| Author |
Topic  |
govinda
Med nytt namn
2292 Posts |
Posted - 2021/05/04 : 13:55:10
"Progress Produktions" So what is Progress Productions? A record label? Well, of course we are in one way, but we operate much deeper and closer with our bands.
A path has been important for us since the start back in 2004. Together we work to reach small goals building upwards rather than just building a big hype around things. Because you know what... hypes never lasts! Our belief is to look 5-6 even 10 years ahead with new acts, slowly building a fan base, rather than having just one radio single and then you are out. We consider every release carefully and we want the band to take a big role in the production of an album. After all we are just the brand that have the honour of releasing the art created.
We always live by our slogan "Quality before quantity".
Progress Productions has no room for rock stars or huge egos, all art created by the bands released under our brand is of equal importance. Together WE ARE PROGRESS. Together our aim is to bring you the finest music available on the alternative scene. We hope you will find something that you like and love... just as much as we do.
http://www.progress-productions.com/ Så mycket härlig musik på svensk hemmaplan! Det finns en grym Trippelcd(199kr) med unikt material en riktig Gulklimp! finns ännu billigare för nedladdning. Trippelcdn med massa låtar är väldigt unikt samarbete som troligen blir svårt att överträffa! Begränsad upplaga 1000 ex
http://www.progress-productions.com/product/various-artists-procd100/ Smakprov förstaspåret https://youtu.be/efVT7Kij8vY |
Music Isn`t my hobby It`s my passion
Professionell Musiklyssnare Musik-Tantriker |
Edited by - govinda on 2021/05/04 18:00:06 |
4608 Posts |
Posted - 2021/05/04 : 15:37:35
Härligt,beställd nu. |
govinda
Med nytt namn
2292 Posts |
Posted - 2021/05/04 : 18:07:48
Härligt du kommer inte ångra dig Jag fick CD 0570 utav 1000 |
4608 Posts |
Posted - 2021/05/10 : 14:30:41
Det bidde nr 0705. |
govinda
Med nytt namn
2292 Posts |
Posted - 2021/05/10 : 18:26:54
Härligt hoppas du gillar musiken? Jag är imponerad vilka bra produktioner det är |
4608 Posts |
Posted - 2021/05/10 : 18:47:15
Det är bra på riktigt,jag är imponerad. |
4608 Posts |
Posted - 2021/05/11 : 11:11:01
Tydligen slutsåld nu. |
iMac
484 Posts |
Posted - 2021/05/13 : 10:33:58
| Det var skit att man missade denna, får se om det är någon som lägger ut den så man kan köpa den. |
"David mot Goliat" HK DPR 2005 vs AVR7000 |
Topic  |
