 Nytt från Genelec
Mattias
Posted - 2014/09/17 :  20:38:40  Show Profile Send Mattias a Private Message  Reply
Surfade och fann att Genelec ha lite nya monitorer på G.
De är ännu inte prissatta i Sverige och kommer inte börja produceras förrens i Oktober.
http://www.audioprointernational.com/new-gear/read/ibc-2014-genelec-showcasing-new-compact-smart-active-monitors/07466
New models
http://www.genelec.com/news/latest-news/1293-genelec-launches-new-compact-additions-to-its-smart-active-monitoring-range-at-ibc-2014/
Speakers
http://www.genelec.com/products/8330a/
http://www.genelec.com/products/8320a/
Sub
http://www.genelec.com/products/7350a/
Hoppas de inte blir för dyra.
/Mattias
Mattias
Posted - 2014/09/17 :  21:24:56  Show Profile Send Mattias a Private Message  Reply
GLM uppdaters till 2.0. Gillar möjligheten med trådlös volym kontroll.
GLM 2.0 software features:
GLM2 uiConnectivity for up to twenty-five 8300 Series monitors and five 7300 Series subwoofers
The GLM 2.0 introduces a new user interface designed to make setups and calibrations easier with enhanced flexibility.
Highly graphical approach to monitor placement in the room and system settings
GLM 2.0 computer control allows for repeatable, consistent performance, reducing perceived differences between listening environments or positions
GLM 2.0 provides interface to AutoCal automated acoustical system-wide self-calibration algorithm
Analogue or digital audio input types are created together with monitor groups
Each group can have a separate AutoCal calibration
Groups contained in one GLM system setup file can feature both analogue and digital input use
Unlimited number of system setup files can be created
Volume control via GLM 2.0 software fader or external wired or wireless volume controllers
Mattias
Posted - 2014/09/17 :  22:56:07  Show Profile Send Mattias a Private Message  Reply
När jag får prisuppgift återkommer jag.
För intresserade kolla Genelec forumet och denna tråd.
http://www.community.genelec.com/forum/viewtopic.php?f=4&t=1459
Mattias
Edited by - Mattias on 2014/09/17 22:56:56
