. Det är väl "smaken är som baken" fenomenet kan jag tro.
eliot Posted - 2007/05/02 : 18:29:33
Audiophile Club of Athens har en artikel om en DIY Custom disc-'o'-ring for heavy platters ...
- de har för övrigt mycket intressant att läsa om olika skivspelare: http://aca.gr/paper37.htm
Mvh,
Eliot
Audionet Posted - 2007/05/02 : 17:46:45
VPI har det som tillbehör till en del av deras modeller.
Per Posted - 2007/05/02 : 16:00:22
Det gäller ju dels att platta till skivan men även om att ge skivan högre yttröghet. Med fyra 4mm blir det inte mycket extra massa.
eliot Posted - 2007/05/02 : 15:35:07
Detta är samma sak som Outer Limit från Clearaudio
I början på 90-talet demonstrerade Alfred Rudolph på Acapella med en skivspelare där han använde en sådan ring. Jag skulle tro att Suchy och Clearaudio hade fått idén av honom när de introducerade Outer Limit då de har ett nära samarbete....
Jag var faktiskt i kontakt med killen som hade gjort liknande ring till Michael Fremer's Simon Yorke för att han skulle specialtillverka en sådan till mig men basen till min luftlagrade tonarm är bara 4 mm ifrån skivtallriken så det är mycket knappt
//Eliot
Adagio Posted - 2007/05/02 : 12:30:35
Det ser i mina ögon ut som en bra och logisk lösning på problemet, hur stort problemet nu är? Jag har några ojämna skivor men endast en som ser riktigt läskig ut. Har man en bra arm och pickup som matchar varandra där VTA och nåltryck är rätt i förhållande till varandra, ja då klaras riktigt hemska vurpor av utan att det hörs. En bonuseffekt med denna ring är ju den ökade vikten i ytterkant vilket borde påverka fartstabiliteten i rätt riktning, pga svänghjulseffekten.
Är den dyr? Man måste ju sätta dess pris i förhållande till hur stort problem man har. Om man bara har krökta skivor kanske det är läge att köpa en discflattner från Clearaudio, en rätt dyr men väldigt bra historia enl recensenter iaf.
Om den inte är dyr så köp den och berätta för oss vad du tycker, den är ju snygg iaf och du slipper se när nålen åker bergodalbana, det är ju alltid värt nåt.
Big Pete Posted - 2007/05/02 : 09:04:49
Nu kanske vi kan återgå till själva sakfrågan då nagellängden är fastlagd.
Är detta ett ovanligt bra #8221;tweak#8221; eller bara en annan orm olja?
Ljudet ren allmänt är ju också klart förbättrat enl. vittnesmålen
Problem med ojämna skivor har väl alla mer eller mindre av i skivsamlingen. Frågan är om denna lösning är bäst?
PG Jeppsson Posted - 2007/05/01 : 22:27:48
Då behöver du inte klippa naglarna Calle.......
calle_jr Posted - 2007/05/01 : 22:02:18
He, ok, det förklarar ett och annat
Ronnie_Ericsson Posted - 2007/05/01 : 20:20:24
calle_jr: Metallringen ligger ovanpå skivan. Antar att du tyckte det såg ut om skivan låg ovanpå.
calle_jr Posted - 2007/05/01 : 12:22:28
Hmm, det blir jobbigt att ta av skivan om man inte har långa naglar.
