 Demo and used speakers
HES
Posted - 2014/09/02 :  22:29:59  Show Profile  Visit HES's Homepage Send HES a Private Message  Reply
Audiostatic DCP in silver
Electrostatic full rane speaker 25 - 22.000 Hz (and it will do it)
WE can supply subwoofer/-s for non-belivers for your convenience.
Demo in our showroom for personally booking.
Price was 8.000 EUR - now 3.000 EUR (in SEK with day ratio)
Jamo R909 - dipol speaker - 3 way
Price was 11.000 EUR - Now 7.000 EUR
Black piano lacquer
Have to be collected, no packaging is available.
The revolutionary Jamo R 909 floor-standing dipolar loudspeaker is packed with high-performance features:
Two massive 15-inch woofers,
A Seas magnesium midrange driver
A customized Scan Speak Revelator tweeter
A beautiful high-gloss, 1.7-inch thick baffle, with unique multi-ply construction
No other high end loudspeaker sounds or looks quite like it.
The R 909 is the perfect match for the highest quality amplifiers on the market. However, with 89dB sensitivity and very stable load at 4 ohms, it doesn't need huge power to drive it'although it will handle more than 800 watts of peak power, if you choose! The open design and drivers reproduce wonderfully transparent vocals and a response so dynamic that it's hard to believe you're listening to a speaker. The exceptionally firm bass provides excellent transient speed, precision and fluidity throughout the frequency range with no coloration or reverberation. The Jamo Reference R 909 fully captures the heart of the musical experience.
Specification:
System Type 3-way dipole
Impedance 4
Tweeter (mm/in) 25 / 1"
Midrange (mm/in) 140 / 5½"
Woofer (mm/in) 2 x 380 / 15"
Product dimensions (mm/in, HxWxD) 1276 x 488 x 541
Frequency Response (Hz, +/-3dB) 35Hz-30kHz
Power Handling (Watts Long/Short Term) 550 / 800
Sensitivity (dB, 2.8V/1m) 89
More info: http://www.jamo.com/speaker-types/floorstanding/?sku=R909
www.HighEnd-Sound.com
Showroom kun efter aftale +45 60 77 24 48
AMAZON Audio, Audiostatic, Playback Designs, Tricord Research RIAA, Tri-planar + many more
Edited by - HES on 2014/09/11 23:46:04
